Cascade delays for more than 2.7 secs?
Page 1 of 1 [7 Posts]
lxndr1
PostPosted: Wed Jan 16, 2008 4:35 pm    Post subject: Cascade delays for more than 2.7 secs? Reply with quote  Mark this post and the followings unread
Hello.
I suppose this question has been answered explicitly somewhere on the forum, but I couldn't find it.
Can you cascade multiple audio delays on the G2 within a single patch for a longer total time than 2.7 secs?
I assume the answer is no, but I am interested in exactly how the G2 prevents you from doing this.
I am not a G2 owner, but am considering purchasing one largely for the purpose of processing vocals.
Thanks.
Audio files: 278
PostPosted: Wed Jan 16, 2008 4:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
In a single patch there are two areas (voice and fx) you could use that to make 5.4 sec (using the audio buses).
It's also possible to do voice multiplexing ... it's causing headaches, but it would allow for longer delays in a single patch's voice area ... it has some limits as well, but it's been a while since I tried Very Happy
Oh and we have time multiplexing, how could I forget Very Happy
Handle
PostPosted: Thu Nov 27, 2008 5:44 am    Post subject: Reply with quote  Mark this post and the followings unread
You can cascade 4 delays for a total of 10.8 seconds of delay using 2 patchs. I've used a 3rd patch in the attached file because I was trying to add more delay but the G2 said no so I just added some chorus.
What is patch multiplexing and can I use the method in the attached patch with time multiplexing to get a delay of 21.6 seconds?
TenSecondDelay.prf2
 Filename:  TenSecondDelay.prf2
 Filesize:  4 KB
 Downloaded:  1378 Time(s)
Audio files: 278
PostPosted: Thu Nov 27, 2008 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome Handle,
voice multiplexing you mean? Hmm, it's a long time ago since I experimented with that ... the idea was that one delay gets two when the voice count goes from 1 to 2 ... but it needs a way to get sound from one voice to the other ... I forgot how I did that .... probably by routing to the FX area through a demultiplexer set by the voice nr output of the in/out/stat module & then back to the poly area, erm VA I mean ... something like that anyway Wink
Audio files: 278
PostPosted: Thu Nov 27, 2008 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
I remembered ... this is the idea
voice-mpx.pch2
Basic voice multiplexing to make long delays
 Filename:  voice-mpx.pch2
 Filesize:  1.46 KB
 Downloaded:  2360 Time(s)
Audio files: 278
Press the button or hit a key, and then wait ...
Audio files: 278
PostPosted: Thu Nov 27, 2008 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
And then you can add some extra delays of course ... and automate it bit ... Laughing
voice-mpx-auto.pch2
Even longer delays
 Filename:  voice-mpx-auto.pch2
 Filesize:  3.09 KB
 Downloaded:  2345 Time(s)
