CGS-34 Analog Shift Register
Page 1 of 1 [19 Posts]
funkyfarm
PostPosted: Sat Jul 26, 2008 7:32 pm    Post subject: CGS-34 Analog Shift Register
Subject description: uses
I'm sure i've put 1% resistors where needed, but i've always been disappointing when it come to drive several VCO with this "cv delay"... (fed by 1v/oct keyboard)
theoretically, can we use it with a LFO, in order to get "quadrature" waveform, or something ala ThreePhase LFO ?
how do you use it ?
http://www.cgs.synth.net/modules/cgs34_asr.html
andrewF
PostPosted: Mon Jul 28, 2008 4:32 am    Post subject: Reply with quote  Mark this post and the followings unread
I usually use two in series with the 3rd output of one module connected to the input of the other. All the stage outputs go to VCOs and VCFs
have you read Serge's suggestions for using the ASR?
http://www.cyndustries.com/synapse/synapse.cfm?pc=35&folder=sept1976&pic=19
and
http://www.cyndustries.com/synapse/synapse.cfm?pc=35&folder=sept1976&pic=20
The circuit design is not the same as the CGS but the functionality is basically the same.
ericcoleridge
PostPosted: Tue Jul 29, 2008 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I feed the CV Input of the ASR a S+H signal, then take the 3 outputs and feed them into a mixer, and use the mixer output to control a VCO. Or I may take some of the mixer output and feed it back into the S+H input.
Creates very interesting semi-random melodic patterns. It's fun and a different way and outcome from a straightforward S+H.
bearblock
PostPosted: Tue Jul 29, 2008 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
i also had some trouble getting my ASR to track accurately enough for melodic stuff... and i used 0.1% resistors. ended up having to install some trim pots around the input amp, now it's much better. my guess would be that the output impedance of my midi-cv converter isn't what the circuit expects to see? haven't done any math to back that up though.
in theory, but you would need more than 3 stages, like 100 or so Wink
funkyfarm
PostPosted: Sun Aug 03, 2008 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
maybe i should do that too.
3 stages, three outputs, no ?
0°, 120° and 240°
hmm, semi-random melodic patterns...i'll try, but i used to see this module in a funny tempered echo/arpeggiator style...maybe i'll have to run outputs trough the oncoming quad cv quantizer...
http://electro-music.com/forum/topic-21931.html
ericcoleridge
PostPosted: Sun Aug 03, 2008 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I don't have enough audio generators yet to try out the echo-like effects as described in the Synapse Serge ASR/arabesque generator article. But I have seen ASRs used in a lot of Buchla, and others, random voltage generators. Check out Marc Verbos's DIY page, and other places, for the Source of Uncertainty schems. That's where I sort of got the idea of mixing the various ASR outputs and using them for CV.
What? Is this really oncoming? I really hope so.
Sine
PostPosted: Wed Aug 06, 2008 6:18 pm    Post subject: Re: CGS-34 Analog Shift Register
Yeah, I had the same problem, when you drive three VCO's them
when you hit the same note four times, tune the vco's and hit the note a fifth time the whole thing jumps out of tune.
Feed it with a constant voltage and clock it with an LFO, then plug a scope in the output and don't be surprised to see something that resembles a staircase.
I went as far as to use CA3140's for the buffer amps, add balance pots for them and select the resistors, that improved it somewhat but the real problem seems to be the 4052's the switches aren't perfect and the voltage drop seems to vary per switch, I ordered a few of them from other brands but I didn't have the time to test them yet.
Also as Ken states this thing is *VERY* sensitive about power line noise, I thought it would be neat to add a few LEDs to the output of the counter to be able to see the steps, bad idea !
I'll swap the muxes tomorrow and let you know how it turns out.
bearblock
PostPosted: Thu Aug 07, 2008 1:31 am    Post subject: Reply with quote  Mark this post and the followings unread
0°, 120° and 240°
no.
the ASR really isn't a "cv delay" in the sense you are thinking. it's more like an multi-stage sample and hold, and sample and hold circuits will mangle any waveform you put through them, unless the sampling rate is a lot higher than the input frequency. with such a fast clock you would need a lot of stages to create more than a couple of degrees of phase shift; you would end up with something like the BBD chips used in old chorus/delay effects.
edit: check out the diagrams on this page http://www.ear-group.net/model_23.html
funkyfarm
PostPosted: Thu Aug 07, 2008 2:50 am    Post subject: Re: CGS-34 Analog Shift Register
I knew I missed something, so my question !
for me, a S&H (without noise) produces some sort of a stepped version of the input.
Sine
PostPosted: Thu Aug 07, 2008 8:11 am    Post subject: Re: CGS-34 Analog Shift Register
As promised I tested the module with a few different muxes :
The module with balance pots for the 3140's
The upper trace is the second output, the lower trace the third
Fairchild muxes :
Motorola :
TI
So these switches are definitely the cause, I have a few DG switches laying around from another project, maybe I'll try something with those.
bearblock
PostPosted: Thu Aug 07, 2008 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
funkyfarm: did you look at the link?
if you still don't understand, i give up.
funkyfarm
PostPosted: Thu Aug 07, 2008 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool
I understand here "mangle" as stepping waveforms.
I've listened to samples : for sure my ASR doesn't behave like Model23...which makes me sad.
most would have given up before !)
funkyfarm
PostPosted: Thu Aug 07, 2008 8:45 am    Post subject: Re: CGS-34 Analog Shift Register
Sine wrote:
The module with balance pots for the 3140's.
3140 are used for OUTPUT buffers ? TL074a TL074b TL074c
you're post is amazing !
but you can't swap 4052 for some DG ?!...saying that you still got a lot of blank space on breadboard Smile
Sine
PostPosted: Thu Aug 07, 2008 9:24 am    Post subject: Re: CGS-34 Analog Shift Register
The output indeed is a 074, I used ca3140's for the sample and hold buffers, they have a very high input impedance ( 1.5T ohms (!) ) so It doesn't drain the sample caps as much when using long sample times.
Jup, basically that would be redesigning the whole thing because the DG switches can handle +- 15V so the divider / doubler setup in the ASR isn't really necessary anymore.
I think I'll try the module in It's current form, if it still varys too much to my taste I might try the DG's, after all the biggest difference is about 10mV with the Fairchild muxes.
neandrewthal
PostPosted: Mon Aug 11, 2008 9:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I just read this from Ken's site:
"Being a CV processor, this module requires nice clean power rails. Initially mine was exhibiting slight stepped voltage shifts (resulting in pitch shifts). I traced these to the mass of flashing LEDs in the next module - a module that should have been connected to my "dirty" power supply."
I have my heart set on having it on the same panel as my pulse dividers/boolean logic/digital noise with 14 LEDs Mad It's really the only place I can fit it in my first cabinet at this point and I really want one in each cabinet. Is there anything I can do besides getting a second power supply? Does it help that my power supply is a rock solid power one 5A or does that even make a difference in this situation? Thanks.
Sine
PostPosted: Tue Aug 12, 2008 1:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, It is VERY sensitive to powerline noise, I had some LED's on the module and disconnecting them visually affected the output.
neandrewthal
PostPosted: Tue Aug 12, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
What If I gave it it's own power line. Directly from the power supply. Would that help?
ChrisCoady
PostPosted: Thu Apr 07, 2011 12:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey guys,
I've finished building a pair of ASRs and they sounds great and scale nicely.
When they are recieving a constant voltage and outputting a steady tone there is a wobbling in the frequency though.
In Kens build docs he says:
Connect a constant voltage to the input. Connect one output to a VCO and the Clock input to an LFO or clock running at a few hertz. You should get a constant tone. If there is a stepped warble, one of your ICs has a different offset to the others. You can work out which chip it is by holding your finger on the pins of each chip in turn. Swap the affected chip for another. Repeat if needed until you get a constant tone. I have only had this happen with LM3140/CA3140 chips.
I touch the ICs and I hear a stepping tone but I'm not sure how to identify the bad chip(s). Has anyone experienced this and been able to narrow them down? I am just not sure what to listen for.
Thanks in advance,
Chris Coady
Adam-V
PostPosted: Thu Apr 07, 2011 10:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mine does the same thing. I just live with it!
Not much help to you though...
Adam-V
