8-tap mod delay
Tim Kleinert
G2 patch files: 236
PostPosted: Fri Jan 23, 2009 9:59 am    Post subject: 8-tap mod delay
Subject description: eight modulatable delay taps
If you want to use the full 2,7 seconds of delay time on the DSP, you are limited to one delay module, so the maximum you can have is 4 modulatable taps (the 4tap delay module) per patch. Not good enough.
This building block doubles this amount through multiplexing the readouts. The resulting eight taps are therefore at 48kHz, which by all means still is enough for audio.
tim
EDIT: There was a redundant module in the patch. New version uploaded.
8-tap delay TK.pch2
8 modulatable taps from the 4tap-delay through multiplexing; yields audio at 48kHz
 Filename:  8-tap delay TK.pch2
 Filesize:  2.03 KB
 Downloaded:  943 Time(s)
