Precision +/-15V @ 1A PSU
Page 1 of 4 [80 Posts]
Goto page: 1, 2, 3, 4 Next
Audio files: 51
PostPosted: Tue Sep 23, 2008 3:06 am    Post subject: Precision +/-15V @ 1A PSU
Subject description: What I'd like to know is,......
I'm working on a new precision +/-15V @ 1A PSU and I thought I'd share some pics and info on the process.
It's based on the LM723 (*2) regulator chip with MJE3055 transistors to carry the current load.
The schematic is freely available on the Elby Designs site. Here
I've done a stripboard layout of my own which I'll post if anyone is interested.
Please Note:
This DIY project involves the wiring of a mains transformer and associated IEC socket, fuse and switch. Attempting this without the proper precautions can be lethal!
If you have any doubts about your ability with mains potential wiring,... Do Not Attempt this Project.
No responsibility will be taken by myself or
electro-music.com for anyone's ability or lack thereof to attempt a project of this nature.
I'll be posting some pics soon.
We would lose our friends.
So,.........
Etaoin
PostPosted: Tue Sep 23, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for reminding me of that one.
How easy would it be to pull out more amps? The MJE3055 can handle up to 10A so I guess the design is limiting in other places. I have some 2N3055 lying around that can do even more current.
http://www.casia.org/modular/
PostPosted: Tue Sep 23, 2008 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
the limitation is obviously the heat dissipation. take a look at these gorgeous heatsinks! Shocked
i thought about a 1.5A PSU using the units case itself as heatsink. thoughts?
fonitronik at
frijitz
Audio files: 54
PostPosted: Tue Sep 23, 2008 7:57 am    Post subject: Re: Precision +/-15V @ 1A PSU
Subject description: Build and Pics
Interesting! How much better is this design than the LM317/LM337 regulator approach?
Ian
Peake
PostPosted: Tue Sep 23, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
So long as the case doesn't flex at all, know that it's been done (with extra dissipation hardware). The Prophet 5 comes to mind, but that's where I saw the problem- the regulator ICs were bolted to the case, and the length of the case allowed for flexing- and the leads eventually break off at the PCB.
My knowing "it's been done" doesn't mean that it was totally successful. You'd have to look into any tales of the reliability of the P5 power supply to confirm.
bugbrand
PostPosted: Tue Sep 23, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just started to use some POwer One HAA15s and these are LM723 based also with 2n3055s. These use the (semi-)case for heatsinking.
http://www.bugbrand.co.uk
Audio files: 51
PostPosted: Tue Sep 23, 2008 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was going to elaborate on that.
This design will actually allow me to up the Amps later.
I'm putting in an 18-0-18 @ 4A4 per rail transformer.
Initially I'll use the 1A per rail circuit, but I'm also looking at a way of beefing up that circuit using a TIP29 and a 2N3055 on each rail. And yes, the trick is to fit the right heatsinking in. It should end up being able to deal with about 3A per rail.
Right from the start, I'm putting it all in a 2U rack case, and designing the layout with the upgrade in mind.
That's why I thought you guys might be interested. Wink
So,.........
Sine
PostPosted: Tue Sep 23, 2008 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have built this thing and it is really rock solid with minimal drift
The only change I made is using darlington transistors so the 723 doesn't have to supply as much base current, something like the TIP140 or BDV65 would do nicely, or a MJ3001 if you must have a TO-3 in there Wink
Audio files: 51
PostPosted: Tue Sep 23, 2008 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's one of the reasons for going with the TIP29/2N3055. I'm going to do them as a discrete darlington pair.
So,.........
Audio files: 51
PostPosted: Sat Sep 27, 2008 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay,
Here's the first pic.
These are all the basic parts, laid out roughly where I want them. You can see the start of my distribution panel bottom right (it's come a long way since then!)
I think there should be plenty of space for expansion later, like I said, that transformer can supply 4A4 on each rail, so to up the ante I only need to come up with a new stripboard layout and heatsink pair later on.
 Filesize:  203.61 KB
 Viewed:  109 Time(s)
So,.........
Audio files: 51
PostPosted: Sat Sep 27, 2008 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Next,
I got to work on the back panel. Here's a pic of the panel, with holes cut for the IEC power socket and fuse holder. There's a collection of tools around it which I use for this kind of work.
 Filesize:  121.76 KB
 Viewed:  97 Time(s)
So,.........
Audio files: 51
PostPosted: Sat Sep 27, 2008 5:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Two shots of the power socket and fuse holder. Note the lug for attaching the chassis earth. Check with a meter that there is 0R from the lug to the other end of the panel. Wink
 Filesize:  160.89 KB
 Viewed:  72 Time(s)
 Filesize:  175.11 KB
 Viewed:  76 Time(s)
So,.........
fluxmonkey
PostPosted: Sat Sep 27, 2008 7:34 am    Post subject: Reply with quote  Mark this post and the followings unread
i cant tell from the pics what kind of ventilation scheme you're using? big heatsinks help conduct the heat away from the regulators, but it's still got to have someplace to go... vent holes and/or forced air.
www.fluxmonkey.com
Sine
PostPosted: Sat Sep 27, 2008 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Great work on the case Krunkus,
Yes, a step drill is a MUST for anyone that does diy electronics.
I build mine on matrix board
Originally for +-12V, but later modules needed +-15V so I did a "upgrade" on it a few months later Wink
Audio files: 51
PostPosted: Sat Sep 27, 2008 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm not putting any ventilation holes at this stage, as this board is just 1Amp per rail. The 3A version (when it goes in) will have larger heatsinks and holes top and bottom. I'll sort out where to best place the holes once I have the larger heatsinks in place.
So,.........
Audio files: 51
PostPosted: Sat Sep 27, 2008 8:03 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't want to cut holes at the moment, 'cos I don't know where the larger heatsinks will be mounted. I've never built a PSU this size before, so I want to do a bit of testing under load and find out just how hot it gets. Very Happy
So,.........
Sine
PostPosted: Sat Sep 27, 2008 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Personally I would ( and I have on my version ) mount the heatsinks on the back of the unit.
Audio files: 51
PostPosted: Sat Sep 27, 2008 5:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's the distribution board.
I used stripboard, as I'm going with the .1" pitch molex style keyed headers and plugs.
The screw terminals are reverse mounted, and jumpered over with a piece of .7mm tinned solid copper wire. I continued this along the stripboard to maintain the cross section and keep the resistance as low as possible. I thought about adding an extra 2 caps at the other end of the distribution board, but decided that would be overkill and would just up the inrush current. What do you guys think? I could still add them later if needed.
 Filesize:  133.5 KB
 Viewed:  73 Time(s)
 Filesize:  125.05 KB
 Viewed:  73 Time(s)
 Filesize:  153.95 KB
 Viewed:  81 Time(s)
So,.........
Audio files: 51
PostPosted: Sat Sep 27, 2008 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Then I mounted it in the slot with 6mm threaded plastic spacers. These are great, as they eliminate the "now, just hold on to those 5 things while I get this one in place,....doh!" effect. Laughing
8 mounting points might seem a bit much, but it wasn't much harder than 4, and it means the board won't flex at all when connecting/disconnecting plugs.
I also kept it to one half of the panel depth, so I can add a second one later if need be.
 Filesize:  164.49 KB
 Viewed:  75 Time(s)
 Filesize:  138.88 KB
 Viewed:  79 Time(s)
So,.........
Audio files: 116
G2 patch files: 317
PostPosted: Sat Sep 27, 2008 6:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
When you'd space them differently you could use less ... irregular placement is better than regular and having them at the end of the board is not the best position re. flex reduction .. funny thing is that it's really a musical problem of sorts, the eigen frequencies of the mounted board should be optimized for max stability at least cost Shocked sorry, good morning is what I really meant to say Laughing
Audio files: 51
PostPosted: Sat Sep 27, 2008 7:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, didn't you notice the gap in the middle is bigger? Laughing
So,.........
bugbrand
PostPosted: Sun Sep 28, 2008 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Uncle K -- good work on the rectangular holes --- nice and tidy!!
Audio files: 51
PostPosted: Sun Sep 28, 2008 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, that nibbling tool is one of the handiest things I've ever bought. Even more vital than a step drill IMHO. You hardly need to clean up the edges either, you can come right up to a line within less than .25mm. It does prefer aluminium to steel though, which is to be expected, but on a nice quality rack enclosure like this one, the front and back are aluminium which makes it easy.
So,.........
Luka
PostPosted: Wed Oct 01, 2008 4:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
stipboard layout available andy?
problemchild
melbourne australia
Audio files: 51
PostPosted: Wed Oct 01, 2008 6:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah,
Hold on, I'll just tidy it up a bit. Very Happy
So,.........
