G2 midi question
Page 1 of 1 [5 Posts]
wildbill
PostPosted: Mon Sep 06, 2004 6:54 pm    Post subject: G2 midi question Reply with quote  Mark this post and the followings unread
anyone know if you can get the G2 to send midi out thru its usb port?
i'm trying to use it to control softsynths in a laptop that has a usb port, but no midi connector.
or would it be simpler to try and find something that has a usb connection on the computer end and a midi connector on the G2 end?
thanks
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Mon Sep 06, 2004 10:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Unfortunately you can't Sad
It would be a nice touch though! If it was firewire you could also run a huge number of audio streams between the computer and G2... A modular midi and audio interface with immense dsp power Smile perhaps the G3 engine?
PostPosted: Tue Sep 07, 2004 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Even USB should handle 4ins, 4outs, programming, and MIDI! Though maybe not at 24/96k rates:(
It would be cool to have a VST "nord" plugin that ghave you access to the hardware! Exclamation
wildbill
PostPosted: Tue Sep 07, 2004 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok: let me phrase this another way:
on the Clavia site, they show a G2 controlling softsynths and have some templates that you can download to do it.
if the G2 has midi and your laptop has only usb, how do you go about it?
PostPosted: Tue Sep 07, 2004 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
At this point, that's your best answer.
