The Threeler
Page 4 of 10 [235 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 Next
janvanvolt
PostPosted: Mon May 05, 2008 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Well. that was it. Tantalums... replaced with normal elco caps, no short anymore.
testing now.
Update: Filter now working over expectation. holy crap !
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
frijitz
Audio files: 54
PostPosted: Mon May 05, 2008 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
cheers
Ah, very good. Thanks andrew!
Ian
andrewF
PostPosted: Mon May 05, 2008 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
What is it with Tant.caps?
they seem so sensitive, but to what? voltage spikes, reverse voltage?
I certainly won't bother using them in synth ccts anymore, I need components that can handle my luddite tendencies.
RF
Audio files: 28
PostPosted: Tue May 06, 2008 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Tantalums are sensitive to reverse voltage...
I use tantalum caps in my modules quite often. (I scrounge them from scrapped equipment) I don't recall ever having a problem with them...
bruce
Audio files: 116
G2 patch files: 317
PostPosted: Tue May 06, 2008 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
One could consider ceramic caps now they are becoming available with larger capacitance values.
janvanvolt
PostPosted: Sun May 25, 2008 7:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
a finally got my panel from Schaeffer earlier last week so i finished all cabling today.
I just observed one strangeness (which somebody could help me out with):
- When switching modes with the rotary, i seem to have a short "short" in the whole power rail. not sure if it is +15 or -15V. besdies that the filter is working.
no other tantalums in the circuit, so i definitely can rule this one out.
ideas anyone ?
guitarfool
PostPosted: Sun May 25, 2008 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
You're probably using a "make before break" rotary switch. As it is rotated, it connects the wiper with the next contact before disconnecting with the previous one. Since the rotary switch in the Threeler selects alternately from V+ and ground, you're getting momentary shorts between V+ and ground.
Not all rotary switches are this type, but many are. Usually (like when switching between audio sources) it is a good thing. But not in this case Shocked
Anyone who hasn't built theirs yet (like me) should take this as a "heads up". Very Happy
janvanvolt
PostPosted: Mon May 26, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Any idea if i can put in CAPs to limit the short ? (e.g. ground connection?)
final solution might be another switch.
guitarfool
PostPosted: Mon May 26, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
You might try a current limiting resistor between V+ and the switch. I would think something like at least 1k might work. 1k would give you a current of 0.015 amps at a power dissipation of 0.225 watts (although briefly). Too large a resistor might cause the voltage at A0 and A1 to be too low. I haven't looked at a spec sheet for the DG409.
frijitz
Audio files: 54
PostPosted: Mon May 26, 2008 1:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unit --
Thanks for bringing that up. Yes, you need a break-before-make switch. Alternately, you can probably put a 10k resistor in series with either the V+ line or the ground line. I should have thought of that. Embarassed
Ian
Funky40
G2 patch files: 5
PostPosted: Mon May 26, 2008 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
and which ones are break bevore break switches ?
which would be the right ones from mouser ? ( locally i can get Lorlin, are those fine? )
janvanvolt
PostPosted: Mon May 26, 2008 4:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
never mind about the switch.
i now soldered a 10K in series to ground and the problem is no longer existant.
Thanks Ian for the Hell of a filter Smile
guitarfool
PostPosted: Mon May 26, 2008 4:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
the Alpha rotary 2P4T is Mouser part number 105-SR2511F-34NS
The "NS" stands for non-shorting, (break before make) as opposed to shorting, designated by a part number ending in just "S".
There's also the Alpha plastic enclosed type, Mouser part number 105-SR2611F-34-38RN. Both of these have round shafts and solder terminals (not PCB mount).
I prefer the 1st type myself.
frijitz
Audio files: 54
PostPosted: Mon May 26, 2008 7:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good, thanks! I thought that would work, but I haven't actually tried it.
Ian
Funky40
G2 patch files: 5
PostPosted: Tue May 27, 2008 3:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks, it came just in the right moment.
I also was not aware that there are shortening and non shortening types.
jnuaury
Audio files: 9
PostPosted: Thu Jun 05, 2008 3:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
does anybody want to show off their front panel for this?
ive been really interested in this bad boy but i think i need to see how much front panel real estate it takes up
Etaoin
PostPosted: Tue Jun 10, 2008 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
My Threeler appears go work great, although the (2)134's are running warm. Are they supposed to?
http://www.casia.org/modular/
frijitz
Audio files: 54
PostPosted: Tue Jun 10, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't remember them running warm, but I may not have checked carefully. Are they clipping against the rails when they get warm? Are they always warm, even with low feedback?
Unfortunately, I don't have one set up right now. I'll try to check this later in the week.
Ian
Etaoin
PostPosted: Tue Jun 10, 2008 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hehe, something is very wrong with mine. The res pot just went up in flames! I turned it slightly from zero on up and a big flame burst out of the side. Haven't seen that since I first began in electronics some 25 years ago Very Happy Back to my workbench...
Etaoin
PostPosted: Tue Jun 10, 2008 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, found it. I'm using pcb-mount Alphas. But if you mount those flush with the pcb, the pads on the pot are actually touching the extra two holes and causing shorts. A short from +15V to the wiper burned out the pot. So you need to mount Alphas slightly off the board (or isolate those extra holes).
Audio files: 116
G2 patch files: 317
PostPosted: Wed Jun 11, 2008 6:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Etaoin wrote:
[...]a big flame burst out of the side.
You seem to have a /power/ supply Laughing
frijitz
Audio files: 54
PostPosted: Wed Jun 11, 2008 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Ouch! You're saying the little legs on the slider terminal are hitting the pads for the smaller size pot? I'm not sure what I can do about that -- the board is layed out to accept two pot sizes.
Ian
bridechamber
PostPosted: Wed Jun 11, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I just tried trimming those little stops on the middle pin with a wire cutter, and that worked pretty well. Sorry it's necessary, though; that's one I never would have thought of.
RF
Audio files: 28
PostPosted: Sat Jun 21, 2008 9:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Such as it is - here's mine. Just fits on a 2 1/4 by 8 1/2 inch panel.
I left off the fine-tune for the frequency. May have been a bit crowded with it.
Just finished it tonight so have not played with it much yet - just a few tests to make sure all was good. It's quite an interesting/unusual filter....
props to Scott at Bridechamber for the parts kit and board. Everything was perfect.
Ian, it's a crazy/nifty filter thumleft - thanks for sharing it.
bruce
 Filesize:  70.83 KB
 Viewed:  145 Time(s)
 Filesize:  76.26 KB
 Viewed:  118 Time(s)
Etaoin
PostPosted: Thu Jun 26, 2008 6:11 am    Post subject: Reply with quote  Mark this post and the followings unread
This is my low budget Threeler panel. I left out the fine tune pot as well. Size is double Frac. Need to find another knob for the switch!
Threeler low budget panel
 Filesize:  66.82 KB
 Viewed:  115 Time(s)
Niio2
