MS-20 based SEM / Polysynth ?
Page 5 of 5 [115 Posts]
Goto page: Previous 1, 2, 3, 4, 5
whomper
PostPosted: Fri Feb 06, 2009 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it is interesting. I will be looking forward for this project.
One more note, will you be able to design a supporting PCB that will allow for a single front panel to control the board?
Erez Yaary
Home Page: http://www.yaary.com
Buy my CDs at http://www.mellowjet.de
jhaible
PostPosted: Fri Feb 06, 2009 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
whomper wrote:
This is not so much a question of an extra PCB - it's a question whether to make everything voltage controlled or not.
I think I'll make it all VC'ed - but no promises yet.
JH.
Dan Lavin
Audio files: 20
PostPosted: Fri Feb 06, 2009 7:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Juergen,
This last concept sounds perfect! I was thinking of developing something similar myself, but obviously not if you do yours. I like it!
whomper
PostPosted: Fri Feb 06, 2009 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
whomper wrote:
JH.
I was thinking more in the line of whether it makes sense to create a PCB that allows a single input (POT, JACK..) to be routed to several boards. I am not sure doing a plain multiple will work, some CV buffering...
Erez Yaary
austrohungaro
PostPosted: Fri Feb 06, 2009 12:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
Interesting?
And a slew/lag/glissando/portamento, as in the MS Korgs?
alain6870
PostPosted: Fri Feb 06, 2009 2:17 pm    Post subject:  An interresting Poly voice board Reply with quote  Mark this post and the followings unread
Hello Jürgen,
Nice to see that the Poly project isn't dead. for me its seems essential that everything is voltage controlled as this enables to quickly "midify" everything. I can't imagine a polyphonic synth without the midi option. And with applications such as MIDIBOX (ucapps.de) everything is possible.
What do you think about the design :
- one voiceboard with: 2 Osc, 1 HPF, 1 LPF, 2 Mixers before the filters, 2 ENV, 1 VCA
this is indeed the board I started to design, thinking it would save money because it uses only 2 ENV 1 VCA 1 HPF and 1 LPF pro voice. But I am not sure anymore because of the VC mixer that is also expensive...
At the moment I am wondering about the possibility for FM in poly mode with the technology I know ( ASM VCOs for instance)? This would be a nice option too.
This will be a huge board anyway!!
Very interested I keep in tune.
Kind regards from France,
Alain
hachiman
PostPosted: Sun Feb 08, 2009 11:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
very good to hear about the voltage control.
-thereby one could use an industrial control DA chip with 16-32 channels and 12-14bit accuracy @ 10-20 khz sounds good enough , and pricing isnt that steep either (you wont need another for a while Laughing ) Now if there would be some non compromise datalink between the DA and PC, besides midi, that would be cool , then one could use all sorts of modulated LFO and ENV signals , not necessarily those corny "virtual analog"-s... Smile
JoeMorris
PostPosted: Thu Nov 19, 2009 4:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
This still gonna happen at some point JH?
jhaible
PostPosted: Fri Nov 20, 2009 12:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Sooner or later. Smile
But probably nothing that's close to a SEM anymore, now that Tom Oberheim himself has re-released the real thing!
JH.
whomper
PostPosted: Fri Dec 25, 2009 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Checking the pulse of this project.
I am looking to build myself a poly synth sometime in the near future, so anything coming from you Jurgen will be high on my want list.
Anytime in 2010?
Erez Yaary
jhaible
PostPosted: Fri Dec 25, 2009 1:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
whomper wrote:
JH.
Anytime in 2010?
Probably!
JH.
JoeMorris
PostPosted: Tue Sep 21, 2010 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
still really want to see this! looking possible? or pcbs for the polykorg Wink ?
bennethos
PostPosted: Tue Feb 08, 2011 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm all in for something poly ! If the vco's would have the linear detuning à la CS80 .
Would be great if you could include the possibility to have 6-8 voices by somehow buying a 2nd PCB.
4 voices is better than 1 but just not enough :p .
I have been thinking about building a poly, but it's the price that always kept me from designing such a thing.
I don't care about memory or the ability to save patches either.
What would be important though is types of waveforms that would be made available for the vco etc...
What I would expect to be able to recreate :
Always wanted to hear this great Brass - CS80 sound (with the "living" VCO aspect) .
I'll start saving up already ! Smile
TekniK
PostPosted: Tue Feb 08, 2011 2:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Juergen is going to move into a monastery soon,so forget this project
Wink
jhaible
PostPosted: Tue Feb 08, 2011 2:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wink
Rest assured, I have no such calling. Surprised
JH.
JuneSolstice2013
