naw0r
Posted: Sat Mar 14, 2009 11:04 am Post subject:
How do i use alesis micron with cubase?! Subject description: please help |
Im using an alesis micron connected via a midi usb cable to a dell inspiron 6400 laptop.
the software im using is cubase essential 4.
when all plugged in no sound is created but the 'midi in activity' volume bar rises and falls as though there is.
cubase apperars to be recognising the keyboard as it shows it as an option for output routing. when selected no sound comes through. if i change it from 'usb audio device' to 'windows gs wavetable sw synth' i can use the keyboard to play a piano sound but it is incredibly delayed and incorrect.
i want to be able to record sounds made by my micron into cubase. how can i do this when the above is happening? how can i fix this?
i would really appreciate any help or advice.
thanks |
Joined: May 16, 2005 Posts: 8902 Location: Birmingham, England, UK
Posted: Sat Mar 14, 2009 11:10 am Post subject:
Please do NOT double/ quadruple post! It is against forum rules. Thanks _________________ ACHTUNG!
BobTheDog
Posted: Sun Mar 15, 2009 4:30 am Post subject:
How are you getting the audio from the micron into the laptop?
Andy |
naw0r
Posted: Sun Mar 15, 2009 12:24 pm Post subject:
usb to midi in out |
im using a midi to usb cable.
theres a midi in and a midi out cable that go into the back of the micron with both connect to a small black box. from the black box theres a usb cable. this is connected to my laptop.
the light on the box marked 'in' blinks when i play the micron, showing that signal is being communicated.
i hope this helps |
Joined: Apr 03, 2004 Posts: 19582 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Sun Mar 15, 2009 12:32 pm Post subject:
You'll need an audio cable too as MIDI is not for audio signals. Does your computer have an audio input? _________________ Jan |
naw0r
Posted: Mon Mar 16, 2009 4:57 am Post subject:
What does it look like ? |
| I may do but I'm not sure. What does it look like? |
Posted: Mon Mar 16, 2009 5:59 am Post subject:
Have you looked at the manual yet?
http://www.alesis.com/micron
If not, try reading it. A manual is written to help you understand how something works.
Alternatively, try Googling "jack plug +audio output". If reading is far too taxing for you, press the "images" button.
naw0r
Posted: Mon Mar 16, 2009 12:47 pm Post subject:
| i have a thing which will convert a large jack plug (guitar lead type thing) into the smaller kind (earphones etc), shall i plug that in the microphone input? |
Posted: Mon Mar 16, 2009 1:14 pm Post subject:
I wouldn't bother using those adaptors- these things are quite unreliable. It would be best to read the manual and find exactly what you need to get. Get some proper leads A decent soundcard too (usb based)
FWIW, you are going to get really stuck if you don't read the manual- especially when you get to working with Cubase! _________________ ACHTUNG!
BobTheDog
Posted: Tue Mar 24, 2009 7:14 am Post subject:
| Even after you have read the manual in fact! |
Posted: Tue Mar 24, 2009 8:08 am Post subject:
| BobTheDog wrote: | | Even after you have read the manual in fact! |
Don't confuse the poor boy!
Yeah- while we're at it, Cubase sucks.  _________________ ACHTUNG!
