a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Fri Jun 27, 2008 9:08 am Post subject:
scott where is your klee?
i'm only 400km from mine
i'm in my wifes home town down on adriatic coast.
it is darn hot. juck |
Posted: Fri Jun 27, 2008 4:28 pm Post subject:
Scott Stites wrote: | Quote: | I would replace the sliders with a switch of some type. |
At least for the method of how I use the Klee, I'd have to disagree. This would sort of kill things for one step sequences. For the higher range sequences, the small adjustments do make quite a bit of difference. |
What Scott is saying makes a lot of sense, and he has been using his Klee alot more than I have, so I will humbly make a 180degree turn on the "lose the sliders" opinion, and bow to the experience of my learned friend. _________________ What makes a space ours, is what we put there, and what we do there. |
Luka
Scott Stites
Audio files: 96
Posted: Fri Jun 27, 2008 10:09 pm Post subject:
Well, actually Andy, it's not such a bad idea - it may work quite well for others. I think we'll find that one person's Klee is another's Clover
My Klee is in Kansas, but I'm in Penang, Malaysia right now for a good long time ('til end of July). Not sure if it's *really* 10,000 miles, but I figure it's close to that. I'm closer to Andy's Klee than to mine.
Hmmmm......... _________________ My Site |
Scott Stites
Audio files: 96
Posted: Fri Jun 27, 2008 10:10 pm Post subject:
I keep forgetting to mention that is one spankin' badass circular panel! Very nice indeed. _________________ My Site |
Posted: Sat Jun 28, 2008 2:29 am Post subject:
Scott Stites wrote: | I'm closer to Andy's Klee than to mine.
Hmmmm......... |
Well,.... It's only a little flight down to Brisbane. Then a connector to Coffs Harbour. You get weekends off don't you? Charge work for it. Research and Development it's called. You can research the state of SDIY in Nambucca Heads, and we can develop a hangover together! _________________ What makes a space ours, is what we put there, and what we do there. |
sduck
Posted: Thu Jul 03, 2008 8:17 pm Post subject:
So here's mine. I probably get the award for ugliest klee panel yet.
Folks who also look in the modularsynthpanels yahoo group have already seen this, and the .fpd file is available there - I can post it here also if there's any interest.
I just wanted something that would fit right into my otherwise mostly motm format synth. It's actually Clickmrmike's design, with some slight tweaks of the switch positioning and labeling. I basically took an old milton panel design and modified the bottom of it.
Apologies for getting the electro-music Klee label wrong - I didn't read all of the applications and build thread until after I designed it.
So anyway, this panel is on its way to me from Seattle as of now, and I've got the boards half stuffed, and many of the panel parts are here or are on the way also. When I posted this design on modularsynthpanels, it seemed to get things going, and Thomas White did his amazing oval design, which'll also work for my purposes, so I'll probably end up getting one of those once Scott Deyo starts producing them cheaply. I like this straightforward, linear design, but I also really like the oval design - one can have 2 klees, right? This is assuming that eventually there'll be a third board run (hope!).
Description: |
Screen capture of my klee panel in front panel designer |
Filesize: |
144.47 KB |
Viewed: |
445 Time(s) |
Posted: Fri Jul 04, 2008 1:51 am Post subject:
fonik wrote: |
BINGO! thank you so much! |
these seem to be momentaries, aren't they? i am not quite sure about the mechanical details anyway. how do they work? _________________
Tech Buddy at Random*Source |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Wed Jul 09, 2008 4:40 pm Post subject:
Very very nice design Mono-Poly !!! All these great front panel iterations, there should be a Klee picture book made up
Bill |
sduck
Posted: Wed Jul 09, 2008 4:56 pm Post subject:
mono-poly wrote: | Wiard Klee |
That is really nice. Is that an official Wiard implementation of the klee, or a look-alike version? |
mono-poly
Posted: Thu Jul 10, 2008 11:07 am Post subject:
It is DIY for in my Wiard setup. |
Scott Stites
Audio files: 96
Posted: Thu Jul 10, 2008 6:05 pm Post subject:
Man, that is just absolutely beautiful. _________________ My Site |
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Tue Jul 15, 2008 11:13 am Post subject:
fonik wrote: | fonik wrote: |
these seem to be momentaries, aren't they? i am not quite sure about the mechanical details anyway. how do they work? |
sorry, i've been out of town and missed this.
yep they're momentaries.
there's conductive carbon on each silicon button and it contacts a pad on the pcb.
cool, sparkfun finally added diode pads to their pcb (to avoid ghosting in matrix switch circuits). i wound up making my own pcbs... |
Luka
Posted: Thu Jul 17, 2008 7:11 pm Post subject:
well here is my contribution
my modular panel material is a bit different from most,
im using rusty steel that i have found around our warehouse.
so here is my rusty klee.
sorry about photo quality
im still waiting for my switches,
then ill finally check the circuit build for any problems.
so excited !
cant wait to hear this baby in action _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
sduck
Posted: Thu Jul 17, 2008 7:25 pm Post subject:
At first glance I went "ewww, that's some serious funk". But then I found I couldn't look away - that panel has some serious depth, and looks like it'll be real fun to use. Cool variant on the steampunk thing. Thanks for sharing! |
Luka
Posted: Thu Jul 17, 2008 7:56 pm Post subject:
yeah its a bit grimey. but i kinda like that
one day ill have some cash and ill get some aluminium panels cut for all my panels, for now i like the industrial rust edge. this machine is going to make good noise so rust fits in with that theme _________________ problemchild
melbourne australia
seraph
Editor
Audio files: 33
Posted: Fri Jul 18, 2008 12:34 am Post subject:
Luka wrote: |
so here is my rusty klee |
it looks like some ancient time machine hypnotic
_________________ homepage - blog - forum - youtube
Quote: | Don't die with your music still in you - Wayne Dyer |
Sound
Posted: Fri Jul 18, 2008 3:39 pm Post subject:
OH! Luka! Its amazing!
Please, could you upload a high resolution picture? I would like to look your klee more detailed!
Could you explain how you do your front panels a little bit?
Thanks! |
Luka
Posted: Fri Jul 18, 2008 5:40 pm Post subject:
ok, ill try find a camera (and ill chuck into this post)
Basically i found lots of sheets of 1mm steel which were rusty as hell (only surface rust and only slighty correoded on one side). i pulled out our angle grinder and cut it to measure a moog unit system. desinged the panel in photoshop ( i actually designed it for brass but i made it in rust to suffice for the moment but i think ill keep a whole cabinet in rust now )
drilled the holes with a drill press, and labeled it by hand with a sharpie. drilling wasnt too hard, it was a lot easier than i expected however i never had drilled much aluminium before this. after making some aluminium panels for other people i must say it is so malable and easy to work with
so then i added led bezels and some cheap knob that im using for my whole cabinet. now waiting for switches. (200 on the way) i hate waiting for international deliveries
i have an enitre rack near completion of modular done in rusty steel. i like it a lot. it is a good means of recycling, it looks a lot different to most people's modular systems, and it is so much fun using angle grinders and heavy metal tools it also has a industrial edge and seems fitting for a modular synth.
attached is my design, soon to come high res pictures if i find a camera
the rust has a really amazing natural corrosion patterns so ill put some time into take the photos right once i find a camera
Description: |
klee panel design, ive changes a few slight things when i drilled and marked the panel main differences are the position of the merge T&G, the colour of the LEDs, and that i wont be using push buttons for the inner row of switches (obviously the switc |
Filesize: |
77.51 KB |
Viewed: |
279 Time(s) |
melbourne australia
sduck
Posted: Fri Jul 18, 2008 8:03 pm Post subject:
Subject description: my klee, part 2 |
Ok, here's 2 pics of my ugly duckling klee in it's current state. Just a ton of wiring to do yet. I wanted to get a halfway decent pic as I'm off on vacation next week, and won't be able to work on the thing, and need a pic to keep my head in the game. I just threw the knobs on loosely for the picture - don't want to mess them up while soldering tons of wires on the back - but also wanted to have a feel for how the thing will look like completed, and so I could fulfill the instructions on the bottom of page 21.
Description: |
Filesize: |
1.49 MB |
Viewed: |
339 Time(s) |
Description: |
Filesize: |
1.53 MB |
Viewed: |
246 Time(s) |
Luka
Posted: Sat Jul 19, 2008 5:14 am Post subject:
Been looking at the panels guys and I continue to be amazed at the variations ....... great work to all !!!! I love it
Bill |
softfin
Joined: Oct 11, 2006 Posts: 271 Location: Far in the north
Rykhaard
Posted: Wed Jul 23, 2008 9:58 am Post subject:
Luka wrote: |
That panel looks WILD!! And it's JUST inspired me as well! Since I use wood for my panels, I'm going to search around / keep my eye open to see if I can find any flat BARK, in any type of wood. I love the look of yours extremely, especially in the Industrial (mechanical and musically) frame of mind! At the very least, for future art on my panels, I'm going to keep the 'industrial' in mind, pictures wise!
Now - the other reason for replying - 200 switches?? From WHERE? How much??? With all of the sequencers that I have planned at the moment (2 more Ray Wilson MFOS sequencer digital boards, just arrived in the mail - weeeee! ) I'm going to need at least 100 each of ON/ON and ON/OFF/ON switches. I'm looking for great priced sites.
Where are your 200 coming from and if eBay - please let me know when they arrive; how long they took to ship and their cost! |
