Fozzie
G2 patch files: 49
Posted: Mon Jan 05, 2009 4:05 am Post subject:
Getting separate bytes from sysex dump into cc messages |
I am trying to get the separate bytes from a 256 byte sysex dump (from a Waldorf synth, but this is not really important) and use them as the value bytes of a range of cc messages. The purpose of doing this would be to send the cc values to a midi controller (NM G2 or BCR2000) in a parameter feedback scheme, to update the values of the endless rotary encoders.
I noticed that SC/PC can cope with sysex messages on a PC platform, but would my problem be solvable? The idea would be to capture the sysex string of hex bytes, and send 'em one by one (all or preferably a subset) to the midi out, packaged in the correct CC controller messages as hex value bytes. Of course, I know what sysex byte should be in what CC# message, so maybe I could use some sort of table to do this parameter mapping?
Any ideas whether this is feasible, or whether there is a more simple solution (midi-ox doesn't work since it can't handle sysex input other than storing or routing it)? _________________ Spinning at ~0.0000115740740741 Hz |
Fozzie
G2 patch files: 49
Posted: Mon Jan 05, 2009 6:54 am Post subject:
I just noticed that a vbscript approach using midi-ox might be feasible as well, so I'll investigate that option as well. Still, if anyone wants to comment on PC sysex transmogrifying, please do. _________________ Spinning at ~0.0000115740740741 Hz |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Tue Jan 06, 2009 1:39 pm Post subject:
IIRC sysex receipt in SC gives you an Int8Array with all the bytes, which you can then parse any way you choose.
Not sure exactly what the question is here...? It's quite straightforward to get individual bytes with messageArray[index], and ranges with messageArray[leftIndex .. rightIndex] (*). Like C, indices start at 0.
(*) But keep in mind, the range syntax copies part of the array into a new Array object. If using the same range more than once, it's better to save the partial copy in a variable rather than repeatedly copy the range. (Getting a single array item doesn't copy.)
Don't know if you're reassembling 14-bit ints from a pair of 7-bit values -- if so, that's easy too:
(mostSignificant7Bits << 7) | (leastSignificant7Bits)
hjh _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
Fozzie
G2 patch files: 49
Posted: Wed Jan 07, 2009 3:16 am Post subject:
Thanks James, that helps. I think I will try the psycollider and midiox/vbscript options both, to see which works best. I am having some problems with the midiox scripting, but this is probably due to my relative newbieness with regard to any kind of text-based programming.
I want to 'lift' single bytes from the sysex message to incorporate them as the value byte in appropriate cc messages. The sysex dump that I want to remap to cc message lends itsself well to do this. I am yet unsure what format these bytes should be when psycollider sends cc messages out. _________________ Spinning at ~0.0000115740740741 Hz |
dewdrop_world
Posted: Thu Jan 08, 2009 10:06 am Post subject:
"Lifting" bytes... in text-programming-speak, that's array addressing. Array items start at index 0 and increase by 1 thereafter. If the array is:
a = [10, 8, 4, 7, 3, 2, 6, 9, 1, 5];
... then a[0] is 10, a[1] is 8, a[7] is 9 and so on. This is standard syntax for most languages.
a[2..5] is a new array, [4, 7, 3, 2]. Not all languages do this. SC gets the [2..5] syntax from Ruby.
Sending MIDI out in SC uses the MIDIOut object. The .control message handles standard continuous controllers. I've heard Behringer controllers sometimes use a pair of CCs to increase resolution (0..16383 instead of 0..127).
Code: | ~midiOut = MIDIOut.newByName("my device", "my port");
// Continuous controller
// controllerNumber, value can be 0-127 only
// channelNumber is 0-15
~midiOut.control(channelNumber, controllerNumber, value)
// Controller pair, assumes 'x' is the 14-bit value
~midiOut.control(channel, ctlNumMostSignificantBits, value >> 7)
.control(channel, ctlNumLeastSignificantBits, value & 127); |
Fozzie
G2 patch files: 49
Posted: Fri Jan 09, 2009 1:23 am Post subject:
dewdrop_world wrote: | "Lifting" bytes... in text-programming-speak, that's array addressing.......
Thanks again! I understood the array thing (was just trying to get across what my intention was), but thanks for the code examples. I always struggle for some time with the exact syntax since I am not fluent in any computer language in particular.
I was a bit fuzzy on the byte format; I wasn't sure whether PC uses decimals or hex for internal sysex or other midi processing, but I now understand all processing is in decimals. Since I am also working on a midiox script - where sysex is in hex and other midi in dec - I was mixing up things.
I have been making headway in the midiox scripting last night, so at least I'm confident that I will get there one way or the other. _________________ Spinning at ~0.0000115740740741 Hz |
dewdrop_world
Posted: Fri Jan 09, 2009 9:53 am Post subject:
Fozzie wrote: | I was a bit fuzzy on the byte format; I wasn't sure whether PC uses decimals or hex for internal sysex or other midi processing, but I now understand all processing is in decimals. |
Processing is binary but display is decimal. You can turn a byte into hex using byte.asHexString(2) -- for display -- the result is a String that doesn't do math. (For other bases, there is asStringToBase - more than you needed to know I'm sure )
Good luck, feel free to post with more questions.
James _________________ ddw online: http://www.dewdrop-world.net
