Modifying COMPARATOR module
Page 1 of 1 [6 Posts]
funkyfarm
PostPosted: Tue Sep 23, 2008 3:50 am    Post subject: Modifying COMPARATOR module
Subject description: GATE OFF output
do you know if it would be easy to mod yves' module to get, not a TRIG OFF (when input changes to low), but a GATE OFF output instead, which would stay high as long as signal at the input stays under threshold.
What happen if you replace C4/C6 with a wire ?
http://yusynth.net/Modular/index.html
yusynth
PostPosted: Sat Sep 27, 2008 1:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi if you need a GATE OFF, you can pick the signal at pin 1 of U1a and add a diode and a 1K resistor in series.
If you don't need the TRIG OFF output you may replace C4 by a 10k resistor (this resistor is needed otherwise the LED would'nt operate normally I think.
Yves
funkyfarm
PostPosted: Tue Sep 30, 2008 1:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you so much.
I'll try both !
funkyfarm
PostPosted: Sun Mar 08, 2009 3:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
R17 R18 voltage divider and so gives 6 volts from 14V.
if i want 10V signals, what is the better choice ?
10V is about 75%...
330ohm and 1k
510ohm and 1k5 (i have this in stock...)
Would it change output impedance ? it can leads to problem ...
yusynth
PostPosted: Sun Mar 08, 2009 4:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
330 and 1K seems to be alright, no problem with output impedance.
Yves
funkyfarm
PostPosted: Mon Mar 09, 2009 2:49 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you for answer.
