  bingsatellites Mostly Ambient
Where does this wire go?
Page 1 of 1 [4 Posts]
noiseofthecondor
PostPosted: Sat Jul 26, 2008 11:20 am    Post subject: Where does this wire go?
Subject description: Looking for some wiring help Sequential Switch
Hi. New here to this forum, and to module construction as well. I am writing for some wiring help and advice for the Ken Stone CGS28 Sequential Switch. I can solder well and do the 'paint by numbers' part, but I am ready to start wiring and I can tell I have options, but it isn't extremely clear how to proceed from here. I need some dummy directions basically. A few things weren't obvious to me.
Here is what I am attempting to end up with: I plan on using mostly audio signals, not necessarily only cv's for this unit. I also plan on using this unit like a sequencer. I am currently using the Blacet PS500 for power supply with a 4-pin connector, which I use with my Ken Stone Matrix Mixer (can I just say bad-ass). Space is of no concern to me as big knobs and 1/4" jacks are preferred.
So here are some of my (admittedly probably dumb) questions to start:
What size pots should I be using for the input attenuators, and the Mix attenuator?
For the gate outputs there are 2 points to solder, it doesn't seems to make a difference which one I use, so what is that extra intended for?
What, if anything, is getting wired to the -0.6V solder points?
Thanks for any and all of your help in this! I am certainly enjoying the site and forum and figured this would be a great place to start. I'll soon be posting a few questions for the Pulse Divider/ Boolean Logic PCB as well, since it is ready for wiring too.
otherunicorn
PostPosted: Sat Jul 26, 2008 5:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
1) 100k Lin for the pots.
2) >For the gate outputs there are 2 points to solder, it doesn't seems to make a difference which one I use, so what is that extra intended for?
It's just a spare if you need it for some reason or another.
3) >What, if anything, is getting wired to the -0.6V solder points?
Nothing else gets wired to them. They are identified on the board in case you need to check them with a meter. It saves a lot of hunting around.
Ken
http://www.cgs.synth.net/
neandrewthal
PostPosted: Sat Jul 26, 2008 8:11 pm    Post subject: Re: Where does this wire go?
I would strongly recommend wiring these to the reset input through a rotary switch to act as a number of steps selector if you aren't already.
noiseofthecondor
PostPosted: Sun Jul 27, 2008 6:36 am    Post subject: Looking for some wiring help Sequential Switch
Subject description: Re: Where does this wire go?
Thank you Ken and thank you Neandrewthal for your help. I will give this a shot.
AmbiphonicDSP
