  bingsatellites Mostly Ambient
Gated comparator pesky LED
Page 1 of 1 [4 Posts]
neandrewthal
PostPosted: Sun Aug 10, 2008 9:41 pm    Post subject: Gated comparator pesky LED
Subject description: Bugger won't light
My gated comparator is working 100% except the LED for the second shifted output. This is odd, as the gate for that stage passes right through the LED and out the jack perfectly, yet it won't light. I made sure it was connected properly(and even lit it up) with my multimeter. I changed it with a new one and still, nothing. What could be wrong Confused Thanks.
andrewF
PostPosted: Sun Aug 10, 2008 10:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sounds interesting.
If it doesn't light up but you still get a gate signal, maybe there isn't enough current passing thru.
check the resistor values (don't trust the markings), with a multimeter. Check 2k2 is properly connected to ground and finally consider replacing the transistor.
neandrewthal
PostPosted: Sun Aug 10, 2008 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Aye! A flaky(literally) solder pad t'was. Bridged it with a wire and she's right as rain. Thank ye kindley!
andrewF
PostPosted: Sun Aug 10, 2008 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Good
enjoy the gated comp - it is great for triggering drum modules
emSynth
