 Forum index » Instruments and Equipment » Waldorf
Micro Q FX2 routing and drum maps? (rephrased)
torsig1967
PostPosted: Mon Dec 01, 2008 2:58 pm    Post subject: Micro Q FX2 routing and drum maps? (rephrased) Reply with quote  Mark this post and the followings unread
I asked about this earlier but my question was a bit confused so I'm trying this new rephrased version:
When using Drum Maps is it true that the FX2-routing of each sound in the map is dependant of both:
1. The FX2-effect and level of the actual Drum Map program.
2. The FX2-level of each sound in the drum map.
That is; even if FX2 is turned up in the drum program it still has to be turned up in each individual program as well.
Seems to me this is the case but it's a bit strange because if I use an effect with a tail (reverb or delay) sounds which are suposed to be dry will spill over into the effect if an earlier sound with effect is still sounding. This seems like a bug to me or maybe I'm missing something.
I use OS 2.22, 75-voices, keyboard version.
Niio2
