  bingsatellites Mostly Ambient
 Forum index » Instruments and Equipment » OSX as a music workstation
Help! My MacBook Pro is suffering from Arrested Development
Page 1 of 1 [23 Posts]
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 8:19 am    Post subject: Help! My MacBook Pro is suffering from Arrested Development
Subject description: Incoming network is spastic and Chuck makes snap, crackle and pop
So, as some people who helped me out almost a year ago when I bought this machine know, I bought a MacBook pro last year to have a second portable machine for some electro-music applications, as a backup and hopefully a replacement for my lead weight, so called "portable" Alienware XP machine. In fact I bought 3 Macs last year, but my daughter's iMac is with her in New Mexico, and my son's MacBook Pro is in Canada with him at audio school. I'd like to have his at hand to compare with my problems, because he runs ProTools and other audio processing stuff on it, but he's not here.
Anyway, problem number 1 is incoming network traffic often has a terrible case of the slows. I've eliminated the wireless LAN by using wired, and it's not just the web. The XP machines in the house do fine on the web, and moreover -- and this is the important part -- I have a distributed music program I am working on that sends OSC-on-UDP datagrams around, at pretty coarse time granularity. Packets going out of the Macbook to the XP machines arrive at good speed, but the packets coming back to the Mac seem to take forever to get into the Mac and get processed, regardless of whether it is using the wireless or wired LAN. A crappy old Dell laptop that I have performs much better than the MacBook on receiving and using this incoming UDP-LAN traffic. So the consistent symptom here is very slow incoming network traffic, both with LAN-only-musical traffic and web traffic, and it's not tied to either the wireless or wired Ethernet hardware.
I can't find any place in the mac on-line UIs that let me monitor or try to fix the problem. Any suggestions? I've used Ethereal and other traffic analysis tools for years, but I don't see where OSx even gives me a way to look at the problem.
The other problem is that I tested a ChucK application that works fine on the Alienware machine on the MacBook, and on the Mac I get a lot of crackly noise that I don't get on the Alienware. Same Edirol sound box, same sampling rate. I tried playing with the buffers sizes, and also tried the Mac's built-in sound card, on the chance that the Mac Edirol driver is goofy, but still have the crackles. The machines are on par CPU and memory wise, about 3.5 GHz and 2 MB ram, and run the ChucK app in the mix with about a 30% CPU load, which should be fine.
There is something goofy with this machine, so that it winds up almost exclusively being used by my wife and visitors for email and web browsing, which is a big disappointment to me. Any suggestions on how to attack the problem? Thanks.
EDIT: Should have said 2 GB RAM.
"Time is a ruler across the knuckles of eternity."
Dale Parson
"Just say no."
Nancy Reagan
Last edited by Acoustic Interloper on Fri Jul 18, 2008 11:19 am; edited 1 time in total
BobTheDog
PostPosted: Fri Jul 18, 2008 10:02 am    Post subject: Reply with quote  Mark this post and the followings unread
My MacBook Pro uses large amounts of cpu when it has a high network load, up to 80% cpu can be used copying a file to the MacBook over gigabit. I have never worked out why. Apparently they are not meant to.
You can get ethereal using macport http://www.macports.org/ first of all though I would do a simple test of copying a file to the macbook and having a look see if you suffer from the same cpu issue that I do although your issue sounds like it may be a bit different.
I don't know about the edirol device (is it usb?) but the core drivers for the onboard audio are bloody awful, they are real cpu hogs, my RME drivers use 50% of the cpu than the onboard drivers!
Definitely some developers code runs very badly on intel based macs, NI stuff tends to use twice the amount of cpu running on OS X as when running XP on my MacBook pro. I Don' know why, code I have written and benchmarked runs slightly slower under OS X, but not much.
Andy
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
I'll give it a try, thanks.
The Edirol is USB, no hub, and the CPU load looks no worse than the Alienware XP machine. The OSC/UDP datagrams are quite small, 1000 bytes or so, and only 3 of them arrive after a player has made a move at distributed musical chess on a Python/Tkinter GUI running on the Mac, but it takes forever for them to come back. It's very strange -- a player moves a piece on the Mac, a small-data XML/RPC call gets made to the Alienware machine serving the game and normally running ChucK, you hear the sound change immediately, but it takes forever for the Mac display to update as the result of the 3 return UDP datagrams that describe the new board state. I would have thought the outgoing XML/RPC woul have been the bottleneck if anything would, because of all the added XML roughage. In the original design I also used XML/RPC for the return trip describing the board state, but after this slowness, I decided to try UDP in order to reduce the volume of return network data. The UDP is all packed binary fields with minimal size, unlike XML. This made no difference to the Mac at all; the XP return path seems to suffer from fewer dropouts using UDP than it did from XML/RPC, which is atop TCP, which is supposed to be more relaible than UDP. HA!
I have played with some CPU intensive home benchmarks that show the Mac beating my Alienware. It smells like a synchronization problem, maybe the packet is getting in but not getting handed to a thread in a timely fashion. EDIT: If they have a polling loop deep down in the O.S., that would account for incoming slowness and a CPU jump. Man, would that suck.
1982 was the last time I took a UNIX admin course Exclamation I studiously avoid that kind of thing, but I may have to go digging into low level UNIX land before I am done with this. OSX, look out Exclamation
Thanks again.
Dale Parson
"Just say no."
Nancy Reagan
BobTheDog
PostPosted: Fri Jul 18, 2008 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
The UDP stuff sounds very strange, when I first read your last post I thought it may be a Nagel problem but this would only add 200ms per packet, what sort of delay are you seeing?
If it is a Nagel problem this will be caused by your sending code, the socket options should be set up with TCP_NODELAY when using small packets like this. Or you should pad out the data sent a bit to a couple of KB, networking is one of the few fields where sending more data can be quicker, especially under microsoft operating systems.
Audio files: 116
G2 patch files: 317
PostPosted: Fri Jul 18, 2008 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nagle Rolling Eyes
But can it even be used for UDP, don't think so ... anyway, a network sniffer might give some info about where the delays occur. (for windows I use Ethersnoop, not ideal but useful).
PostPosted: Fri Jul 18, 2008 12:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Have you checked you serial number with Apple Support? At least over here in Norway we have seen some MBPs and MBs with serious networking issues. THis is a hardware issue.
Flickr
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
The delay runs anywhere from 10 to 30 seconds. It's horrible. The UDP datagrams are being sent from an XP Alienware machine, and if I put a Dell receiver and the Mac receiver side-by-side, the Dell updates its chess display from the UDP datagram "immediately" (from a user perspective), while the Mac takes at least 10 seconds. So this problem can't be the sending side, since the UDP datagrams are obviously getting out.
Dale Parson
"Just say no."
Nancy Reagan
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 12:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks. I only started looking at this seriously when I ported the chess program to OSX. EM2008 deadline. Deadlines are always good for forcing problems to the surface. I'll chec on the number.
Dale Parson
"Just say no."
Nancy Reagan
PostPosted: Fri Jul 18, 2008 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did you do this:
Restart MacBookPro, then press Option-Command-p-r until you hear two start up beeps ?
That´s the NVRAM reset.
Flickr
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 1:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just looked up Nagle. It wouldn't affect the UDP datagrams carrying the game state, since Nagle is TCP, but, if a player makes a move from the Mac, the UDP datagrams showing the board state are preceded by an XML-RPC-over-TCP calls to make the move and if the XML-RPC return value comes back slowly, the display thread in the Mac won't process the UDP datagram until *after* it gets the XML-RPC-TCP response. I'll give TCP_NODELAY a try on *that* connection.
Dale Parson
"Just say no."
Nancy Reagan
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
Did you do this:
Is it safe to do? I would imagine so, but this is one of those "Are you sure?" messages!
Dale Parson
"Just say no."
Nancy Reagan
PostPosted: Fri Jul 18, 2008 1:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes, quite safe. Well, unless you have been setting some stuff yourself to the NVRAM and such and you wouldn´t like to have that flushed.. but that I doubt.. Very Happy
The reset is quite OK. You might have to tweak some basic system parameters again.. but those are never of the dangerous or fatal kind.
Trust me. Do it! Very Happy
Flickr
Acoustic Interloper
Audio files: 26
PostPosted: Fri Jul 18, 2008 2:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Did the Option-Command-p-r, didn't hurt anything Very Happy Still gotta check on that serial number, but
Given the fact that the protocol is:
1. Chess GUI client sends and XML/RPC/TCP call to game server,
2. Game server replies with XML/RPC/TCP result
3. Game server sends individual UDP display updates to all subscribed GUI clients, 1 at a time (I plan to switch to broadcast later)
I set two machines as gui clients of the alienware games server, the mac and a dell, side by side, and took turns making moves from the mac and dell.
When I move from the mac, the dell display updates fast, the mac slow.
When I move from the dell, both the mac and dell update fast.
So, it appears that the mac is not sending out the XML/RPC/TCP call right away. (EDIT: No, that can't be it, otherwise the server wouldn't get the move from the Mac. It's gotta be that the Aleinware responds faster to the Dell than the Mac with the XMLRPC response for some reason!) When the mac does not get involved in making an XML/RPC/TCP call, it is as fast as the dell. The slows have nothing to do with the UDP display update datagrams.
Have not found a way to config a TCP_NODELAY on an XML/RPC client, but I did find this:
Nagling: by default, sockets in unix try to bunch up data into larger packets, to avoid congestion problems. This can result in delays in sending XMLRPC requests. Smart implementations of XMLRPC set TCP_NODELAY (or TCP_CORK); for example, Xmlrpc-C does this. The python xmlrpclib does not. Ultimately the workaround is to submit a patch for xmlrpclib.py to turn on TCP_NODELAY for the socket, or otherwise flush the socket.
I am using Python xmlrpclib, and so far I see no evidence that this was fixed. The above was written last month!!! xmlrpclib hides the underlying socket; haven't found it yet.
So, I guess the options are to shove some extra long parameter into the XML/RPC calls and return value, or else rewrite from XML/RPC to something else, probably UDP. Grumble, grumble. Rolling my own RCP-over-UDP won't be so bad in Python, since I can just pass the whole thing as a string and "eval()" it on the other side. It would be nice if reuse was so simple as to actually work.
Thanks for the help!
Dale Parson
"Just say no."
Nancy Reagan
BobTheDog
PostPosted: Sat Jul 19, 2008 1:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Nagle Rolling Eyes
No it isn't, thats why I was confused!
The misspelling is of course just stupidity Embarassed
Andy
BobTheDog
PostPosted: Sat Jul 19, 2008 1:16 am    Post subject: Reply with quote  Mark this post and the followings unread
10-30 seconds looks like it may be a retransmit problem, maybe a sniffer is the way to go on this.
Acoustic Interloper
Audio files: 26
PostPosted: Sat Jul 19, 2008 1:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
The chess game problem was definitely in the XML-RPC/TCP code, could have been Nagel inside of Python's XML-RPC library (where I can't get at the socket to TCP_NODELAY it), or it could have been problems with Python's XML-RPC library on the Mac. I just rewrote it to get rid of XML-RPC and am using all UDP datagrams instead. Occasionally a UDP datagram gets lost, but clicking the "redisplay" button widget fixes that. Good enough for EM2008.
Apparently my other mac issues are unrelated to this, unless they are TCP generic problems. But that Python XML-RPC library is certainly suspect.
Now, my fast Alienware machine has developed a vertical scar in its display. Had the video card replaced about a year ago. Hope this one isn't dying. Why must these things happen right before I finally get out of the house to play something? Looks like I better hurry up and port the rest of my stuff to the Mac laptop. I may be back with more questions Surprised
I think one reason that people get into the this-OS-camp vs. that-OS-camp is not the OS, but because the apps don't exist or they are hard to port or the libraries work one way on one platform and another way on another. So, once you get used to the pains of your favorite platform, you are loathe to change. I don't have a favorite any more. I'd like a small footprint RTOS with a lot of DSPs on the side, with all the MSP/ChucK/SC libraries available on those DSPs. Of course, I also like to write software that other people can use, so I guess that leaves out special platforms.
I'm going to spend the evening restringing 2 banjos and 2 Appalachian dulcimers. Maybe I can even con my wife into playing one of those.
Thanks for your help!
Dale Parson
"Just say no."
Nancy Reagan
BobTheDog
PostPosted: Sat Jul 19, 2008 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I work on code that has to run on Irix, various Linux dists (32 and 64 bit versions), XP and 2003 server (32 and 64 bit versions) also covering little and big endian architecture, running over multiple processors and in clustered environments.
I have begun to hate all computers and operating systems!
Acoustic Interloper
Audio files: 26
PostPosted: Tue Jul 22, 2008 11:32 am    Post subject: Re: Help! My MacBook Pro is suffering from Arrested Development
The other problem is that I tested a ChucK application that works fine on the Alienware machine on the MacBook, and on the Mac I get a lot of crackly noise that I don't get on the Alienware. Same Edirol sound box, same sampling rate. I tried playing with the buffers sizes, and also tried the Mac's built-in sound card, on the chance that the Mac Edirol driver is goofy, but still have the crackles. The machines are on par CPU and memory wise, about 3.5 GHz and 2 GB ram, and run the ChucK app in the mix with about a 30% CPU load, which should be fine.
Healed this one by using a combination of ChucK's blocking configuration, an undocumented command line arg (at least I haven't found documentation for it), with expanded buffersize, which I had tried without blocking before. I assume blocking waits until the output audio buffer is flushed before continuing. These adjustments probably add latency, but for the chess game-to-music this does not matter, since the temporal correlation of a chess move to music changes is not near as tight as banjo finger picking speed.
Next I have to rewrite a MIDI foot controller-driven state machine from Tcl+a custom MIDI library to ChucK to get it to work on Mac, and I think I'll be set for EM2008.
No common thread to these problems, other than that porting is a pain. At least I am getting some time with my Mac. Razz
Dale Parson
"Just say no."
Nancy Reagan
Acoustic Interloper
Audio files: 26
PostPosted: Wed Jul 23, 2008 1:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a cute portability problem:
$ python
Python 2.4.4 (#71, Oct 18 2006, 08:34:43) [MSC v.1310 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import time
>>> help("time.clock")
Help on built-in function clock in time:
time.clock = clock(...)
clock() -> floating point number
Return the CPU time or real time since the start of the process or since
the first call to clock(). This has as much precision as the system
records.
CPU time or wall clock time Shocked Now there's a handy time bomb, so to speak. Almost needless to say, it works one way on XP, and the other on OSX.
Dale Parson
"Just say no."
Nancy Reagan
Audio files: 116
G2 patch files: 317
PostPosted: Wed Jul 23, 2008 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
http://www.daniweb.com/code/snippet218.html suggests that time.time() might be more compatible.
Acoustic Interloper
Audio files: 26
PostPosted: Wed Jul 23, 2008 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, yep, that's what I started using yesterday. That may be vulnerable to the Unix Millennium bug, but it should be OK for the chess game.
Dale Parson
"Just say no."
Nancy Reagan
Audio files: 116
G2 patch files: 317
PostPosted: Wed Jul 23, 2008 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
All my embedded code has the 2038 limit, but hell, I'd be over 80 years old by that time Shocked Dunno all my devices are built with a life expectancy of 10 years and they don't have to deal with time beyond "tomorrow". Long before the date gets to be a problem the eeproms and flash memories will be worn out and obsolete.
BobTheDog
PostPosted: Thu Jul 24, 2008 2:10 am    Post subject: Reply with quote  Mark this post and the followings unread
You could always use the Hi resolution timers.
Windows - QueryPerformanceCounter()
Unix/linux etc - clock_gettime()
You should be able to get at these somehow, c++ code :
Code:
#ifndef  HiResTimer_H
#define HiResTimer_H
#include "HLMObject.h"
#ifdef WIN32
#include "windows.h"
#else
#include <stdio>
#include <time>
#include <errno>
#define NUM_NANO 1000000000
#endif
//inline HI Resolution timer
namespace SMG
namespace HLM
class HiResTimer  : public HLMObject
 public:
  HiResTimer()
#ifdef WIN32
      m_bInitialised = (QueryPerformanceFrequency( (LARGE_INTEGER *)&m_Frequency ) != 0);
      start();
#else
      if (clock_getres(CLOCK_THREAD_CPUTIME_ID, &tRes))
            LOG(HLM::Log::ssHLM, HLM::Log::llVerbose, "Problem getting the timer resolution. System errno: %d \n", oserror());
         else
            m_bInitialised = 1;
      start();
#endif
  virtual ~HiResTimer()
  void start(void)
#ifdef WIN32
      QueryPerformanceCounter( (LARGE_INTEGER *)&m_Time );
#else
      if (clock_gettime(CLOCK_THREAD_CPUTIME_ID, &tStart))
         LOG(HLM::Log::ssHLM, HLM::Log::llVerbose, "Problem getting the timer information. System errno: %d \n", oserror());
#endif
   float getElapsedMS(void)
#ifdef WIN32
      if (m_bInitialised)
            m_LastTime = m_Time;
            m_ElapsedTime = m_Time - m_LastTime;
            return ((float)m_ElapsedTime / (float)m_Frequency)  * 1000.0f;
      else
            return (0.0f);
#else
      if (m_bInitialised)
            if (clock_gettime(CLOCK_THREAD_CPUTIME_ID, &tEnd))
            long temp1 = (tEnd.tv_sec - tStart.tv_sec );
            long temp2 = (tEnd.tv_nsec - tStart.tv_nsec );
            start();
            return  ((float)(temp1 * NUM_NANO) + temp2) / 1000000;
         else
            return(0.0f);
#endif
   float getElapsedSecs(void)
#ifdef WIN32
      if (m_bInitialised)
         return ((float)m_ElapsedTime / (float)m_Frequency);
    else
         return (0.0f);
#else
   if (m_bInitialised)
      start();
      return ((float)(temp1 * NUM_NANO) + temp2) / NUM_NANO;
   else
      return(0.0f);
#endif
private:
  bool   m_bInitialised;
#ifdef WIN32
  __int64 m_Frequency;
  __int64 m_Time;
  __int64 m_LastTime;
  __int64 m_ElapsedTime;
#else
  timespec tStart;
  timespec tEnd;
  timespec tRes;
#endif
#endif
emSynth
