Saving performances
Page 1 of 1 [2 Posts]
AngusHastie
PostPosted: Thu Sep 30, 2004 6:59 am    Post subject: Saving performances Reply with quote  Mark this post and the followings unread
Quick question - when you save a performance, patch settings for all slots are included, even in slots that are not active (e.g. you might have been playing around with patches in other slots and decided not to use them so deactivated them). Is there a way to just save data for the active slots or does it not really matter anyway? Just thought it might reduce the load time for a new performance if you're switching between performances in a live situation.
Cheers, Angus
Audio files: 278
PostPosted: Thu Sep 30, 2004 7:14 am    Post subject: Reply with quote  Mark this post and the followings unread
I know of no other way to do so than to remove all modules from the slots you don't want to be stored.
Wheteher it makes any difference on the load time ... maybe not, as the patch does not have to be compiled (which takes some time). It will be sent to the synth though I assume, othewise something would get lost by storing the patch into the synth. This is just guesswork though.
Jan.
