  bingsatellites Mostly Ambient
5-channel Attenuverting Mixer 2nd run
Page 3 of 9 [214 Posts]
PostPosted: Mon Aug 25, 2008 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
a.b.o.z. wrote:
fonik wrote:
sent out the first batch today. i don't have the time to PM everyone today. nevertheless everyone whos PCBs have been sent will receive a PM this weekend...
didn't get that PM. hmmm
I've sent payment. Did you get it?
Or you didn't had time to send PMs.
my fault. you are right, i did not have the time, yet, which is not what i wanted...
fonitronik at
Peake
PostPosted: Mon Aug 25, 2008 9:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you very much!! Your time and effort are appreciated!
a.b.o.z.
G2 patch files: 4
PostPosted: Mon Aug 25, 2008 11:21 am    Post subject: Reply with quote  Mark this post and the followings unread
hei no problemo at all.
thxn
Danno Gee Ray
PostPosted: Tue Aug 26, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Received my two boards today. They look great!
Thanks Mathias.
numbertalk
PostPosted: Tue Aug 26, 2008 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine too - thanks!!!
a_guy_called_tom
PostPosted: Wed Aug 27, 2008 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
mine arrived too, they look great. Thanks alot!
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Aug 28, 2008 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
got mine today.
great!!
thnx M.
ericcoleridge
PostPosted: Thu Aug 28, 2008 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also got mine today. Beautiful job. Very Happy
Peake
PostPosted: Thu Aug 28, 2008 5:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Received! Thank you very much! Very Happy
Edit: I don't see any 1% resistors indicated in the documetation. I'll thus take it that there are none required or recommended? That the trimpots negate the need? Thanks!
rjd2
PostPosted: Fri Aug 29, 2008 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
so ive got a question here, sorry to be daft about this, but need to confirm something...
do the individual input pots work like this: hard R=full gain, hard L=full gain inverted, 12 oclock=0 gain?
it just popped into my head that if i am reading this right, this would be a hugely utilitarian module for me down the line. if so, are there any spare boards available? thanks.
PostPosted: Fri Aug 29, 2008 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are absolutely right. BTW i am always using 1% resistors since they are not much more expensive at the store i buy them...
fonitronik at
PostPosted: Fri Aug 29, 2008 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
correct. the trimmers are needed to calibrate the 0V at 12 o'clock (potentiometers usualy have tolerances about 10-20%)
there are still PCBs left.
just tell me how many you need.
fonitronik at
rjd2
PostPosted: Fri Aug 29, 2008 7:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
question on caps-any of the values should be film or polystyrene or anything? im planning on using these as VCO summers, among other uses.
crashlander42
PostPosted: Sat Aug 30, 2008 2:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my boards today! They look great!
When they plug me in the lights go down in Hong Kong.
http://www.myspace.com/isaciongun
http://www.youtube.com/user/Crashlander42
My DIY stuff Flickr
PostPosted: Sat Aug 30, 2008 3:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
there are no capacitors in the audiopath. using poly for decoupling is a good choice, i think.
fonitronik at
Fungitec
PostPosted: Mon Sep 08, 2008 1:45 pm    Post subject: Still boards available...? Reply with quote  Mark this post and the followings unread
Is there by any chance boards left here Fonik? If thats the case, I would like a pair of them. Please sign me up for two if you still got any spares... plz. Smile Thanx
/thure
PostPosted: Mon Sep 08, 2008 10:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
still some boards left. check PM.
fonitronik at
loopcycle
PostPosted: Wed Sep 17, 2008 7:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
received my boards. beautiful work! thanks for this.
Peake
PostPosted: Tue Sep 23, 2008 2:39 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got a board up and running- great stuff! My first intent is to use it to substitute for a power supply for the Moog Modules, until I get one built: 12V, -6V, and -10V rails are required (the classic power supply does not regulate the -10V). For some reason, I was only getting 1V at the internal/jack normal'd source, so I jumpered R29 to pass the full 15V to the pots. Presto, just set the pots to the desired voltages. I don't know if this will work in powering the modules yet, but it's fun to play with Smile
Thanks a bunch for the second run!!
loss1234
PostPosted: Tue Sep 23, 2008 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
does anyone think i could get away with using SINGLE TURN 50k trimmers?
i really want to get this built (mainly as an audio mixer) and i have tons of single turn trimmers but NO 50k multi turn.
thanks
PostPosted: Tue Sep 23, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
actually you could get away without a trimmer and a fixed resistor instead. the trimmer is just to calibrate the processing potentiometer to OV at 12 o'clock.
fonitronik at
PostPosted: Tue Sep 23, 2008 8:31 am    Post subject: Reply with quote  Mark this post and the followings unread
try a single turn trimmer. you could get set it with patience and a tranquil approach...
fonitronik at
LektroiD
PostPosted: Tue Sep 23, 2008 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
can I take one please? Wink
PostPosted: Tue Sep 23, 2008 1:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
sure, check PMs.
fonitronik at
LektroiD
PostPosted: Wed Oct 01, 2008 12:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Oops... should I remove and change these?
 Filesize:  103.51 KB
 Viewed:  123 Time(s)
