Live Streaming New Years Eve 2009 electro-music.com event
Page 2 of 8 [196 Posts]
EdisonRex
Audio files: 171
PostPosted: Mon Dec 29, 2008 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
testing worked. thanks mosc
Garret: It's so retro.
ocp
Audio files: 9
PostPosted: Mon Dec 29, 2008 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
same here Cool
https://opcabpol.bandcamp.com | https://www.mixcloud.com/Boiar | http://editoradoporto.blogspot.com |
tytytytyty
PostPosted: Mon Dec 29, 2008 9:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tested and working -- thanks, Howard!
http://sublevel9.net
Roland Kuit
G2 patch files: 127
PostPosted: Tue Dec 30, 2008 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
great idea!!!! thumbs up and a very great 2009 to you all!!!!!!!
i hope i can join in, but the internet pc has some problems. hope i can fix this today. i put this on synthforum.nl
PostPosted: Tue Dec 30, 2008 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Up and running here as well. Thanks! Very Happy
/Stefan
Audio files: 266
PostPosted: Tue Dec 30, 2008 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
my connection seems to work too Smile
rent
PostPosted: Tue Dec 30, 2008 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
as far as I can tell my connection is working, but I'll double check today in the forums to make sure others are hearing it okay...
Mohoyoho
PostPosted: Tue Dec 30, 2008 11:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Still not working for me.
Mark Mahoney
Kingsport, Tennessee
www.cdbaby.com/cd/markmahoney
mtvic
PostPosted: Tue Dec 30, 2008 12:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey
Is anyone using rogueameoba Nicecast?
m
Mohoyoho
PostPosted: Tue Dec 30, 2008 12:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Starting to make connections a little more frequently.
Mark Mahoney
EdisonRex
Audio files: 171
PostPosted: Tue Dec 30, 2008 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Mac users using Nicecast - take note:
You should go into the effects section and load the Apple AUPeakLimiter in the audio chain. You should also get your meter up and make sure you set the limiter's cap at the green on the meter. This will give you a healthy signal and cap the distortion.
I don't know if non-Mac streamers have plugins but if you have a hard limiter plugin (or a soft limiter, set up with aggressive top end) you should use it.
Audio files: 239
G2 patch files: 319
I've made : http://bluehell.electro-music.com/nye/
to have all info readily available in one place.
EdisonRex
Audio files: 171
PostPosted: Tue Dec 30, 2008 2:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
mtvic wrote:
Hey
m
yes quite a few. Come on the chat if you want to tune it up.
ocp
Audio files: 9
PostPosted: Tue Dec 30, 2008 5:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Linux and Mac users may also want to try Muse: http://muse.dyne.org/
Rather simple to set up and it's free.
Wink
Pehr
PostPosted: Wed Dec 31, 2008 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
I tested streaming audio with edcast on my dedicated server yesterday and it seemed to work. I could listen to it via Screamer radio and with Winamp. Also someone in the chatroom called "BluJ" helped me to confirm that it worked. Very Happy
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
mmetlay
PostPosted: Wed Dec 31, 2008 1:40 am    Post subject: Moi Aussi Reply with quote  Mark this post and the followings unread
Hello Howard and all else concerned!
I ran a test of the streaming server and chat room tonight, and all seems good. I should be good to go to hit the stream and scare the bejabbers out of folks toward the end of the set. Looking forward to seeing and hearing your music!
mike
mike metlay * metlay@atomiccity.com
founder and coordinator, different skies
associate editor, recording magazine
prime mover, atomic city / mindSpiral
cappy2112
PostPosted: Wed Dec 31, 2008 2:27 am    Post subject: Re: Moi Aussi Reply with quote  Mark this post and the followings unread
mike
Hey Mike,
Good to see you here.
Tony C
mtvic
PostPosted: Wed Dec 31, 2008 5:32 am    Post subject: Reply with quote  Mark this post and the followings unread
well hello mike
mystahr
PostPosted: Wed Dec 31, 2008 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
While I'm late to the party, I'll likely be tuning in over the course of the night and morning. Not that I'm doing much else really.
Very cool concept and I'm glad I ran into this forum.
mtvic
PostPosted: Wed Dec 31, 2008 9:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Im using nicecast and have my port #8080
and password.Nicecast is Broadcasting.
What do I do now. Is there a specific url that I have to use to broadcast to the shoutcast server.
Help
m
Audio files: 239
G2 patch files: 319
PostPosted: Wed Dec 31, 2008 9:14 am    Post subject: Reply with quote  Mark this post and the followings unread
The server is radio.electro-music.com, but please go to the chatroom with questions, there are more people there who know things ....
Acoustic Interloper
Audio files: 86
PostPosted: Wed Dec 31, 2008 9:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Help
m
I'd take a look at the oddcast/edcast instructions linked from the first page of this thread, and fill in the corresponding fields in nicecast. The URL (Jan's previous post), port, and the streaming format in MP3 are all critical fields. It's nice to fill in the meta-data, after you have tested the streaming, so listeners can get title and performer info, etc.
When the stream is deep
my wild little dog frolics,
when shallow, she drinks.
Audio files: 239
G2 patch files: 319
PostPosted: Wed Dec 31, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
some links :
chat room: http://electro-music.com/forum/chat.php
info page : http://bluehell.electro-music.com/nye/
ocp
Audio files: 9
PostPosted: Wed Dec 31, 2008 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Nice to see you here!
Catch you later ( ;
mtvic
PostPosted: Wed Dec 31, 2008 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Jan
In 2006 I used winamp and a pc. this year nicecast and mac.
not accustomed to this.
m
