I'm warming my iron up! _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
We would lose our friends.
So,.........
Oh, don't you worry about that!
I always find time to play with the Appendage! _________________ If we thought and said hateful, discouraging, demeaning things to our friends,.....
So,.........
My beta board arrived today! Bug checking is done and construction will start on Tuesday morning.
All else is on hold until the beta build is completed and testing has begun.
The 4 of you that I have items to mail to, will FINALLY occur this coming payday / Thursday.
I wish I had known what it costs to get a car tuned up. If it weren't for that, 10 days ago, things would have been mailed back then. Sorry about that everyone.
i had some talk about this module with ryk a while ago. i'd thought it would be a good idea to have an AR and a VCA on board to, so the liquidHH would only need a trigger to work as a kind of standalone module.
what do you think about it? would it be too late to incorporate this into the design/layout? however, one could add this later on a perfboard... _________________
fonitronik at
Exactly! 1st time experience for me. From THAT cost, I'll now learn about doing as much of it myself, to save money as I can. Haven't even been able to buy a single part since the tuneup, due to it's cost. Ah well. Payday is only 2 days away.
I am just glad that you are on it again.
Think this is going to be a great module.
Credit will have to be extended to Dragon's Lair on that one, for taking it ahead. I myself had to get some other testing done FOR the Liquid HiHat, but my sequencer's development and building was taking up almost every available thinking / building moment that I was having available to me. Hence - leaving the LHH in limbo.
I'm much-o glad that the LHH has now come to this point. The first Beta report will be posted here within days, including video(s). Last edited by Rykhaard on Tue Dec 09, 2008 9:33 am; edited 1 time in total
I am quite FOR that idea myself as well. In a related parallel move to that, after having recently built 1 of Ray Wilson's Drum Triggers, that I tried out with the piezo transducer still seated in an alarm clock that I bought at the dollar store - thought that it would be great TO have the Drum Controller built INTO the LHH! Ray's Drum Trigger provides a velocity sensitive Attack Decay envelope generator. I (of course) modified that, to give it a changeable Decay time and it works beautifully with the LHH. Depending on what level you set the Decay amount control at, your velocity can determine whether you're playing a Closed or Open Hihat.
The LHH is currently at beta though. So I don't know if Dragon's Lair would wish to redo the layout with an addition for it, or not. As well - whether Ray would allow his circuit to be used as well, or not. Mmmm.
Personally, I would rather have them all on separate modules, to me the whole idea of having a modular synth is that you can plug anything into anything, once you start putting all the "options" on one board, you limit what you can do with it, you may want to use the drum trigger or vca with other modules. I find this is a growing trend on the DIY stuff, the designers are adding everything they can think of, to make it an "all in one" module, to me that is no longer a modular, I like my modules to be simple, single purpose modules, if I want complex I just patch more modules together.
So I really don't want to redesign it to add all the extras, I already have lots of VCA's, (and I'm working on a multi trigger module using touch sensors) but I have no objections to someone else doing it, but when I get some time, I'll look at it to maybe incorporate a header for a future daughter board. Last edited by Dragon's Lair on Tue Dec 09, 2008 11:26 am; edited 1 time in total
Joined: Sep 25, 2005 Posts: 1332 Location: Telford, PA USA
Posted: Tue Dec 09, 2008 11:21 am Post subject:
Send Ray an email asking for permission.
MK-1 Mod-0 Daughterboard...If the current board designer is unable to re-do the layout, add the new functions on a separate board as a an add on or enhancement.
From what Dave had said, I can agree with that point.
Extending it further from what Danny said as well - last night at work, another thought that I had was expanding Ray's Drum Trigger, to have multiple Attack Decay EGs from it, at the very least. The 1 that I've modified it for, opens up the sound manipulating possibilities HUGELY. Having at least a 2nd one would be all that much the wider! 1 for amplitude (VCA) and another for Pitch or Filter Cutoff?
I'll email Ray about working on an expansion for it after having done more modifications on #2 of it. (Which of course, will come after testing is finished for the Beta of the Liquid HiHat. I just got all of the parts added to the PCB, but I haven't enough time to hook up all of the controls and jacks before heading to work - where I'd best head off to now. )
She's working beautifully! Better than my original (thanks to the External Input resistor addition / correction.)
And wouldn't ya know it? I'd removed 1 of my 2 White Noise sources previously. In transferring the 2nd one, I haven't hooked it up. So I can't at the moment check the Balance control with White Noise.
I DID check it though with the output of a dual triangle VCO fed AD633 Ring Modulator and the balance options with the LHH work wonderfully.
I made only 1 mistake in temporary hookup so that 1 of the 4 x CV Inputs is not working. Outside of that - every other function works as it should.
Outta time. I'll be doing more testing / video examples on Friday as tomorrow will be tied up getting other things shipped.
What where did I go wrong? I always have at least one trace that has to have a kludge added, because I screwed up
That's good to hear Ryk, Ive been doing a little tweaking on the board layout, I found that it was a bit tight if I used the keyed type headers, I'm just going to give it another once over, then send it out for another test run, mainly to make sure the hole sizes are right this time.
If there is anything you think should be changed, now is the time to do it.
On a side note, I'm painting my workroom today, so I should have a real workshop by the weekend, which will make life much easier.
Dave - I can't remember if I reported it back to you in a PM or not, for the PCB.
Uncle Krunkus had mentioned that he PM'd you about the power connector's holes being too small. I confirmed that to him in a PM, as I'd tried to put in a 0.156" 4 pin Molex male connector (ala Ken Stone / etc.) but found the holes to be too small, as well.
Another bit to change, for clarity, is the positioning of the silkscreen labeling for some of the connections. There's overrun between pairs of them in a few places.
Also, holes for inserting the wiring for connections to the jacks and pots is a bit small as well. I had to be careful in feeding the twisted wire through them, to not have the end of it fray / split up.
Outside of those minor things, the board is looking and working great!
Right then. I HAD meant to shoot at least 1 video on Friday, but it's been a busy weekend for Christmas preparation; 'family' and traveling out for cigarettes and gifts. I'm heading downstairs to the shop in a few minutes to prepare everything for another set of tests and video shoot. Sorry for the delays!
All the holes where a bit small, my parts layout was setup for single sided boards and did not allow for the plating through on the double sided boards, I have adjusted the hole sizes accordingly.
The silkscreen is fine on the layout, it's the board manufacturer that seems to shift them sometimes, so I always have to do some adjustments after the first run, I've cleaned up the board a bit, and shifted a few parts, to give them more room, so I am just about ready to send it out for another small test run.
Excellent to read on all of the points.
I didn't have enough time to check into why Control Voltage In #3 of 4 is not working, today. I probably forgot to solder one of the wires. Doh.
I'm uploading a new video to my youtube (dolphinicus) site right now. I have about 45 minutes left before I have to leave for work. If all that has to be done on the youtube site gets done in time, I'll post a link to the video here.
It's a simple video again:
- The Liquid HiHat is being played with an 8th note pattern.
- At the very beginning I give a brief glimpse of the PCB attached to the panel.
- One by one, I demonstrate 3 different Control Voltages that are hooked up to the LHH. Then I bring them all in together to give an idea in that regard.
- Finally, I bring in a 1/4 note bass drum and snare drum pattern and a simple octaves bassline in the background.
For an coming video (or videoS), I'll be showing controlling the unit from a drum pad as well as changing the frequences of the LHH's oscillators to give some more ideas of it's functionalities.
Possibly in another video, I'll do some demonstrations of using it to produce Hihat - open and closed; Cymbal and Snare drum sounds.
The more that I play with this little bugger, the more percussion instrument types that I find are possible with it. And everything that I've mentioned above is with using a VCA ONLY. Drive it into various filters and the sonic possibilities increase hugely, once again.
I can't wait to have 3 or 4 of these guys. That, will cover all of my hihat and cymbal needs for quite some time.
Here's my front panel.
As usual, any suggestions welcome.
Filesize:
257.43 KB
Viewed:
169 Time(s)
So,.........
Ryk -- The video is very entertaining and informative ... Keep them coming
Bill
Shall be doing! I'm going to hook up my Ray Wilson Drum Trigger to my alarm clock (from the Dollar store - has a piezo transducer in it. ) and pound away again, to give more examples of the power of the Liquid HiHat. (For the next video, I mean).
Jus' wait til I get a 2nd 'pad' built. I'll then be able to give Closed and Open Hihat examples, from a single module. (It CAN be done in a way with playing technique, on a single pad, but the variations with a single Decay CV related to Velocity aren't as wide, as with a 2nd pad, driving a another Decay amount or something else.)
In the not to distant future, once I get some Remo practice pads and convert them into electronic drum controllers, shall the the video examples start to give a greaterly detailed example.
Please support our site. If you click through and buy from our affiliate partners, we earn a small commission.
