MN3005 instead of MN3007 in Subtle Chorus
Page 1 of 1 [7 Posts]
dingebre
PostPosted: Sun Apr 05, 2009 1:17 pm    Post subject: MN3005 instead of MN3007 in Subtle Chorus Reply with quote  Mark this post and the followings unread
Is there any utility in using MN3005's instead of MN3007's in the Subtle Chorus? While the packaging is different, I'm not adverse to adapting the MN3005 to fit. If I understand the data sheets (big assumption here) they are compatible and electrically swappable in a circuit with the difference being the delay.
Thoughts?
David
dingebre@3dphysics.net
2thick4uni
PostPosted: Sun Apr 05, 2009 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
IMHO I can't see it being much use as chorus effect relies on a short delay time - assuming same clock speed the MN3005 would increase delay time by a factor of four as it is 4096 stage against 1024 stages for the MN3007. I think you'd loose the chorus effect and have a very short slap back echo instead?
dingebre
PostPosted: Sun Apr 05, 2009 3:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Interesting. Thanks for the explanation. Looks like I need to find a different use for the MN3005's.
David
jhaible
PostPosted: Mon Apr 06, 2009 1:21 pm    Post subject: Re: MN3005 instead of MN3007 in Subtle Chorus Reply with quote  Mark this post and the followings unread
Thoughts?
David
More latency, higher distortion, more noise, too high a modulation index.
JH.
dingebre
PostPosted: Mon Apr 06, 2009 2:16 pm    Post subject: Re: MN3005 instead of MN3007 in Subtle Chorus Reply with quote  Mark this post and the followings unread
jhaible wrote:
Thoughts?
David
JH.
Well... there you go. Off to look for another use. The datasheet has an interesting echo/reverb circuit. I might give that a go...
Thanks JH.
StephenGiles
PostPosted: Tue Apr 07, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
But with a turbo buffered clock running at 5Mhz maybe good chorus with an MN 3005 Rolling Eyes
2thick4uni
PostPosted: Wed Apr 08, 2009 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Datasheet quotes clock frequency as 40khz, I'm intrigued to know how you could get this up to 5mhz.................
