kxspxr
aerogramma
Joined: Feb 27, 2008 Posts: 156 Location: Roma, Italy - London, UK
Posted: Fri Dec 12, 2008 12:15 am Post subject:
sounds interesting thanks!
so if i read it correctly thi thing modulator has only one audio input correct?
any chance to have a sound sample?
cheers
kxspxr
Posted: Sat Dec 13, 2008 4:53 am Post subject:
Yes - one input and one output. I can't upload any sound samples because I gave my Thing Modulator V3.0 to a friend the other day. I will build one for myself next week (if time is on my side) and upload some sound samples.
EDIT: Sine the bandwidth of the oscillator lock is determined by input voltage and input capacitans, I'd suggest experimenting with the 100nF input cap. Check out the datasheet for LM567 for the equation.
EDIT_2: I tried it with only a few audio sources; piano, violin and fuzz guitar sound absolutely great IMO. Maybe because of the rich harmonic content in all three?
EDIT_3 (and pretty off topic):I can see from your myspace you know Goodiepal as well. He's one of my old friends, small world _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
aerogramma
Posted: Sat Dec 13, 2008 5:07 am Post subject:
thanks!
look forward to hear them when they're ready
loss1234
kxspxr
Posted: Mon Jan 05, 2009 6:23 am Post subject:
loss1234 wrote: | IMPORTANT
THIS PROJECT DOES NOT WORK QUITE RIGHT WITH A REGULAR LM567
(this is why specifically asks for an LMC567....big difference
when i tried it with a lm567 it had a lot more bleed. with an lmc567 it had very little. |
That is very good to know! I don't remember what I used in the one and only Thing Mod V3 I made, which I gave away the same day I soldered it. I'll check it as soon as I get a chance..
-Kasper _________________ "Posthumanity is a discrete set of processes with arbitrary return codes." |
LektroiD
Joined: Aug 23, 2008 Posts: 1018 Location: Scottish Borders
Posted: Mon Jan 19, 2009 12:58 pm Post subject:
Getting hold of a LMC567 is not the easiest thing in the UK. Unless someone knows a good source for these? |
aerogramma
Posted: Tue Jan 20, 2009 4:20 am Post subject:
off topic! |
EDIT_3 (and pretty off topic):I can see from your myspace you know Goodiepal as well. He's one of my old friends, small world [/quote]
oh yes i know the palla quite well, i even know his grandma..
we did quite a few stuff togheter and he lunched at my table for years... supernice guy |
ninja86
Joined: Jan 30, 2009 Posts: 1 Location: Underground Lair
LektroiD
Posted: Fri Jan 30, 2009 12:48 pm Post subject:
That is not an LMC567
LektroiD wrote: | loss1234 wrote: | IMPORTANT
_________________ LektroiD |
fluxmonkey
LektroiD
Posted: Fri Jan 30, 2009 5:11 pm Post subject:
Farnell wrote: | US Stock
US Stock items that have a service charge indicated are coming from our Newark warehouse. The service charge will be 15.95 per order, in lieu of a freight charge for Newark items.
Delivery Charge: £15.95 once per order. |
I'm looking for one in the UK _________________ LektroiD |
DGTom
Posted: Sat Sep 05, 2009 3:51 am Post subject:
I need to pick up some LMC567s... I found the normal kind still pretty usefull, I made a pair of drone oscillators for my lunetta which do some cool 'stepping' tones when used in a feedback loop with one another & found a pretty good configuration for a nasty digital sounding fuzz. I'm gonna try this one out as well as I've still got a few chips, was it devised with the LM or LMC? |
mikebike
Posted: Tue Aug 03, 2010 3:27 pm Post subject:
this thing is awesome! im gonna build the WSG filter and tack it on the end!??!?! maybe an envolope folower? crazy!?!?!! |
