NM Classic: Can somebody help?
Page 1 of 1 [3 Posts]
fmq75
PostPosted: Wed Oct 20, 2004 1:12 pm    Post subject: NM Classic: Can somebody help? Reply with quote  Mark this post and the followings unread
i have a nord modular and a nordlead 2 and i want to control the switches and buttons in my patches from the nordlead buttons.
If i program a NL button to switch on the OSC Sync (for example)it always switch just one time,and that`s all.It's not possible to switch it on again or to switch through osc waveforms or filtertypes.why?
It must be wonderfull to use ALL controls from the NL panel...
please help ;-)
thanx,frank
Audio files: 116
G2 patch files: 317
PostPosted: Wed Oct 20, 2004 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Welcome to the forum Frank.
Apparently the nl2 sends out one particular controller value each time a button is pressed.
It would have to send an incremented value each time a button is pressed in order to make it work. And I think the increment would have to be adjustable as well as the total range of values ( 0 .. 127) is divided equally over a button range for the NM Classic (AFAIK) and so it depends on how many buttons there are in the set.
Jan.
Rob
G2 patch files: 109
PostPosted: Wed Oct 20, 2004 2:32 pm    Post subject: Re: NM Classic: Can somebody help? Reply with quote  Mark this post and the followings unread
fmq75 wrote:
please help Wink
thanx,frank
For radio buttons the NL sends only the smallest values in the range of a cc#. E.g. when a button selects four functions the cc# will send the values 0, 1, 2 and 3, while the possible range is from 0 up to 127. On a Modular these values would not control buttons properly, as on the Modular a button range is scaled in equally big sections over the 0 to 127 range, e.g. a radiobutton with four positions would have to be controlled by numbers in the ranges 0-31 for the first button, 32 to 63 for the second button, etc.
Basically its a bit strangely implemented on the Nordlead. The bad thing is that it prevents one from controlling most of the Modular functions from the Nordlead.
Niio2
