help!!!w/sequencers
Page 1 of 1 [10 Posts]
settle
PostPosted: Thu Oct 07, 2004 4:25 am    Post subject: help!!!w/sequencers Reply with quote  Mark this post and the followings unread
i really hope i can explain this deadend i always hit when im trying to build my dream seqeuncer in the nord. here it goes-
i am using the notesequencer to control the pitch of my main oscillators, and the trigger/gates below the note sliders(on the notesequencer) to trigger the opening of the envelope. i want the note sequencer to only send a change to the pitch on my oscillators when i trigger the envelope, so when i have a long decayon the envelope, the pitch of the oscilator doesnt change during the decay. know what im sayin? please!!!
an example of what i want to do is here
http://www.sq4.be/
Audio files: 216
G2 patch files: 319
PostPosted: Thu Oct 07, 2004 4:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Can't try here without a G2, but Id think you can use a sample&hold or a track&hold to do what you want.
Connect the yellow sequencer output to the yellow input on the sample/track&hold and the blue signals likewise.
For the sample&hold some delay in the blue signal might be needed (use a note quantizer or a mixer or anything that's blue and can be set to unity gain for it).
The track & hold might give a small glitch, although probably it will be unnoticable. If not use a glide in the blue signal set to some mili seconds.
Jan.
settle
PostPosted: Thu Oct 07, 2004 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
hmm...this is the key hey? ill try it out in the morn...thanks blue.
settle
Audio files: 143
PostPosted: Thu Oct 07, 2004 9:03 am    Post subject: Reply with quote  Mark this post and the followings unread
A trick I've used is along with the S/H is to block new triggers and gates with an AND gate where one of the inputs is fed by the envelope via a comparitor. New notes are allowed only when the envelope is less than 1. If you do this in Poly mode it works well. You'll never get a note that's mangled while it's still playing.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Thu Oct 07, 2004 2:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Settle, I uploaded a demo patch that might answer your question.
Read the description and download it at this post in the experimental patch forum.
Audio files: 143
PostPosted: Thu Oct 07, 2004 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, Zynth. You don't even need a comparator. The AND gate sorta has them built in. Cool
settle
PostPosted: Thu Oct 07, 2004 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, thank u again. so, this is where i start to learn the logic modules? slowly. is there a tutorial of how to use logic stuff in the nord, or did u all just have to learn them by trial and error?
tanx
settle Very Happy
settle
PostPosted: Thu Oct 07, 2004 5:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh...shit. shoulda googled before asking.
http://www.cim.mcgill.ca/~clark/nordmodularbook/nm_logic.html
Audio files: 143
PostPosted: Thu Oct 07, 2004 6:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's a good place to learn this stuff. The basic funcitions of logic gates and flipflops are in almost all electronic tech text books used at community colleges.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Thu Oct 07, 2004 7:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
check used books sites for digital fundamentals textbooks....when I first started learning this stuff I bought a used one from the 80's for $3.00 and it had everything I needed to understand the logic gates in the nord.
