rogan
Posted: Fri Jun 06, 2008 3:46 am Post subject:
Gardner Reverbs |
Hi all,
I've coded the Gardner reverbs from the CSound book, by Hans Mikelson, into Chuck. They're based on loops of allpass filters, based on the idea of loading up lots of echos. The only problem is that they let a bit of high-freq ringing in, which make them sound sort of metallic.
I'll post my first versions here, along with a testing script. Let me know what you think!
| Allpass filter, used everywhere. |
 Download |
| Filename: |
Allpass.ck |
1.19 KB |
| Downloaded: |
30 Time(s) |
 Download |
| Filename: |
Gardner_SmallRoom.ck |
1.21 KB |
| Downloaded: |
27 Time(s) |
 Download |
| Filename: |
Gardner_MediumRoom.ck |
1.87 KB |
| Downloaded: |
22 Time(s) |
 Download |
| Filename: |
Gardner_LargeRoom.ck |
1.91 KB |
| Downloaded: |
25 Time(s) |
| Extendable script to test the reverbs. |
 Download |
| Filename: |
reverb_test.ck |
418 Bytes |
| Downloaded: |
21 Time(s) |
Joined: Jul 06, 2004 Posts: 6502 Location: The Hague, NL
Posted: Sat Jun 07, 2008 3:02 am Post subject:
You're using "public" as a equivalent to "fun" but I don't understand why? I thought the word was just reserved but didn't do a thing. I just tried and "public" seems completely equivalent to "fun" in classes. Then I tried to use it outside of a class (which is fine as well) and it turns out I can even spork a "public". This is quite weird. _________________ Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard |
rogan
Posted: Sat Jun 07, 2008 11:25 am Post subject:
Hmm.... I thought that functions in classes should be declared public if they were going to be used outside of the class.
But, I guess I was wrong. I just looked at the chuck manual, and I should definitely have 'fun' instead of 'public' there.
Thanks Kassan! |
kijjaz
Joined: Sep 20, 2004 Posts: 493 Location: bangkok, thailand
Posted: Sat Jun 07, 2008 11:27 pm Post subject:
| Public and fun in class -_-" (That's what I read the first time and got confused lol..) |
rogan
Posted: Mon Jun 23, 2008 9:50 pm Post subject:
Hi all,
I've been playing around a bit more with these reverbs and some additional delays. The following code is kinda neat (although the actual sound isn't that wonderful).
| Code: |
LargeRoom lr_reverb;
MediumRoom mr_reverb;
mr_reverb.chuck() => Delay delaym => lr_reverb.chuck => LPF rlpf => Delay delayl => mr_reverb.chuck;
0.5::second => delaym.max;
0.5::second => delaym.delay;
0.5 => delaym.gain;
0.25::second => delayl.max;
0.25::second => delayl.delay;
0.25 => delayl.gain;
1000 => rlpf.freq;
0.0 => float dry;
Gain forward;
dry => forward.gain;
Gain revgain;
1.0 - dry => revgain.gain;
Impulse i => LPF lpf => forward => dac;
lpf => revgain => mr_reverb.chuck => dac;
10000 => lpf.freq;
dur delholder;
while( true ) {
if ( Std.rand2f(0.0,1.0) > 0.5 ) {
1.0 => i.next;
delaym.delay() + (std.rand2(0,1) - std.rand2(0,1))::ms => delholder;
if ( delholder < (delaym.max() - 1::ms) || delholder > (delaym.max() / 2.0) ) {
delholder => delaym.delay;
} else if ( delholder > (delaym.max() - 1::ms) ) {
delaym.max() - 2::ms => delaym.delay;
} else {
(delaym.max() / 2) + 2::ms => delaym.delay;
Std.rand2f(0.1,1000.0)::ms => now;
The really cool part is where I change the delay length of one of the delays a random amount every random amount of time. This has the effect of tamping down transient high-frequency noise.
I've been thinking about doing something like this for awhile, because all the high-frequency elements pass right through digital reverbs without any loss. Randomness like this can help to quash it down.
So, just some thoughts. |
