ChucK, GUI and Processing
Page 1 of 1 [16 Posts]
ilSignorCarlo
PostPosted: Thu Jul 03, 2008 11:56 am    Post subject: ChucK, GUI and Processing Reply with quote  Mark this post and the followings unread
is there any way to know if ChucK can work with a particular graphical environment?
I mean, I'd like to bind ChucK to a GUI, but I am not sure if it's gonna work. Are there requisites that a programming language or a GUI should have to be compatible with ChucK?
Or, in general, how should I test it?
I've found this environment: Processing.
It seems pretty cool and I think it would be great to use in combination with ChucK. Just not sure that it is possible.
What do you think?
Self-referential phrases, like this one, are not so funny or good for a forum signature.
Inventor
Audio files: 60
PostPosted: Thu Jul 03, 2008 12:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some people have attached GUI's to ChucK in the past, but as far as I can tell it's a true DIY thing because it is unlikely that others will go through your particular setup process to get your GUI working, especially when ChucK has a GUI that's due for arrival to the Linux and PC versions anytime now. We've been waiting some time for "anytime now" to roll around but it is on the next release, thankfully.
So although it may seem cool to add a GUI to ChucK, you must realize that the probability is that only you will ever use it. At least that's what happened in the past when others attempted this. So the best thing to do, IMHO, is wait for the ChucK GUI to finally arrive, sigh. Wish I could be more positive about it...
EChucK: The synthesizer that got smashed into smithereens!
PostPosted: Thu Jul 03, 2008 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Processing makes perfect sense to me for this. As it's Java based the syntax isn't too different (less to learn!), it's also build as a educational intro to programming and graphics, it eats OSC, it's as cross-platform as ChucK...
As inventor points out; sharing your code (getting others to run it) will be harder but if you just need something for yourself I'd say "go!".
Modern technology offers an endless field day to any deviant strains in our personalities. --J.G.Ballard
ilSignorCarlo
PostPosted: Thu Jul 03, 2008 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, I understand this. But for a project I have in mind I think I need a GUI. Anyway, in this moment I'm a newbie with ChucK.
What can I try to do just to test if a GUI works well with ChucK? How am I supposed to bind, for example, the creation of a graphical object to a ChucK object?
Sorry if the question sounds stupid.
PostPosted: Thu Jul 03, 2008 5:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
No problem, we were all newbies at one point; I myself hardly know anything about the details of Processing.
I think you should look into OSC (Open Sound Control). You could make objects (classes) in ChucK that would also send out a OSC message to Processing calling for the creation of a interface as they get initiated. From there on it would be messages back& forth. You'd have to design a little protocol that would depend on your needs but it sounds doable if advanced to me.
Inventor
Audio files: 60
PostPosted: Thu Jul 03, 2008 6:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't let me discourage you, if you want a great ChucK GUI then I agree with Kassen, do whatever you want to! ChucK is designed to be flexible and friendly with other applications through things like OSC. I myself have not yet learned anything about OSC and it's a bit of a mystery so I can't help you, but I wish you the best of luck and look forward to some screenshots. I wish there was some decent ChucK-side documentation of OSC, but I haven't found any yet.
ilSignorCarlo
PostPosted: Fri Jul 04, 2008 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, with some more search I've found that actually someone already used Processing with ChucK, using OSC to make them communicate.
Do you know if there exist a starting tutorial or something about OSC?
Inventor
Audio files: 60
PostPosted: Fri Jul 04, 2008 3:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is one:
http://opensoundcontrol.org/topic/151
I did a google search on "open sound control tutorial" and found several others. If you figure it out, come back and tell us how it works. I haven't invested the time to learn OSC because there is little documentation of it on the ChucK site.
dewdrop_world
PostPosted: Fri Jul 04, 2008 8:19 am    Post subject: Reply with quote  Mark this post and the followings unread
If you're looking for the usual types of sliders, buttons, pop-up menus etc., another very good option is SwingOSC. It doesn't do everything processing can do, but it might save some effort because you would just have to implement the existing OSC protocol in ChucK -- no need to design your own brand-new protocol, and implement it in both ChucK and Processing.
The OSC protocol is documented here... the trickier thing is knowing which Java objects to instantiate and how to manipulate them. So I guess if you don't know swing classes, this might not be so much help.
Supercollider uses this for cross-platform GUI compatibility and it's working very well.
James
ilSignorCarlo
PostPosted: Fri Jul 04, 2008 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Mmm, I was searching something more flexible. I need to create objects, move them, connect objects to other objects...
Make them blink, faster or slower, depending on a metronome, for example. So I thought I could do all this with Processing.
Yes, I know Supercollider, but I think I prefer using ChucK.
dewdrop_world
PostPosted: Fri Jul 04, 2008 12:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, definitely Processing is a better fit for that.
(I wasn't trying to convince you to use SuperCollider btw... just pointing out an area where SwingOSC is being used successfully.)
James
ilSignorCarlo
PostPosted: Sat Jul 05, 2008 3:40 am    Post subject: Reply with quote  Mark this post and the followings unread
James
I was starting studying SuperCollider, but then someone pointed me to ChucK and it just seemed cooler to me Very Happy
Anyway, I've found this about ChucK and Processing:
http://visiblearea.com/blog/pub/VisibleArea/ProcessingandChucK/readme.txt
PostPosted: Sat Jul 05, 2008 5:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Considering that Swing OSC is a Java library, wouldn't you be able to load it in Processing anyway if you'd feel the need?
Audio files: 10
G2 patch files: 54
PostPosted: Sat Jul 05, 2008 4:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Didn't see this thread until now. I'm actually tinkering with a Java GUI for arranging samples on the fly, that I intend to have communicate with a ChucK program using OSC. So the Java app does all the fancy graphics stuff and calculates times, and ChucK does the sharp timing. Most of the crucial stuff in the Java app is in place, and I have working OSC communication (using my own home-brewed UDP implementation). Now I only need to get the ChucK stuff in place.
The main reason for me doing it this way is because I wanted to try out SWT in Java and just generally experiment a bit. I might be able do this with MAUI instead. It would be interesting to try running the graphical frontend on a different computer than the sound generating one as well.
Anyway, if this sounds interesting in any way, I'll probably have something to share soon.
/Stefan
@myspace @virb A blog home - in Cyberspace no one can hear you SEGV
Acoustic Interloper
PostPosted: Mon Jul 14, 2008 6:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been writing a lot of SWT code this year for my job, extending Eclipse for a DSP toolset, just finishing up a grapher for run-time costs in an instruction simulator for a DSP. When it comes to GUI programming, I'd WAY rather use Tk with Python (a.k.a. Tkinter) or Tcl than use SWT. Tk lets you attach symbolic tags to graphical elements on a canvas or in a text widget and manipulate sets of elements together. I've used it for the Python-to-ChucK (or SC or Max/MSP) chess game GUI here. SWT, in contrast, is lower level, for example you have to prep a bunch of data structures for painting and then do the actual paint in your code whenever the window is exposed, resized, etc. Not that SWT is bad, just that it operates at a much lower level. The only issue with Tk is that its widget set is somewhat dated, e.g. no toolbars per se, but it's a lot handier to program, in my opinion.
EDIT: This program works on multiple machines on a LAN, although I think for best results the Python algorithmic generator should be on the same machine as ChucK; less latency and overhead that way, and the Python program does not eat much CPU.
The GUI chessboards, though, can be distributed across the LAN, so players can sit on different machines when playing their chess games.
Ordinary Machinery . . . frightened her . . . It seemed to take up an Absurd Amount of Space.
Audio files: 10
G2 patch files: 54
PostPosted: Tue Jul 15, 2008 1:50 am    Post subject: Reply with quote  Mark this post and the followings unread
I've posted that project here: http://electro-music.com/forum/topic-27609.html
Moving from swing to SWT was enjoyable anyway. Everybody's talking about Python nowadays, so should probably check it out. I'm starting to become a bit set in my ways. Confused
/Stefan
