synthmonger
Posted: Thu Feb 19, 2009 8:24 pm Post subject:
| bbob wrote: | | synthmonger wrote: | | This is all lunetta minus the CA3080 VCA and op-amps used for the EF, EG and mixer....which could've been done with a 4069 ;x |
beautiful thang... now matrixsynth, so i'll bet someone snaps it up. what circuit did you use for the envelope follower?
b |
Same one from the nurse quacky, with a spare op-amp as a typical gate converter. |
slacker
Posted: Fri Feb 20, 2009 2:10 pm Post subject:
| synthmonger wrote: | | slacker wrote: |
It's actually aluminium, the photo makes it look much shinier than it is. It's stuff the you use to make splashbacks for your kitchen work tops. It's cheap and it's just about stiff enough.
Where'd ya get the panels? |
I got the aluminium sheet for the panels from B&Q, a big UK DIY/home improvement superstore.
The sheets are 12cm x 100cm, and I just used tin snips to cut the panels to size and cleaned up the edges with a file. |
RF
Joined: Mar 23, 2007 Posts: 1481 Location: Northern Minnesota, USA
Audio files: 28
Joined: Apr 03, 2004 Posts: 19570 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sat Feb 28, 2009 10:21 am Post subject:
| RF wrote: | | So I started my Lunetta 2.0 this week |
wow, this starts to look like brain surgery  _________________ Jan |
RF
Audio files: 28
Posted: Sat Feb 28, 2009 10:45 am Post subject:
| Blue Hell wrote: |
wow, this starts to look like brain surgery  |
lol - the flying wires have gotten a bit out of hand, haven't they?
Actually though, I just mentioned in a PM that it's nice to not have to use the brain much putting these together. Peek at the data book, add a few resistors & bypass caps and send the IC pins to the panel...
Don't be put off building one of these by my mess!
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 275 Location: Indianapolis, Indiana
Audio files: 43
Posted: Sat Feb 28, 2009 11:47 am Post subject:
Looks like a great start and if 1.0 is any indication, should sound great too..
Any new modules you'd care to share schematics of on this thread, rf? I'm curious what other chips i might use if I make a 1.5 side-kit Lunetta. Not sure at this point whether it's necessary as I've been getting crazy sounds out of the suitcase I have. |
Audio files: 116
G2 patch files: 317
Posted: Sat Feb 28, 2009 11:58 am Post subject:
| RF wrote: | lol - the flying wires have gotten a bit out of hand, haven't they? |
It looks great actually, as in "nice picture"
And indeed people should not feel intimidated to much; after all one starts with one wire and then it builds up a bit ...  _________________ Jan |
droffset
Joined: Feb 02, 2009 Posts: 480 Location: new zealand
Posted: Sun Mar 01, 2009 5:54 am Post subject:
wow it's a lot of wiring, hehe.
Here's another iteration of mine, starting to fill out more bits.
The 40106 oscillators and some other stuff lives on another panel
Can't wait to fire it up! |
Rykhaard
Posted: Sun Mar 01, 2009 5:26 pm Post subject:
Deleted, manually. Last edited by Rykhaard on Fri Nov 04, 2011 3:45 pm; edited 2 times in total |
RF
Audio files: 28
Audio files: 43
Posted: Mon Mar 02, 2009 12:41 am Post subject:
you guys are doing some great stuff! Keep it up. |
stolenfat
Joined: Apr 17, 2008 Posts: 430 Location: Sunny Oakland California
Posted: Mon Mar 02, 2009 12:49 am Post subject:
| wow! every one: awesome job! all i need is some sort of jig to slice some wood i found to start making panels. |
slacker
Posted: Mon Mar 02, 2009 4:34 am Post subject:
Great looking stuff, can't wait to hear 'em.
I like the way this thread has suddenly sprung to life. |
Rykhaard
Posted: Mon Mar 02, 2009 9:06 am Post subject:
Deleted, manually. Last edited by Rykhaard on Fri Nov 04, 2011 3:45 pm; edited 1 time in total |
theMinister
Joined: Jun 09, 2007 Posts: 14 Location: North America
Rykhaard
Posted: Mon Mar 02, 2009 10:00 am Post subject:
Deleted, manually. Last edited by Rykhaard on Fri Nov 04, 2011 3:46 pm; edited 1 time in total |
RF
Audio files: 28
Posted: Mon Mar 02, 2009 10:26 am Post subject:
Looks great, theMinister! I'm curious also as to what you have in the box and what is planned to be added.
I moved almost a year ago now - it does take a while to get settled. Welcome back!
theMinister
Posted: Mon Mar 02, 2009 2:55 pm Post subject:
thanks guys.
currently working on getting everything soldered to go in the case.
8 x 40106 oscs, 4 with sync out 4 with sync in (as per the bugbrand design)
4 x nand gate oscs each with an input jack so they can be modulated (based on the nic collins book)
the big section of jacks in the middle will be for some gates of some sort, i have to check and see what chips i have. there's also a row for 1 and a row for 0, somebody's layout had that, i thought it was cool.
the colomn of 1/4" and banana jacks is the mixer section. four inputs each with an output and a master/head phone out.
i realized as i was putting everything in that i forgot a power switch and volume control so that will probably stick out like a sore thumb.
i don't really plan on labeling anything, maybe just with lines connecting related things together. the layout is such that inputs are above their respective outputs. on the oscs with an in and out the pot is in the middle.
the case is from a touch and tell, one of my first circuit bending attempts. i fried something and threw it in the corner and left it for dead. that was three-ish years ago. and my wife thinks i should start thowing stuff out, ha!
hopefully by the weekend i'll be posting the finished product with some sounds. i'm pretty anxious to hear it all together off the breadboard.
i really have to thank everyone for motivating/guilting me into this stuff again. everybody on this board does such amazing things. |
monokinetic
Posted: Tue Mar 03, 2009 11:55 pm Post subject:
@RF:
This is a slightly nerdy question, but which gauge of cable are you using for your flying wires brain surgery work of art? I have to do most of my ordering online so I can't really judge which cable would be suitable for me
Or does anyone else have any recommendations?
TIA
David |
Pehr
Joined: Aug 14, 2005 Posts: 1306 Location: Björkvik, Sweden
Rykhaard
Posted: Wed Mar 04, 2009 1:10 am Post subject:
Rykhaard
Posted: Wed Mar 04, 2009 1:13 am Post subject:
monokinetic
Posted: Wed Mar 04, 2009 2:11 am Post subject:
Cheers Rych,
You really are wonderfully helpfull
BTW This weekends project is to strip board your new oscillator, but thanks for the offer of PCB in the other thread
David |
droffset
Posted: Wed Mar 04, 2009 4:15 am Post subject:
Oh hell yes. My Lunetta might not look like much but she's a screamer alright. Did some playing around with it this evening and, oh yes, you can bet I'm going to add some more oscillators and Ics. yayyyyyyyyy.
Will also make it prettier. That's the easy part.
Also need to sort out a better power hub. You can see where the modules are branching out from, on that bit of perfboard are some power caps.
I'm afraid to plug it into my sound card, do you think i'll ruin something?
RF
Audio files: 28
