bubblechamber
Posted: Mon Aug 25, 2008 2:53 pm Post subject:
SDS3 Single Voice PCB Run |
It looks like there is a fair amount of interest in a run of professionally produced PCB for the SDS3 project. Here is an outline of this project:
This is a single voice of the SDS3. Each voice card will have both noise and an LFO on each card.
This is an accurate clone going off the original schematics. There are no substitutions or changes, other than allowing a little more flexibility in the modulation and noise routing.
There will be an external Noise and LFO input per card. This way you can use a single noise genterator and a single LFO from one PCB for the rest of your SDS3 voices. This will allow it to work as the original did, with a single noise generator and LFO shared among all the voices.
The PCB will be around 100mm x 100mm, small enough to fit into a eurorack panel, and Frac too, i think. someone might want to clear up the clearence between the rails of a frac case. i think it's around 4.5 inches, but i could be wrong.
there are no PCB mounted jacks, pots or switches.
right now we're looking at around $8US/PCB,but that can change as the orders increase.
I'll be going through MyroPCB, I've dealt with them several times. They do great work, it's pretty fast and reasonable.
Soldermasks can be any color we want, within reason, so your suggestions are welcome.
I've pretty much finished the initial layout, I will be spending the next week or 2 checking it over and etching a couple of prototypes. I'll post the progress and samples as I get it done.
Once I get this finalized I will be posting a P'nP layout and docs in the PCB section for anyone that wants to roll their own.
I'm looking to get the layout finished, tested and ordered by middle September, so we're looking at early October for shipping.
If anyone has an SDS3 and would like to help with the Beta phase of this project, please get in touch with me.
I'm sure i'm leaving lots out here, if there are any questions feel free to contact me directly or post them here. I'm really looking forward to this and i'm very grateful to all of the members here who have gently reminded me to get on this when I got a little distracted at the beginning of this project.
david _________________ You can check your anatomy all you want, and even though there may be normal variation, when it comes right down to it, this far inside the head it all looks the same. |
Posted: Mon Aug 25, 2008 3:07 pm Post subject:
holla hopsasa! that's great news. i had no idea you're so far in the process. wonderful.
so i am definitely in for four (4!) PCBs. _________________
Tech Buddy at Random*Source |
bugfight
Joined: Aug 02, 2007 Posts: 188 Location: Arlington, TX USA
Posted: Mon Aug 25, 2008 3:30 pm Post subject:
in for 4 |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Mon Aug 25, 2008 5:33 pm Post subject:
At that price, I would be in for 4 as well. |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Mon Aug 25, 2008 6:16 pm Post subject:
Thanks for doing this- you know I need four.
BTW, I wanted to publicly thank David for being a good trader- we've been doing a little work and also exchanging parts- thanks for the opportunity and for the zero ohm "jumper" pack, the trannies, resistors, etching education, etc.
People are going to want to pay attention...'nuff said. _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
fluxmonkey
Posted: Mon Aug 25, 2008 6:46 pm Post subject:
wow. 4 for me, please & thank you!
bbob _________________ www.fluxmonkey.com |
endif
Floppy
Posted: Mon Aug 25, 2008 11:48 pm Post subject:
4 for me please. |
Luka
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Tue Aug 26, 2008 2:17 am Post subject:
8 please.
And i will try to get a picture off the sds3 front. |
b-funk
Posted: Tue Aug 26, 2008 2:26 am Post subject:
I´m in with 4 pcbs |
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Tue Aug 26, 2008 2:53 am Post subject:
Yesss!
If I can in any way afford it when they are ready, I'm in for some boards, but if not, I'd sure love to do a pnp later instead.
Thanks for doing this!
C _________________ Some Rubber Stamp Sound Effects - and other sound effects |
austrohungaro
Joined: Dec 23, 2006 Posts: 42 Location: Barcelona (Spain)
Posted: Tue Aug 26, 2008 3:32 am Post subject:
4 please.
color? white! |
Dego
Posted: Tue Aug 26, 2008 4:40 am Post subject:
I will take 4.
I think white would be nice as well! |
dar303
Posted: Tue Aug 26, 2008 5:46 am Post subject:
I pray to the mighty God Of The Giant Backlog to forgive me...
i'm in for 2! |
Statick
Posted: Tue Aug 26, 2008 6:40 am Post subject:
hi, i posted on the other SDS thread as well
i'll take 4 of the PCBs
i also have a real SDS 3 sitting here but i may have to give it back in a few days. |
fluxmonkey
Posted: Tue Aug 26, 2008 6:59 am Post subject:
Coriolis wrote: | If I can in any way afford it when they are ready, I'm in for some boards, but if not, I'd sure love to do a pnp later instead. |
C,
you might want to do the math on the real cost of etching your own PCBs. between the pnp film, bare board, etching chemicals, drillbit wear/breakage... and even assuming that your time has no value, i'd be surprised if you actually saved much doing your own.
unless, ov course, you can repurpose all that stuff from work...
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Tue Aug 26, 2008 7:21 am Post subject:
Must have 4.
Thanks for all the work on this!
bruce |
mono-poly
Posted: Tue Aug 26, 2008 7:58 am Post subject:
Yeah thanks so much! |
Ilanode
Posted: Tue Aug 26, 2008 8:08 am Post subject:
I'm in for 2. Thanks! |
Rykhaard
Posted: Tue Aug 26, 2008 9:12 am Post subject:
At $8/pcb or cheaper, count me in for 4 as well! Thanks for all of the work! |
Coriolis
Posted: Tue Aug 26, 2008 9:18 am Post subject:
Quote: | between the pnp film, bare board, etching chemicals |
Well, let me put it this way: I have all of the above materials in stock, and NO money, NO job right now, so time is...plentiful
But yeah, with just a little bit of cash on my hands, those boards are better bought than home-etched!
asafnetzer
Posted: Tue Aug 26, 2008 11:08 am Post subject:
I'm In for 4 pcb's
Thanks again
Asaf |
stijn
Joined: Jul 21, 2008 Posts: 39 Location: utrecht, netherlands
Posted: Tue Aug 26, 2008 12:28 pm Post subject:
great work man! I want 4 please. |
ericcoleridge
Posted: Tue Aug 26, 2008 12:43 pm Post subject:
At $8, I'm in for 4. Fantastic |
