| Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features |
| One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!) |
60% |
[ 60 ] |
| 1 PCB = 1 VCO (with many waveforms and inputs) |
40% |
[ 40 ] |
| Total Votes : 100 |
/mr
Joined: Aug 05, 2007 Posts: 223 Location: Elektron City, Sweden
Posted: Sat Mar 21, 2009 6:23 pm Post subject:
| jhaible wrote: | | synthetic wrote: | I assume that daisy-chaining the power is OK? I would probably put in one power jack and hot-wire the four sections together.
I've put 4 connectors there toallow star-wiring.
It will certainly work with daisy-chaning, too.
Wheter there is a tiny difference in terms of absence of interlocking is yet to bee seen. |
I would definitely avoid daisy-chaining in this particular application.
Mostly for psychological reasons, but anyway.  |
synthetic
Joined: Jun 02, 2007 Posts: 76 Location: Glendale, CA
Posted: Wed Mar 25, 2009 3:42 pm Post subject:
| I guess I don't understand why there are four power connectors. Interlocking? |
Krelnarb
Joined: Dec 04, 2007 Posts: 23 Location: Richmond, CA
Posted: Wed Mar 25, 2009 3:58 pm Post subject:
So the star configuration is to avoid interlocking? But except for the cable lengths, once they go to the power distribution board it's electrically identical to them being Daisey chained.
Please tell me if I'm wrong.
Star or Daisey, this VCO(s) is exciting! Thank you so much for all your work.
Cheers. |
/mr
Posted: Wed Mar 25, 2009 4:36 pm Post subject:
| Krelnarb wrote: | | So the star configuration is to avoid interlocking? But except for the cable lengths, once they go to the power distribution board it's electrically identical to them being Daisey chained. |
Only if you use superconductors for power cables.
I personally don't.
Current draw varies with the VCO cycle. The (albeit small, but finite) resistance of the supply lines then makes fluctuations in the supply voltage. The VCOs will be modulated by these variations to some extent if they sit on the same power cable. Since the purpose of the Living VCOs is to actually make use of small frequency differences between oscillators, it is a good idea to minimize such possible errors at least as much as we normally do, if not even more. And normally we have separate VCOs, on separate power cables!
If I would design a board like this myself, maybe I wouldn't even have thought about having multiple power connectors. But now Jürgen has included them, and that's great. If I would daisy-chain them, I would never know if the result is as good as it could be with separate cables. If I use separate cables, it doesn't matter if it is better or if it doesn't matter. Therefore I use weparate cables. I simply don't want to want to know the truth.
(If you're considering daisy-chaining because you don't want to spend 4 connectors on your power supply board, then use 4 cables from the Living VCO board and let them meet in one connector on the power supply board. That's probably better than daisy-chaining.) |
jhaible
Posted: Thu Mar 26, 2009 12:56 am Post subject:
I just want to make sure that nothing will go wrong.
In the JH-5, I *have* the power daisy-chained, btw!
(Only using one connector, and distributing the power from there, on-board.)
But on the JH-5, *I* have control over the power cable lenght (just a few centimeters to the PSU). Someone else my use the Living VCOs in a huge cabinet with a meter of power cable - I wouldn't want the inductance of this shared between VCOs.
In addition to this, I have ferrites on-board for each VCO.
Plus, the "linear detune" feature helps avoiding interlock as well.
(Still not quite ready for testing the board, but almost ...)
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
jhaible
Posted: Fri Mar 27, 2009 5:33 am Post subject:
Started to make tests.
Working under harder conditions, I *did* daisy-chain the power supply.
And the VCOs don't lock!
And in the video, you can see the fluctuating beat rate, at a VCO frequency of about 1.2kHz.
(I didn't touch any knob during the video, and the Linear Detune feature isn't even activated yet.)
JH.
 Download |
| Filename: |
living_beat_rate.MOV |
11.3 MB |
| Downloaded: |
1934 Time(s) |
dingebre
Joined: Aug 10, 2008 Posts: 232 Location: Salt Lake City, UT USA
Posted: Fri Mar 27, 2009 7:55 pm Post subject:
OK, so forgive me for being a little slow...
"not locking" is a good thing right? Sort of the idea behind the "living" part of this trio of VCO's?
Thanks for the video. The videographer reflected in the scope display looks strangely familiar, like someone who spends a lot of time holding a soldering iron : )
I am quite excited to build these things!
David _________________ David M. Ingebretsen, M.S., M.E.
dingebre@3dphysics.net
http://www.xmission.com/~dingebre/Synthasystem.html |
jhaible
Posted: Sat Mar 28, 2009 2:51 am Post subject:
| dingebre wrote: |
"not locking" is a good thing right? |
Yes! Locking prevents a pair of VCOs beating at a very slow rate: When the two frequencies are too close together, they sync. With some exceptions (I only know one!) this is a bad thing. That's why this is the first thing I've tested: With 3 VCOs being in such close proximity, I wanted to be certain that it doesn't happen. It tested good!
| Quote: |
There's more to the "living" part. Not locking is standard - that's nothing special.
The two main features that made me choose that name are the linear detuning feature that allows low frequency mistracking as known from linear (Hz/V) VCOs, and the right amount of built-in pitch fluctuations that has been inspired by the EMS VCS3.
More later, as testing proceeds.
dingebre
Posted: Sat Mar 28, 2009 8:55 am Post subject:
| jhaible wrote: |
JH. |
OK. I re-read the information on your site and in other posts. I am slowly getting the idea. It's more interesting and appealing the more and better I understand.
Thanks JH
jhaible
Posted: Sun Mar 29, 2009 4:31 pm Post subject:
First audio demo!
13.5 MByte mp3
First dry: just VCOs thru VCA.
Then VCOs thru SSM2040 filter, VCA and Reverb.
http://www.jhaible.de/living_vcos/living_vcos%20_1.mp3
Picture from the testbench:
http://www.jhaible.de/living_vcos/jh_living_vcos.html
dingebre
jhaible
Posted: Sun Mar 29, 2009 11:48 pm Post subject:
| dingebre wrote: | Nice!
I'd like to start on a panel design. Will the controls be comparable to the JH-5 VCO pictured on your web site?
David |
Almost. Some minor details may be different.
3 ten-turn potentiometers instead of 2, maybe.
dingebre
loss1234
jhaible
Posted: Fri Apr 03, 2009 2:30 pm Post subject:
taking pre-orders now! |
the pre-order phase of my "living VCOs" project has begun.
(See http://www.jhaible.de/living_vcos/jh_living_vcos.html
for details about the project.)
Pricing is EUR 27.00 per board (that's for 3 VCOs plus an oscillator driver!)
plus a single EUR 6.00 shipping flat charge for worldwide shipping,
regardless how many boards you are ordering and where you live.
It does *not* include any customs fees or tax that you may (or may not) have
to pay in your county.
What you get is a double-sided printed circuit board with component overlay,
approx. size 160mm x 100mmm.
You have to buy the electronic components for this, and build the device,
yourself. (Check the above website regularly for updates and building hints,
bill of matrials etc.)
If you want to place a pre-order, please send me an email to the following
adress:
jhaible@debitel.net
and use the FOLLOWING FORM (fill in your data instead of [],
for instance: "2 Boards" instead of "[quantity] Boards")
===== Start of Email Order Form ===============
Subject line: Living VCOs PCB order: [quantity] boards
Email text:
I'm ordering [quantity] pieces of the Living VCOs PCB
for EUR 27.00 per board + EUR 6.00 single shipping flat charge for any
number of boards.
I'm aware that I may have to pay additional amounts of customs and tax in my
country.
I'm aware that I'm only buying blank PCBs that may help me building an
electonic module - I'm *not* buying a diy kit, not a "project" - just pieces
of FR4 with copper traces.
I know how to build electronic circuits and I am trained in electrical safety matters.
The seller of these PCBs will not be held responsible for any damage that results
from these PCBs, directly or indirectly.
My shipping adress is
[Your Name]
[Your street, number, city, ZIP code, in exactly the form
that is generally used in your country]
[your country]
My paypal adress is [your paypal adress].
I===== End of Email Order Form =========
Looking forward to hear fom you
johans121
Joined: Jun 19, 2007 Posts: 174 Location: Memphis, TN (USA)
Posted: Fri Apr 03, 2009 3:51 pm Post subject:
Order placed!!!
SWEET! _________________ Don't feed me Indian, you WILL regret it!
-Jim |
dingebre
parasitk
Posted: Sat Apr 04, 2009 7:55 am Post subject:
| order placed! |
numbertalk
Posted: Sat Apr 04, 2009 9:33 am Post subject:
| 2 boards ordered! |
jhaible
Posted: Sat Apr 04, 2009 11:15 am Post subject:
I'm really overwhelmed how many orders came in in such a short time. It's probably the fastest "ramp up" of any of my projects so far!
I start to work on the BOM now. No really exotic components. (Three tempco resistors, of course.)
jhaible
Posted: Sat Apr 04, 2009 1:27 pm Post subject:
BOM is up.
eframp
Posted: Sat Apr 04, 2009 7:03 pm Post subject:
order placed _________________ Eric Frampton, keyboards Atlanta, GA
www.ericframpton.com |
Krelnarb
Posted: Mon Apr 06, 2009 10:49 am Post subject:
order placed for 2.
thank you, |
2thick4uni
Posted: Wed Apr 08, 2009 1:43 pm Post subject:
Hi Jurgen,
Order already placed for 2 boards.
I'm considering using one of the boards in a stand alone performance synth, I can add triangle and sine waveforms easily with a small daughterboard, but is it possible to add sync to two of the VCO's? I understand that a lot of design effort has gone into getting it so the VCO's free run when very close in frequency, but if I could add a sync switch too it would be very useful.
I know that schematic hasn't been posted yet, just need a yes or no at this stage as I'm not sure if the VCO core follows usual integrator / comparator sawtooth design............ |
TekniK
Posted: Wed Apr 08, 2009 2:11 pm Post subject:
| Juergen,is this the design where a part of the 3046 is used already to have a temp compensation inside,but u just add an xtra tempco on it? |
