Collecting Envelope Generators
Page 1 of 1 [16 Posts]
kijjaz
PostPosted: Mon Jun 02, 2008 2:12 pm    Post subject: Collecting Envelope Generators
Subject description: let's build and share Envelopes
Let's design some Envelope Generators ^_^
I'll start with the simplest thing I've always been using.
A simple exponential decay! ..
(encapsulated into a ready-to-use class)
Code:
class kjzExpDecay01
    /* kijjaz's simple exponential decay version 0.1
    Copyright (C) 2008 Kijjasak Triyanond (kijjaz@yahoo.com)
    This program is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or any later version.
    This program is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with this program.  If not, see <http://www.gnu.org/licenses/>. */
    // set up a gain, feedback into itself, and output the signal
    Gain g => Gain g_fb => g => Gain output;
    // this impulse add to the envelope
    Impulse i => g;
    0 => g_fb.gain; // default: no feedback
    fun void add(float x)
        x => i.next;
    fun void set(float x)
        x - g.last() => i.next;
    fun void decayRate(float x)
        1.0 - x::samp/second => g_fb.gain;
    fun void decayTime(dur x)
        1.0 - samp/x => g_fb.gain;
test code (with example decay time control):
Code:
kjzExpDecay01 A;
Noise s => Gain s_g => dac;
A.output => s_g;
3 => s_g.op;
int i;
while(true)
    if (i == 0)
        50::ms => A.decayTime;
        A.set(1.0);
    else
        20::ms => A.decayTime;
        A.set(.25);
    250::ms => now;
    i++;
    if (i == 8) 0 => i;
kijjaz
PostPosted: Mon Jun 02, 2008 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
There is another envelope I've just think up now,
the shape is like this kind of function:
f(x) = 4 * (a^x-1)/(a^(2x))
which is.. hmm looks cute ^_^
please let me know if there is a nice way to call it.
for now i'll call it the ... -_-
I can't even think of a name for it -_-" ..
ok.. exponential hill generator -_-"
Code:
class kjzExpHill01
    // kijjaz's exponential hill generator version 0.1
    Gain g => Gain g_fb => g;
    // envelope trigger
    Impulse i => g;
    Step one; 1 => one.next; // constant signal 1.0
    one => Gain OneMinusG;
    g => OneMinusG;
    2 => OneMinusG.op; // calculate 1-g
    g => Gain product => Gain output;
    OneMinusG => product;
    3 => product.op; // calculue g*(1-g)
    // normally, if g is around 0-1, maximum product is .25
    // (because maximum of x*(1-x) is .25)
    // so we'll adjust by multiplying the result with 4
    // to make maximum 1
    4 => product.gain;
        x => i.next;
    fun void set(float x) // default set value is 1
    fun void noteOn()
        1 => set;
test code:
Code:
kjzExpHill01 A;
A.output => Gain s1Freq => TriOsc s1 => Gain s1AmpEnv => dac;
A.output => s1AmpEnv;
3 => s1AmpEnv.op;
500 => s1Freq.gain;
while(true)
    Std.rand2f(1, 50)::ms => A.decayTime;
    A.noteOn();
    250::ms => now;
kijjaz
PostPosted: Mon Jun 02, 2008 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now this one is a mass-movement design in the same set
Code:
class kjzMassMovement01
    // kijjaz's mass and movement envelope generator version 0.1
    Gain p, v, a, F; // position, velocity, acceleration, Force (F=ma)
    Step mass; // object mass
    1 => mass.next; // default mass value = 1 unit
    p => Gain p_fb => p; // update position
    v => Gain v2p => p_fb; // velocity adds to position
    samp/second => v2p.gain;
    v => Gain v_fb => v; // update velocity
    a => Gain a2v => v_fb; // acceleration adds to velocity
    samp/second => a2v.gain;
    a => Gain a_fb => a; // update acceleration
    Gain input => Gain FdivM; // outside force applied to this mass
    4 => FdivM.op;
    mass => FdivM; // calculate delta F = m * delta a
    FdivM => a; // add outside force to the system
    // these add values to p, v, a
    Impulse p_add => p;
    Impulse v_add => v;
    Impulse a_add => a;
    fun void addP(float x)
        x => p_add.next;
    fun void addV(float x)
        x => v_add.next;
    fun void addA(float x)
        x => a_add.next;
    fun void setP(float x)
        x - p.last() => p_add.next;
    fun void setV(float x)
        x - v.last() => v_add.next;
    fun void setA(float x)
        x - a.last() => a_add.next;
    fun void pDecayRate(float x)
        1.0 - x::samp/second => p_fb.gain;
    fun void pDecayTime(dur x)
        1.0 - samp/x => p_fb.gain;
    fun void vDecayRate(float x)
        1.0 - x::samp/second => v_fb.gain;
    fun void vDecayTime(dur x)
        1.0 - samp/x => v_fb.gain;
    fun void aDecayRate(float x)
        1.0 - x::samp/second => a_fb.gain;
    fun void aDecayTime(dur x)
        1.0 - samp/x => a_fb.gain;
test code:
Code:
kjzMassMovement01 A;
A.p => SinOsc s => dac;
220 => A.setP;
2::second => now;
110 => A.setV;
2::second => now;
-220 => A.setA;
2::second => now;
1760 => A.setA;
2::second => now;
Frostburn
Audio files: 9
PostPosted: Mon Jun 02, 2008 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's more efficient to use filters to generate the envelopes.
Here's a simple exponential decay:
Code:
//Exponential decay from 1.0 to 'decayFactor' in 'decayTime'
//Controls:
0.1 => float decayFactor;
100::ms => dur decayTime;
Impulse impulse => OnePole exp => Gain AM => dac;
1.0 => exp.b0;
-Math.pow(decayFactor,samp/decayTime) => exp.a1;
//Fire!
1.0 => impulse.next;
//Apply:
3 => AM.op;
SinOsc sin => AM;
//Play:
week => now;
To boldly go where no man has bothered to go before.
kijjaz
PostPosted: Mon Jun 02, 2008 4:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh.. OnePole, thanks. that's more simple and looks nice also ^_^.
I've been testing kjzExpHill01 by trying to use it as a grain envelope shaper,
it turns out to sound quite smooth and easy to use.
this is one test code. very Birdie again hahhahh.
Code:
Gain master => dac;
.05 => master.gain;
kjzExpHill01 A[10];
DelayL d[10];
Gain g[10];
Noise s1 => LPF s1_f => SinOsc s2;
40000 => s1.gain;
s1_f.set(5, 1);
for(int i; i < 10; i++)
    s2 => d[i] => g[i] => master;
    A[i].output => g[i];
    3 => d[i].op => g[i].op;
    second => d[i].max;
while(true)
        Std.rand2f(0, 400)::ms=> d[i].delay;
        A[i].noteOn();
        Std.rand2f(1, 500)::ms => A[i].decayTime;
        Std.rand2f(1, 300)::ms => now;
Inventor
Audio files: 67
PostPosted: Tue Jun 03, 2008 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Whoah, slow down and back up a sec. I know I should know this by now, but exactly how does an envelope generator work? I presume it tracks the envelope of a signal so that you can do something with it? If that is the case then I've had good luck with thiis:
Code:
adc => FullRect fwr => LPF lpf => blackhole;
Then you set the lpf frequency so that it tracks the signal envelope. But that is much simpler than your code, so I must be missing something. Can you educate me on what I do not understand? Thanks!
For those about to ChucK, we salute you! - Ge Wang
Let's make noise for peace! - kijjaz
dewdrop_world
PostPosted: Tue Jun 03, 2008 11:35 am    Post subject: Reply with quote  Mark this post and the followings unread
No, an envelope is a slower-moving curve usually controlling the amplitude of a signal - ADSR is probably the most common type in synthesis though it has its limits. http://en.wikipedia.org/wiki/ADSR_envelope
One of the things I like in software synthesis is the ability to make arbitrary envelopes. Hardware synths often put pretty severe limits on the kind of enveloping you can do.
James
kijjaz
PostPosted: Tue Jun 03, 2008 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
kijjaz to Inventor: Oh, that you talking about is definitely an Envelope Follower.
Basically, it's a device that tries to follow the envelope of the input signal.
An Envelope is.. i see it's like a.. a.....
a letter envelope -_-"
for example, if you have a SinOsc letter,
but you want to fit it in a shape,
you put in an envelope and it'd look like the shape of the envelope from outside hahaha -_-
so basically, the way we usually 'envelope' a signal is by multiplying it with a signal created from an Envelope Generator.
http://www.soundonsound.com/sos/nov99/articles/synthsecrets.htm
This place introduce Envelopes well.
Inventor
Audio files: 67
PostPosted: Tue Jun 03, 2008 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
I see now, thanks for the clarification, guys. Interesting stuff.
PostPosted: Tue Jun 03, 2008 3:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree. Envelopes, particularly beyond simple stuff are a big issue on hardware synths... but I find that's partially because in hardware envelopes are linked to the polyphony architecture in a rather hard and non-flexible way.
I feel this is a huge issue and will/should be a big part of coming to terms with interfaces for electronic music in general in the next years/decades.
More practically speaking in the here&now; Curvetable (see /examples/special/ ) will get you a "envelope" with a arbitrary number of points and versatile ways of defining the curves between them. If that won't do you likely need some higher level behaviour that'll probably be very context dependant.
aargh! I thought I had submitted this some hours ago but now see I didn't. Oops.
Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard
Audio files: 20
PostPosted: Tue Jun 03, 2008 4:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent points.
I´m kinda expecting someone to come up with some digital hybrid envelope module designs soon. More complex envelopes would be cool, more control points and why not implement envelope tables? Very Happy
Gate outs at the control/ step points in a complex voltage controlled envelope?
I can imagine some pretty cool patches here. bounce bounce bounce bounce bounce
It´s time for more more coffee!! and beer
Music at MySpace and Virb - Forum
PostPosted: Wed Jun 04, 2008 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
That's basically what Curvetable is; a series of points with values, relative time offsets and a indication of the type of curve. Currently it takes up to 100 coefficients so that should get you 33 indexed points, I think. That should probably do.
rogan
PostPosted: Fri Jun 06, 2008 2:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
It's been a while since I've written anything in CSound, but I remember it being extremely easy to use exponential curves in ftables. I was kind of surprised that ADSR envelopes in chuck could only do linear interpolation. Is there any thought of implementing exponential envelopes (ftables)? It's all fine and good to code exponential envelopes as a sample by sample basis, but I feel like it makes more sense to have an envelope generator to do it automatically.
Frostburn
Audio files: 9
PostPosted: Fri Jun 06, 2008 4:06 am    Post subject: Reply with quote  Mark this post and the followings unread
You can always lowpass an ADSR envelope to get rid of the sharp edges. I actually use a Step that is doubly lowpassed with two OnePoles doing leaky integration. (Two OnePoles instead of one TwoPole to avoid floating point errors with long envelopes.)
But I agree that there should be a native implementation for smooth envelopes in ChucK.
Audio files: 20
PostPosted: Fri Jun 06, 2008 8:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes, but we want modules doing this in our dotcom systems, don´t we?
Cool
PostPosted: Sat Jun 07, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
I think 100 coefficients would mean a 100 pots and/or a 100 jacks. that would be one expensive module...
You could mount up a Mac Mini or MiniITX-based board?
Once You Know, You Newegg
