beginner question _ splitting keyboard
Page 1 of 1 [9 Posts]
okan
PostPosted: Sun Sep 14, 2008 12:41 pm    Post subject: beginner question _ splitting keyboard Reply with quote  Mark this post and the followings unread
hi,
sorry i guess its been asked before. but i couldn't find the topic.
how can i split the keyboard to create note zones and assign them to different osc's in one patch?
thanks for the reply,,
regards,
okan
istanbul
Audio files: 278
PostPosted: Sun Sep 14, 2008 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
You have keyboard zones and keyboard split on the keys verion of the G2, thes make it possible to split out keyboard ranges over slots see the manual pages 32 and 49 for these.
Then there is the note zone module which allows you to control different parts of a patch from different keyboard regions, there is an example on page 216 of the manual for that - the same example is in the editor help as well BTW.
And finally there is the note detect module, this module will react to only one particular note.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sun Sep 14, 2008 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
the link is correct but does not work inside [url][/url] maybe because is a .pdf
Audio files: 278
PostPosted: Sun Sep 14, 2008 3:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Think it's the parenthesis in the url ... thanks for telling I didn't reread after posting ... fixed it by using <a href="http://www.clavia.se/downloads/manuals/nord%20modular%20G2/nord%20modular%20G2%20V1.4%20(eng).pdf" target="_blank">manual</a> ... that construction usually works.
okan
PostPosted: Mon Sep 15, 2008 12:22 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i have the non-keyboard, rack version. midi notes comes from external midi keyboard into the g2. i have 2 osc's in a patch. i want to play one osc between the range c2-c3, and the another osc between c#3-c4 for example.
G2 patch files: 626
PostPosted: Mon Sep 15, 2008 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
move the xfade if you dont just want to switch oscillators Smile
2osc.pch2
 Filename:  2osc.pch2
 Filesize:  1.3 KB
 Downloaded:  1734 Time(s)
Roland Kuit
G2 patch files: 127
PostPosted: Mon Sep 15, 2008 9:57 am    Post subject:
Subject description: simple keyboard osc fade
do you mean this? (a simple one)
keyboard fade osc.pch2
simple keyboard split osc
 Filename:  keyboard fade osc.pch2
 Filesize:  1.31 KB
 Downloaded:  1522 Time(s)
okan
PostPosted: Mon Sep 15, 2008 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry i couldnt tell what i need exactly.
i want a typical "left-hand bass" "right-hand solo" split keyboard function. im lookin for a way to use every octave of my midi keyboard with different synth macro in one patch, (through the same midi channel). for example, one octave for the bass, one octave for pads, two octaves for drummin...
i guess g2ian's patch works for that thing. it would be good if it creates more than two note zones. xfade is ok for 2. but i can create another xfade formulas for every synth part. yes i guess it will work.
roland's solution leads me to another thing. it is working as a crossfader between osc's. this macro can be used between two different pad synths to create some atmos.
i will send if i finished a working patch.
thanks for reply,
regards,
Roland Kuit
G2 patch files: 127
PostPosted: Mon Sep 15, 2008 11:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi okan,
here a simple bass&chord pch.
i'm behind the demo software, so i can't send you an explaination with using midi modules(they aren't in the demo version). so, same trick.
