Tronato
Posted: Sat Jan 10, 2009 6:36 pm Post subject:
Deleting Windows 2000 Temporary files question |
Hello!
Is it safe to delete all the files in the TEMP folders or for that matter everything that is XXX.tmp?
Thamks!
TRON Last edited by Tronato on Sun Jan 11, 2009 9:32 am; edited 1 time in total |
Joined: Apr 03, 2004 Posts: 24075 Location: The Netherlands, Enschede
Audio files: 277
Posted: Sun Jan 11, 2009 3:38 am Post subject:
I do it all the time on XP and on Vista too, occasionally for one or a couple of those files I'll get "access denied" when I try, but I've never seen any harm done ... besides it wouldn't be very smart to store files that shouldn't be deleted into a folder called "temp" or any variation there off _________________ Jan
Tronato
Posted: Sun Jan 11, 2009 9:34 am Post subject:
Hello!
You are mentioning Windows XP and Vista... would the same apply to Windows 2000?
TRON |
EdisonRex
Audio files: 172
Posted: Mon Jan 12, 2009 7:52 am Post subject:
Tronato wrote: | Hello!
TRON |
Yes, and Windows 98, ME, 95 and DOS all had the same mechanism.
The locked ones are currently open, otherwise you can delete them.
You can also delete anything in Temporary Internet Files as well, including all those little annoying subdirectories. IE (you don't use any other browser right? ) will rebuild. - you can of course go into IE and under tools -> internet options, delete browsing history and find the delete all button. _________________ Garret: It's so retro.
Tronato
Posted: Mon Jan 12, 2009 10:55 am Post subject:
Hello!
I did a search for all *.TMP files and thousands appeared. However, when trying to delete some of them I received the message that there was a "sharing violation and that most probably the file was in use"
This means that they are indeed used sometimes.
What is the best method to eliminate unused temporary files?
TRON |
EdisonRex
Audio files: 172
Posted: Tue Jan 13, 2009 4:11 am Post subject:
the way I use is to use a command prompt.
C:\> cd temp
C:\temp\> del /b /s /q *.*
Be very careful using the del command, and especially the /s switch, as doing this at the C:\ root directory can have particularly bad consequences.
I'd also recommend doing regular backups of your data at least. _________________ Garret: It's so retro.
