 Forum index » Clavia Nord Modular » G2 Patches - Completed » Audio In
A couple of multi FX patches for my Engine
Page 1 of 1 [4 Posts]
davep
Audio files: 10
G2 patch files: 73
PostPosted: Thu Nov 20, 2008 11:33 pm    Post subject: A couple of multi FX patches for my Engine Reply with quote  Mark this post and the followings unread
Hi All,
I recently got an Engine to be used mostly as an external FX processor. I have a couple of good hardware reverbs (Lexicon PCM70 and TC Reverb4000) so the plan is to use the Engine for just about everything else.
Here are a couple of patches that have been working out really well when used along with the reverbs. Each patch has two different Chorus effects in parallel, one with the classic sweeping delays and one with Pitch Shifters used as detuners. These are then fed to a stereo ping-pong delay.
One of the patches uses a basic clean delay with tone damping, and the other uses an amazing tape delay emulation created by Rob H. It doesn't always behave politely when presented with hot signals and long sustained sounds, but when you want to make extreme tape delay effects by cranking the repeat control all the way up, it really has a lot of attitude like a real tape delay (thanks, Rob!).
So I have the Engine patched from a stereo FX send on the analog console and returning it's output to a couple of channel strips, so I can then cascade the Engine effects into the reverbs along with the other channels. This is working out really well. These chorus & delay patches sent to a lush reverb are exactly what I've been looking for. Enjoy!
EXT Chorus Shift TapeEcho.pch2
 Filename:  EXT Chorus Shift TapeEcho.pch2
 Filesize:  4.85 KB
 Downloaded:  1165 Time(s)
EXT Chorus Shift Echo.pch2
 Filename:  EXT Chorus Shift Echo.pch2
 Filesize:  3.59 KB
 Downloaded:  1071 Time(s)
Dave Peck
BobTheDog
PostPosted: Fri Nov 21, 2008 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Im looking forward to using these.
Andy
Roland Kuit
G2 patch files: 127
PostPosted: Fri Nov 21, 2008 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
nice job dave Smile
mtvic
PostPosted: Sat Nov 22, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
Congrats on your Engine.
I know you had a time finding one .
m
