Troubles with valueswitch
Page 1 of 1 [4 Posts]
kara
G2 patch files: 5
PostPosted: Thu Oct 30, 2008 1:20 am    Post subject: Troubles with valueswitch
Subject description: Why doesn't this work ?
Musicians and math realy don't go together Rolling Eyes Very Happy
I wonder why this doesn't work....
The goal is that when the random pattern generator gives a value above a limit the switch passes entry 2 (second pattern generator) and if the output of the random pattern generator is below a value the switch passes entry 1 (first pattern generator).
Alltough the idea sounded very simple to me, it doesn't work ?
What am I doing wrong here Embarassed ?
k
Example1.pch2
 Filename:  Example1.pch2
 Filesize:  2.3 KB
 Downloaded:  504 Time(s)
Free samples, Vsti's and Artist hosting at www.kara-moon.com
Music forum at www.kara-moon.com/forum
G2 patch files: 584
PostPosted: Thu Oct 30, 2008 2:00 am    Post subject: Reply with quote  Mark this post and the followings unread
The value switch will only change when the input equals the number on the [ctrl value] control (I know that is not what the manual says Rolling Eyes).
If you add a complev and use its A>=C output as the Ctrl in on the value switch, you will get what you want. Set Ctrl Value to 0 or 64.[/right]
iPassenger
G2 patch files: 78
PostPosted: Thu Oct 30, 2008 2:05 am    Post subject: Reply with quote  Mark this post and the followings unread
What Ian says will work and it is how I would do it but could you not also use the windowswitch? (i never use it)
Just a thought while i should be working on reports for work. Smile
iP (Ross)
kara
G2 patch files: 5
PostPosted: Thu Oct 30, 2008 2:40 am    Post subject: Reply with quote  Mark this post and the followings unread
Ian's solution does exactly what I want it to do Cool
Thank you both for your help !
k
Niio2
