 Forum index » Instruments and Equipment » DSI Synths
My Evolver goes crazy whenever I connect both midi in & out
Page 1 of 1 [4 Posts]
yezaev
PostPosted: Mon Feb 16, 2009 11:38 am    Post subject: My Evolver goes crazy whenever I connect both midi in & out
Subject description: Ableton Live, Soundtower Editor, all interfaces
Hey everyone,
every time I connect both the midi in and out of my evolver at the same time, it very quickly goes nuts - won't respond to front panel controls (or editor controls) and will only make strange sounds if any.
As soon as I disconnect the midi out, it goes back to normal.
What's going on here? I can't use the editor at all because of this. Any ideas?
seraph
Editor
Editor
Audio files: 31
PostPosted: Mon Feb 16, 2009 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
it sounds like a midi loop.
Politics is the entertainment division of the military industrial complex - Frank Zappa
williamsharkey
PostPosted: Mon Feb 16, 2009 4:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
go into a midi menu and turn local control off.
yezaev
PostPosted: Wed Feb 18, 2009 6:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks guys for the tips... I made sure to check that poly mode was off and whatever midi settings I could think would cause a feedback loop. I didn't have a lot of chance to play with it but I played in the editor for almost 20 mins which is about 18 more than usual so that's a positive sign!
Niio2
