Joined: Apr 01, 2004 Posts: 2669 Location: Auckland, New Zealand
G2 patch files: 626
Posted: Sun Aug 29, 2004 3:39 am Post subject:
Sample and Hold patterns |
Two experiments in one patch.
On the audio side, I am fiddling with the integration from the G2 math thread (the little that I actually understood). I wanted to do a wave shaper from triangle to sawtooth to solve the symmetry problem with the LFO sawtooth.
The idea is, the integrator and constant compare module, switch between the triangle and an inverted triangle whenever the slope changes. While testing with a software scope, the switch control signal looked very noisy so I inserted a lowpass filter and things looked better. When adjusting the lowpass cuttoff, the wave sort of morphs from the original triangle shape to the (double frequency) sawtooth. Not spectacular, but it is a sort of interesting effect in the audio range.
The second experiment goes back to the old analogue days. I never owned a decent step sequencer so I had to make do with patterns made by summing the outputs of dividers, and the humble sample and hold. The sample and hold typically is fed a signal from a noise module and clocked by an LFO which gives that cliché, random notes effect. In this patch, the noise is replaced with an audio frequency LFO (LfoC2) and the output is scale quantitized. The result is an ever-changing pattern whose character changes with the difference in frequency. Some extra FM of LfoC2 further randomises things. The rhythm is from a combination of modulated pulse and clocked random triggers.
2 variations
Description: |
Triangle-Sawtooth wave shaper with S+H sequencer |
Download |
Filename: |
Tri2saw2.pch2 |
Filesize: |
4.1 KB |
Downloaded: |
1909 Time(s) |
Joined: Jan 31, 2003 Posts: 18197 Location: Durham, NC
Audio files: 212
Posted: Sun Aug 29, 2004 9:51 am Post subject:
Those S/H modules make great sequencers. Better than the step sequencers, IMHO, because they aren't as boring. They always play something new. This setup of yours is an interesting variation on the theme I have never seen before. The addition of the occational glide is fabulous. Variation two cooks. |
Wan
Joined: Mar 31, 2004 Posts: 259 Location: Netherlands, Ugchelen
G2 patch files: 46
Posted: Sun Aug 29, 2004 11:24 am Post subject:
Very clever patching.
i like the hihats parts how they play through the beat.
Indeed not as boring as stepsequencers.
My turn to be humbled _________________ Grtz Wan |
Audio files: 278
Afro88
Joined: Jun 20, 2004 Posts: 701 Location: Brisbane, Australia
Audio files: 12
G2 patch files: 79
Posted: Sun Aug 29, 2004 6:13 pm Post subject:
That's excellent. There's some really intelligible melodies coming from your lfo s+h circuit. At times it sounds like there's a chord progression that the melody is playing to - very cool. |
G2 patch files: 626
Posted: Sun Aug 29, 2004 6:26 pm Post subject:
Thanks Jan, good tip. A single scale can be a little monotonous.
I'm not a huge fan of this type of sound, sometimes the patch itself leads you. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Sun Aug 29, 2004 6:42 pm Post subject:
I just noticed that outs 3/4 are being used for some of the lead sound- are we supposed to hear these outputs? Or were they simply 'turned off'?
It sounds kinda cool when that output is switched to 1/2... |
G2 patch files: 626
Audio files: 212
Posted: Mon Aug 30, 2004 8:06 am Post subject:
What softscope are you using. Is it a freebee? |
G2 patch files: 626
Posted: Mon Aug 30, 2004 11:47 am Post subject:
It is from the freeware WIN3.1 wavetools.zip package. Sorry, cant remember the url I downloaded it from (active links are rare I think).
It works well under 98 & XP and the package comes with other tools I havn't tried yet. |
Audio files: 278
Audio files: 278
Audio files: 212
Posted: Mon Aug 30, 2004 5:10 pm Post subject:
This is great music to change servers by... |
Audio files: 212
Posted: Mon Aug 30, 2004 5:57 pm Post subject:
That WaveTools thing is excellent. Works great on my XP machine with the MOTU 828MKII. Think I'll post it on the How To forum. It may be faster for some people there... |
G2 patch files: 626
Audio files: 212
Posted: Tue Aug 31, 2004 2:09 pm Post subject:
Wow, this one is really beautiful, Ian. It has a lot of drama and suspense. It could be the soundtrack of a movie. I'm on the edge of my seat waiting for somthing to snap and someone to scream. |
Audio files: 278
Posted: Tue Aug 31, 2004 3:03 pm Post subject:
g2ian wrote: | Don't know if it is allowed but I am posting a prf myself. |
Sure you can, why not ? And it''s a good one I think.
Quote: | This one also uses one of Tim's patches |
Funny I also had this StringCheesy patch in mind to do 'something' with, I like the liveliness of its sound.
The 48 KHz .. I saw it as well and I noted the unused inverter to be connected, and wondered why ... . It's used to get it to run at audio rate I suddenly realize (and I now know why certain experiments I did with this circuit failed). Aha !
I knew Rob wouldn't do a useless thing ...
Jan. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Tue Aug 31, 2004 5:30 pm Post subject:
Ian, that's a fantastic performance! Like Mosc said, it could really be part of the soundtrack for a movie. Top notch.
At the moment I'm trying to figure out how your chords work... not having much luck though I've noticed that your bass notes sympathise with the chords as well. It's a very complex set up. Something to do with the mux? |
G2 patch files: 626
Posted: Tue Aug 31, 2004 7:09 pm Post subject:
Thanks for the kind words
The chords are sort of tacked on the side. The bass generator is the same as the original except that the S+H output is taken to three KeyQuant modules, these get fed into the eight in mux (using all eight inputs allows a crude influence over probability) The mux is switched by RndPattern1 clocked by ClkDiv2, fed from the master LFO (lfoC3).
ClkDiv2 also supplies RndTrig3 pulses that directly gate the two noteSend modules in the chord section. The output from the Bass mux at the time the gate goes high offsets the note values in the chord. The S+H here is redundant , as the noteSend will effectively latch the value anyway.
The two notes are sent to SlotB which via the notezone module, passes then also to slotD for layering.
Not the result of careful planning, more like fiddle till it sounds ok, adding more modules as a last resort.
These type of sampled lfo patterns are by themselves, quite repetitive. This one is randomised by x-modulation and slow modulation applied to the sampled lfoC2, use the mixer above to vary the variation. I think this is one of the few practical applications of the aliasing effect. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Tue Aug 31, 2004 8:02 pm Post subject:
Very nice. Thanks for the explanation Ian I thought the chords were transposed with the bass... that's really quite a clever way of doing it. I'm not very experienced with programming noodles (as you can tell I program alot of dance based stuff) but every now and then a patch like this one comes along that inspires me to have another crack at creating a worthwhile noodle... perhaps this time? |
Audio files: 212
Posted: Tue Aug 31, 2004 8:36 pm Post subject:
There are lots of dance based noodles. |
Afro88
Audio files: 12
G2 patch files: 79
Posted: Tue Aug 31, 2004 10:20 pm Post subject:
mosc wrote: | There are lots of dance based noodles. |
Hmmm.. I may have to dig around the G1 patch archives for a bit. With the new module reference list it shouldn't be too hard to convert some over to the G2. |
Audio files: 278
Audio files: 212
Posted: Wed Sep 01, 2004 1:52 pm Post subject:
Whoa, this goes from being humorus to being tortuous.
Not one of my favorites, Jan. |
Audio files: 278
Posted: Wed Sep 01, 2004 5:04 pm Post subject:
mosc wrote: | Whoa, this goes from being humorus to being tortuous. |
Sorry to hear you don't like it ... it's better than the previous one though in my humble obsession. It has more diversity, and it fits my mood better.
I hope this mood will change though now that my summer holiday started, finally, today. I've been dragging myself for a while.
Draging myself job-wise, the presentation of the noodle radio went quite well last weekend. some liked it others didn't, but I got asked to do something like it for a picture exhibition by a painter who's work I liked. I'm happy with that.
Anyway, holiday .. tomorrow I'll be hanging around still till afternoon or so, after that I'll be out for about ten days. Just the usual trip when I need to be away, to Ireland
Jan. |
