Posted: Wed Jan 14, 2009 4:42 pm Post subject:
the module is finished and working - indeed there has been one faulty potentiometer and two LED have been reversed by the technitian
here some pix. no sounds yet, i will have to go to bed and i will have to spend the next two evenings with my girl. so sounds sample hopefully on weekend.
don't look too sharp - i really had a bad time with the panner-fader proto: all transistors were reversed and i had to resolder them all...
fonitronik at
FlickR (pix) / SoundCloud (sounds) / YouTube (vids) / Vimeo (vids) / facebook (news) |
Rvlt
Posted: Wed Jan 14, 2009 9:10 pm Post subject:
wow, looks great!
I would take two Panfader-PCBs. (already built a mono-version). |
Funky40
G2 patch files: 5
Posted: Thu Jan 15, 2009 1:19 am Post subject:
| fonik wrote: | | ericcoleridge wrote: | The Panner PCB can also be configured as a 'fader'? As is x-fader/cross-fader?
Is this so Fonik? |
it is a fader and a panner at the same time. why? just because it does x-pan/x-fade: the left input is at the left output, while the right input is at the right output. then you x-fade/x-pan it until left in is at right out, and right in at right out. so the left output shows the left input first and then fades to the right input signal. looking at it the other way around the left input signal is first at the left output and then at the right output.
clear as mud: looking at two inputs but one output it is a fader, looking at one input but two outputs it is a panner.  |
Thîs would be then more a kind of a Stereo Crossfader not ?
It is strange, i just was thinking in this Moment that i need such a circuit.
Me too have 2 old Resonator VCF Boards.
Can i use those or should i better get the new one ? i like to get something similar as you have built
and yup, thanks for the effort ! |
Posted: Thu Jan 15, 2009 2:52 am Post subject:
| Funky40 wrote: | | fonik wrote: | | ericcoleridge wrote: | The Panner PCB can also be configured as a 'fader'? As is x-fader/cross-fader?
Is this so Fonik? |
you could use the old boards, you would just have to wire the outputs of each single resonator to one input of the stereo-x-cross-panner-fader-whatever-you-call-it PCB. _________________
fonitronik at
pdman1
Joined: Mar 28, 2007 Posts: 48 Location: North Shore Massachusetts
Posted: Thu Jan 15, 2009 11:20 am Post subject:
| I'll take two of the X-panfaders and possibly 1 ps3100 pcb |
Posted: Thu Jan 15, 2009 4:16 pm Post subject:
girl's gone to sleep, i did a very first sample with my new PS3100 DoubleTrouble. This is not for showing isolated functions, but the sound of the PS3100 DT in musical context (SN voice controlled by Klee2).
PS3100 DT setup as follows: internal LFO controls 1st and 3rd Resonator, 3rd Resonators CV inverted. internal LFO controls pan, too.
Klee2 CV controls the SN Voice (fed to harmonic suboscillator). one Klee2 gate controls x-pan of PS3100 DT, other Klee2 gate controls 2nd Resonators freq.
First you'll hear the dry signal (just the SN voice + sub oscillator - however one Klee2 gate crosstalks), then the wet signal.
in the middle i switch the sn voice to noise.
http://www.modular.fonik.de/sound/PS3100_DT_001.mp3 821 KB _________________
fonitronik at
Posted: Mon Jan 19, 2009 1:28 pm Post subject:
i recorded some sound snippets to demontrate what the PS3100 DT is doing.
| x-faderpanner only, fading: the two VCOs to left and right input, only right output used (fading, mono). |
 Download |
| Filename: |
PS3100_DT_006.mp3 |
265.23 KB |
| Downloaded: |
407 Time(s) |
| x-faderpanner only, x-panning: the two VCOs to left and right input, both outputs used (x-panning, stereo). |
 Download |
| Filename: |
PS3100_DT_005.mp3 |
456.9 KB |
| Downloaded: |
382 Time(s) |
| x-faderpanner only, panning: both VCOs to left input, both outputs used (panning stereo). |
 Download |
| Filename: |
PS3100_DT_004.mp3 |
488.34 KB |
| Downloaded: |
388 Time(s) |
| squarewave from TH 8038 VCO fed into the PS3100 DT. external LFO controlling VCOs freq, resonator #1 freq and spread... |
 Download |
| Filename: |
PS3100_DT_003.mp3 |
206.68 KB |
| Downloaded: |
413 Time(s) |
| TH 3038 VCO fed into PS3100 DT. nothing else, just switching between different modes, no spread (mono), manual spread, inverted CV for resonator #3, LFO cnotrolls spread, and so on... |
 Download |
| Filename: |
PS3100_DT_002.mp3 |
610.39 KB |
| Downloaded: |
438 Time(s) |
fonitronik at
crashlander42
Joined: Oct 21, 2006 Posts: 276 Location: Orlando, FL (US)
mono-poly
Joined: Jul 07, 2004 Posts: 931 Location: Rotterdam, Netherlands
Posted: Tue Jan 20, 2009 8:42 am Post subject:
| me want! |
numbertalk
Posted: Tue Jan 20, 2009 10:38 am Post subject:
| Very exciting. Not sure if you're starting to take count to get a rough idea of what your run will be but I'm in for 2 Resonator PCBs and 4 Panner/Fader PCBs. |
lexvortex
Posted: Tue Jan 20, 2009 11:09 am Post subject:
| I would definitely be in for 1 or 2 panner/fader PCBs |
Funky40
G2 patch files: 5
Posted: Thu Jan 22, 2009 3:33 am Post subject:
| crashlander42 wrote: |
must have. |
+1 |
johans121
Joined: Jun 19, 2007 Posts: 174 Location: Memphis, TN (USA)
Posted: Thu Jan 22, 2009 1:25 pm Post subject:
Can't wait to get me on a couple of these
+2 please!!
 _________________ Don't feed me Indian, you WILL regret it!
-Jim |
goiks
Posted: Fri Jan 23, 2009 3:57 pm Post subject:
+1 Resonator pcb
+2 Fader Panner pcb
Thanks! |
fadeddata
Joined: Dec 27, 2004 Posts: 43 Location: Nashville TN
Posted: Fri Jan 23, 2009 7:09 pm Post subject:
Hello!
I'll take two of each!
Thanks Much,
-dustin |
whomper
Krelnarb
Joined: Dec 04, 2007 Posts: 23 Location: Richmond, CA
Posted: Sat Jan 24, 2009 2:02 am Post subject:
Please add me to the list, 2 each of the PS3100 & the Xpanfa.
The PS3100 sounds fantastic by the way.
Thank you |
Posted: Sat Jan 24, 2009 8:05 am Post subject:
okay, you guys want me to start a list for advance orders? i did not plan this for now, since i will have to pay for the TH SCM PCBs first. so it will take a while until i can order the resonators/panner pcbs. woud mid-march for delivery be okay with you all?
however, i start the list on monday and will calculate the price for the panner PCB... _________________
fonitronik at
LektroiD
Joined: Aug 23, 2008 Posts: 960 Location: Scottish Borders
Posted: Sat Jan 24, 2009 1:41 pm Post subject:
That sounds great, one of each for me  |
ericcoleridge
Posted: Sat Jan 24, 2009 10:09 pm Post subject:
Fonik,
Do you have a general range for the x-pan/fader price? Probably under $10US, yeah?
Depending on price, I'd like 4 to 6 Pan/Fader PCBs. |
davemoog
Posted: Sun Jan 25, 2009 10:05 am Post subject:
3rd run of PCBs for the PS3100 Resonators & the X-panfader |
I'd be interested in boards for this as well. Looks and sounds like great project!
Thanks |
Posted: Mon Jan 26, 2009 5:25 am Post subject:
i start a list for advance orders by now. everyone interested should tell me the quantity he definetely wants. that would be very helpful. don't hesitate to contact me via PM, email or by posting in this thread (even if you already did it).
PRICING:
(under the assumption of minimum advance orders for 50 PCB each to make the manufacturing happen):
PS3100 PCB 13.-USD/10.-EUR
X-Panner PCB 10.-USD/7.50EUR
+ packaging & postage
7.-USD worldwide
2.50 EUR europe
2.- EUR deutschland
PCBs should be available mid-march, i guess. _________________
fonitronik at
TekniK
Posted: Mon Jan 26, 2009 6:31 am Post subject:
Matthias,how does the VC has been implemented on the panner?
symmetrical,asymmetrical and what are the voltages?
Regards |
slo
Joined: Feb 18, 2007 Posts: 200 Location: Victoria, BC
Posted: Mon Jan 26, 2009 7:45 am Post subject:
1 resonator and 1 panner pcb please.
George |
