  bingsatellites Mostly Ambient
 Forum index » DIY Hardware and Software » Supercollider
I'm Fueled like the Gasman
Post new topic   Reply to topic Moderators: v-un-v
Page 1 of 1 [11 Posts]
Maks
PostPosted: Wed Jan 14, 2009 3:40 am    Post subject:  I'm Fueled like the Gasman Reply with quote  Mark this post and the followings unread
I just discovered Supercollider. Well, I downloaded it 2 years ago but couldn't then figure out how to start it. The new build seems easier in that sense, so I will be taking the plunge. I'm excited! Crying or Very sad
From what I can hear, the timing (using the latency bundle) is alot more stable than Max/MSP, sounding basically as good as internal MIDI in say Digital Performer. YEY! I am sick of shitty Max scheduling.
Sine waves might just be a bit more velvety than MSP as well.
Good night.
dewdrop_world
PostPosted: Wed Jan 14, 2009 12:48 pm    Post subject: Re: I'm Fueled like the Gasman Reply with quote  Mark this post and the followings unread
I guess you're talking about Windows then Smile The Windows version has improved a lot, especially around the beginning of last year.
Yes, timing with bundled messages is very good. Used to be buggy in Windows but it's been working fine for me lately.
Consider taking a look at JSCEclipse - the code editor in Psycollider is pretty rudimentary. Eclipse has a really nice code editor with built-in help features (look up method templates by mousing over the method name, autocompletion). It's a bit more work to set up and Eclipse is a memory hog but to me it's worth it.
James
Maks
PostPosted: Thu Jan 15, 2009 10:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually I was using a mac back then, but oh well.
I have been virtually leafing the some of Dave Cottels writings on SC, very very informative.
I have ran into one problem and that is I am unable to create a file path to save audio recordings with.
The code I have been presenting is
s.prepareForRecord("SC_Files/audio/rec1"); //rec1 is the name of the file
I am staring at a folder on my desktop called SC_Files, and inside is a folder called audio!
I keep getting this error message:
localhost
File 'SC_Files/audio/rec1' could not be opened. 'System error.'
Que??
(I tried this as well ---- s.prepareForRecord("/SC_Files/audio/rec1"); )
dewdrop_world
PostPosted: Fri Jan 16, 2009 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've given a relative path, which takes as its starting point the folder containing supercollider.app.
If you want the desktop, use ~/Desktop/SC_Files/... (it does assume a little familiarity with UNIX-style paths. A path starting with / goes from the machine's root. ~ indicates the user's home folder -- which is not the same as the desktop. In OSX, there is a folder called "Desktop" in the home folder -- hence, "~/Desktop".)
You can also change the default location for recordings:
thisProcess.platform.recordingsDir = "[path to folder]";
And check the default location:
thisProcess.platform.recordingsDir;
James
Maks
PostPosted: Fri Jan 16, 2009 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks a bunch!
Maks
PostPosted: Fri Jan 16, 2009 6:00 pm    Post subject: Reply with quote  Mark this post and the followings unread
[~/Desktop/SC_Files/audio]
localhost
File '[~/Desktop/SC_Files/audio]/SC_090116_194935.aiff' could not be opened. 'System error.'
What the heck!
Is my path wrong still?
dewdrop_world
PostPosted: Fri Jan 16, 2009 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
localhost
What the heck!
Why are the brackets in there? '[~/Desktop/SC_Files/audio]/SC_090116_194935.aiff' is not a valid path, but ~/Desktop/SC_Files/audio/SC_090116_194935.aiff should be. Try this as a quick test:
f = File("~/Desktop/SC_Files/audio/test.txt", "w");
f.close;
or list the directory:
"ls ~/Desktop".unixCmd;
"ls ~/Desktop/SC_Files/audio".unixCmd;
If it still doesn't work, try prepareForRecord("~/Desktop/SC_Files/audio/some_file.aiff".standardizePath) which should turn the ~ into the physical location.
James
dewdrop_world
PostPosted: Sat Jan 17, 2009 9:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, oops, I put the brackets in! My bad... I meant for everything inside the brackets (including the brackets) to be substituted with your file location... but didn't say so. Embarassed
James
Maks
PostPosted: Sat Jan 17, 2009 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
James,
Thanks so much for helping, but I have to say nothing is working.
Look here, I tried this:
thisProcess.platform.recordingsDir = "~/Desktop/SF_Files/audio";
s.prepareForRecord;
ERROR Mess:
localhost
File '~/Desktop/SF_Files/audio/SC_090117_174641.aiff' could not be opened. 'System error.'
if this doesn't work, what would?
Your dealing with an utter beginner here.......If you could possibly see what is the problem that would be great.
I tried having SC search the contents of the filepath, and that did work.
Well, I'll keep trying to fiddle with it but its like shooting in the dark at this point.
Best,
Max Evil or Very Mad
dewdrop_world
PostPosted: Sat Jan 17, 2009 9:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
thisProcess.platform.recordingsDir = "~/Desktop/SF_Files/audio".standardizePath;
What I overlooked is that the server doesn't automatically convert ~ into a real location, so it's necessary to call standardizePath on the string when setting the recording dir.
On my machine:
"~/Desktop".standardizePath;
prints:
/Users/dewdrop/Desktop
James
Maks
PostPosted: Sun Jan 18, 2009 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Your are the MAN!
Thanks again!
JuneSolstice2013
