LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Mon Oct 13, 2008 9:37 am Post subject:
Maplin voice changer kit |
I've just built one of these, apart from the instructions assuming you're a numb skull, it's quite interesting.
http://www.maplin.co.uk/Module.aspx?ModuleNo=220042
http://www.maplin.co.uk/Media/PDFs/N40FL.pdf
I'm wondering what modifications I can make to make it usable within a synth? I know I need to put a resistor at the input stage to bring it to line level, but I wonder if there are some tweaks I could do to it which would make it more interesting. |
EdisonRex
Audio files: 172
Posted: Wed Oct 15, 2008 2:47 am Post subject:
I had my son build one of these last year. Unfortunately the HT8950A is a one trick pony, and other than possibly doing some circuit bending with it, it pretty much does what it says it can do on the datasheet.
To make this into a module (and I thought about this too) would require some mods, first off, it's only a 4V max supply. Second, you'd have to desolder the onboard switches to carry them to panel mount switches. Third you'd need to deal with the mic level, and you'd need to deal with the speaker level out, and remember that if you hooked it up to a +-12 or 15 based module with 10V signals you'd have a lot of issues.
It's a cute project, but there are other more useful projects in that particular kit collection (the function generator for example). _________________ Garret: It's so retro.
vtol
vtol
fluxmonkey
Posted: Mon Dec 08, 2008 9:20 am Post subject:
also check DH Pitch Shifter at general guitar gadgets. PCB available; you'd need something like one of ken stone adapter boards to adapt it from/to modular levels _________________ www.fluxmonkey.com |
synthmonger
Posted: Thu Dec 11, 2008 1:49 pm Post subject:
I breadboarded a few different designs of this. My finalized design incorporated my vcovr to control the pitch and I replaced the switches with electronic switches.
There is a drawback using electronic switches though. When lowering the pitch the electronic switches don't register as quickly. Also, the e-switches don't register very well at high frequencies. They're fastest switching rate is just above lfo speeds. |
vtol
jjj
Posted: Fri Oct 02, 2015 5:07 pm Post subject:
Big question:
Can its vibrato be adjusted as to provide a slow frequency shift (of max. 5%) and thus, be useful as a how-round stabilizer to eliminate Mic feedback problems in audio setups? |
