  Twyndyllyngs Live - back after 3 weeks Chez Mosc
ARP Odyssey Filters
Page 1 of 2 [27 Posts]
Broadwave
Audio files: 6
PostPosted: Sat Sep 06, 2008 1:56 am    Post subject: ARP Odyssey Filters Reply with quote  Mark this post and the followings unread
Just a teaser Smile
The 4023 12db is on the right, the 4035 24db "Moog" is on the left.
I'll try and get the layouts up today for both filters. Again, like the Oddy VCO's I'm surprised that these two have been ignored for so long.
Yusynth has the 4072 LM3900 based filter on his site... go on collect the whole set - you know you want to Twisted Evil
Andy.
4023 & 4035 VCF's
 Filesize:  250.5 KB
 Viewed:  691 Time(s)
Synth DIY Projects
Musical Doodlings
rjd2
PostPosted: Sat Sep 06, 2008 5:48 am    Post subject: Reply with quote  Mark this post and the followings unread
sweet-these, im definitely building-i'll probably wait til tim's pcb's are done for vco's. hate to ask this, but do you have any docs/bom for the parts?
andy, how easy would it be to toss off the vca and eg circuits? Very Happy then we can all recreate a full on arp modular! thanks a ton for doing these, looking forward to this stuff.
Broadwave
Audio files: 6
PostPosted: Sat Sep 06, 2008 6:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
Ok, here's the PCB and component layout for the 4023 VCF, one or two things though...
The original TZ81/581 expo pair have been replaced with 2N3904/06 (perfectly acceptable subs), and the original 2N5172's are now 2N3904's (again, perfectly acceptable sub).
You will need to watch out when you insert the trannies, as I haven't changed the PCB foil from the original, so you'll have to twist the transistors a bit, as the originals had different pin-outs.
There are two fly leads (marked as blue on the pdf, ugly solution I know) and a wire link which is obscured somewhat by one of the 61.9k resistors - please don't forget these.
The only other change I made was for the CV summer, the original was an LM301 with compensation cap, I had none left so that's been replaced with a TL071 (you can also replace the other two 301's with the TL071, but remember to remove the 33pf caps... In fact, the VCF will probably sound better using TL0's).
I seriously like this filter, I know everyone goes on about 24db Moog VCF's and how fabulously powerful they are, but this cuts through anything, it's a real sizzler - but be carefull when you crank up the resonance, as there's no gain compensation... I don't want you to blow your speakers Smile
I'll get a BOM and samples up for everything when I've slept... been awake now for 36 hours... need... sleep... peaceful... sleep... ZZZZzzzz...
Andy
ARP 4023.pdf
ARP 4023 12db VCF
 Filename:  ARP 4023.pdf
 Filesize:  408.14 KB
 Downloaded:  1411 Time(s)
Synth DIY Projects
Musical Doodlings
Broadwave
Audio files: 6
PostPosted: Sat Sep 06, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi rjd2,
Unfortunately I have no other info on these VCF's (just a couple of very good friends who let me poke around inside their Oddy's - I just copied the PCB directly from the modules). It's seems that anyone who *does* have detailed info on these, tends to keep it to themselves Sad
You may get some useful info here:
http://www.till.com/arptech/40235/index.html
I tried to build it last year, unsuccessfully though, as I'm not too hot on double sided boards... but getting better! Smile
The Oddy VCA is dead simple, the AR/ADSR are both made from discrete trannies (there's a joke there... but I'm not biting!), and they, along with the Noise/S&H/LFO will be my next quest.
Andy.
Synth DIY Projects
Musical Doodlings
widdly
PostPosted: Sun Sep 07, 2008 7:06 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Just checked out your broadwave modular page....that things is AWESOME!
Peake
PostPosted: Sun Sep 07, 2008 7:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
You might wish (or might not wish) to check out the circuit with the 301 in place, for input overload characteristics, etc. That IC, IIRC, soft clips rather nicely, even though it's slow as hell.
There really isn't much to the Odyssey partswise, is there? Just a lot of pots and sliders..thanks for making these available.
Broadwave
Audio files: 6
PostPosted: Mon Sep 08, 2008 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Peake,
Just received a bunch of 301's - Yes, you're right it does clip rather nicely, and if you really push it, it sounds positively evil Smile
No, there's not much to the Oddy at all, apart from the occasional difficult to get part (a couple of dual FET's for the 24db VCF and S&H - 2 x 2N5459 work well - and the elusive 2N5910 in the VCO's).
Apart from that, it's all hardware - I'd love to rebuild everything with sliders, but I've not found a decent and tidy way to cut slots into Aluminum.
Andy.
Synth DIY Projects
Musical Doodlings
rjd2
PostPosted: Mon Sep 08, 2008 5:59 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry to ask for even more info when you have already provided so much, but do you have a similar pdf for the 4035 filter? no rush, im not ready to move on this stuff right away; ive just been looking for months and months for arp cloned module info, so this is all great news to me!
Broadwave
Audio files: 6
PostPosted: Mon Sep 08, 2008 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi rj,
4035 details up soon, I noticed a bit of a boo-boo on the original board I made, just need a bit of time to correct it Smile
Andy.
Synth DIY Projects
Musical Doodlings
rjd2
PostPosted: Tue Sep 09, 2008 10:05 am    Post subject: Reply with quote  Mark this post and the followings unread
just wanted to make a comment on this whole arp thing, and why its really awesome to me....
i had wondered for the longest why noone had done a clone of the 4035 filter, which is in some monumental arp designs that i love the sound of. the answer i always got was " its the moog lawsuit filter, and peeople make moog filters, so just do one of those".
and yet, arps with this filter sound NOTHING LIKE MOOG INSTRUMENTS! (to me, at least). glad that im not the only yahoo who sees it this way....
brother303
PostPosted: Sat Jan 01, 2011 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
an old thread is coming up again... Smile
I got my board etched from a local pcb-service and now there is one question on the 3 trimmers on this pcb.
PDF is here... http://electro-music.com/forum/phpbb-files/arp_4023_163.pdf
What does the "CV-reject"trimmer do? And how to adjust it?
Is there any kind builder around here who would like to share his knowledge about the secrets of adjusting this? Hail the Master Please
Thanks and best regards
Greg
LektroiD
PostPosted: Mon Jan 03, 2011 3:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
This certainly looks like a great project, although I do have a query (and please excuse my ignorance here), but I don't see what the tempco is doing here, it's not thermally coupled to the transistors or anything, so surely it can be substituted with a fixed metal film (or similar)?
LektroiD
brother303
PostPosted: Tue Jan 04, 2011 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
LektroiD wrote:
...but I don't see what the tempco is doing here, it's not thermally coupled to the transistors or anything, so surely it can be substituted with a fixed metal film (or similar)?
Exactly what I think. I´ll try building this filter without tempco...and maybe add one later if really required.
Btw,any idea on the "cv-reject" trimmer and how to adjust it?
Greg
alcide
PostPosted: Wed Apr 10, 2013 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
I've spent some time now with the tremendous 4023, and have achieved some tones I was after for a very long time...I have, however, a question: at high frequencies (cutoff) when resonance is high, if I apply a lot of CV's, the filter produces short and uncontrollable screams (the resonance doesn't track anymore, and doesn't follow any enveloppe: just ultra high-pitched clicks). May it have something to do with LM301's weaknesses (i didn't select them, and only used one tl071 for cv-summing) / bad transistor matching ? Or is this a normal behaviour ?
(And thanks again, Andy, for your Ody-projects !)
isak
PostPosted: Fri Apr 12, 2013 2:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Andy.
The Tempco resistor is for keyboard tracking?
If I'm not interested in keyboard tracking can use regular 1% resistor?
If I use the tl071 instead lm301 you said to remove the 33pF caps, do I need to put jumpers instead?
Isak E.
Broadwave
Audio files: 6
PostPosted: Fri Apr 12, 2013 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
isak wrote:
Hi Andy.
The Tempco is mainly for frequency "stability" which is vital in a VCO, but not so much in a VCF, so it's ok to use a regular resistor.
Just remove the 33pf cap, no jumper required Smile
Synth DIY Projects
Musical Doodlings
Broadwave
Audio files: 6
PostPosted: Fri Apr 12, 2013 2:45 am    Post subject: Reply with quote  Mark this post and the followings unread
The 4023 will overload (not in a nice way) if the CV is to high - The ARP Odyssey is designed to keep the CV mixer levels within a certain range to avoid this happening. I think you probably just need to attenuate your CV's a little... or a lot Smile
Synth DIY Projects
Musical Doodlings
isak
PostPosted: Fri Apr 12, 2013 3:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank man Smile
alcide
PostPosted: Mon Apr 22, 2013 8:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Problem fixed ! I replaced the lm301's with TL071, and everything's fine now (maybe I should have selected, as required, the 301 ? But I don't know how to do it, and I don't care anymore, in fact: it sounds a LOT better, now, i must say (by modern standards, at least...)
Thanks !
The Real MC
PostPosted: Wed Apr 24, 2013 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
The 301 is an uncompensated opamp which required the right capacitor to prevent oscillation. That may had been the "squealing" you heard. 301s were also prone to latchups.
The TL071 that you substituted has internal compensation and that may have fixed the problem.
Could had been a bad cap or bad 301 opamp. ARP did have a selection process for the 301 opamps. The 301 offered that design flexibility of tailoring the compensation circuit towards the application circuit, but it was not without its thorns and in the long run the industry favored the internally compensated opamp.
paulstone
PostPosted: Wed Sep 25, 2013 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello guys
will the Jfet BF245B work instead of the 2N5459 ?
i have build one of this filter but no work
for build it i have use :
BF245B (soldered SGD with pin reversed) instead of The 2N5459
TL071 (both whitout 33p caps) instead of the LM301
Harris CA3080
Suggestion ?
thx
Paolo
Baloo
PostPosted: Wed Sep 24, 2014 2:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built this one but no sound at all ... Can anyone confirm this layout is working???
Sad
Broadwave
Audio files: 6
PostPosted: Tue Sep 30, 2014 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Sad
Sorry you seem to be having a problem Baloo, but I have two in my modular, fully working, using the layouts I posted here.
Have you checked that the transistors are orientated correctly (the pin outs are different from the original). Are your 3080's "genuine" there seems to be quite a few fakes out there! Have you inserted all the wire links?
If possible, can you send some hi rez (and in focus) pics of both sides of your board... I'll do what I can to help.
Andy
Baloo
PostPosted: Tue Sep 30, 2014 7:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a lot for your help Andy.
4023 is working perfectly. A bad cap replaced and it came to life.
thanks for sharing Wink
Now I will try the 4035 one but I've got not much experience with double faced PCBs...gonna make a try anyway.
Baloo
PostPosted: Tue Sep 30, 2014 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyone for a DIY Odyssey envelope generator layout ?? Rolling Eyes
