CMOS triple resonant VCF
Page 2 of 3 [72 Posts]
slacker
PostPosted: Tue Apr 07, 2009 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
It uses a high frequency clock which is around 30Khz. This then gets mixed with what ever CV you feed it and that creates a pulse width modulated signal that drives the 4066s. Basically the CV sets the width of the pulse and that sets the resistance of the 4066.
I haven't heard any bleedthrough yet, there is a bit of noise if you sweep the filter really high, but that might not be from the clock.
The original schematic is here http://www.generalguitargadgets.com/pdf/ggg_mxr_envelope_filter_mods.pdf. I've just removed the envelope follower, that's everything from R8 to R23. The CV in goes through a resistor to pin 9 of A1d. The CV response is reversed like this though so I just added a second invertor like the "reverse sweep" mod. Apart from that I just tweaked a few things to improve the frequency range.
The clock is made up of A1a, A1b and A1c.
synthmonger
PostPosted: Tue Apr 07, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well I'll be! I didn't think of using a 4069 as the clocking vco. You should try and work out a sync function. Osamu has a vco that has a faux sync with a 4069 as a vco. I tried it and it works great.
synthmonger
PostPosted: Tue Apr 07, 2009 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a sync demo of my vco clocking 4066 switches in my wasp like vcf. The filters are almost identical, just different caps but both state variable. Mine will self-oscillate though.
http://www.youtube.com/watch?v=RFMUEMy4KI8
synthmonger
PostPosted: Tue Apr 07, 2009 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think I Just figured out how to add a pseudo-sync function to the resonate filter. Gotta love it when things work in threes....
loss1234
PostPosted: Wed Apr 08, 2009 5:06 am    Post subject: Reply with quote  Mark this post and the followings unread
what is this pseudo sync mod?
sounds cool
also..you mentioned you left out a chip on the schematic...where does that go? at the very end
i really want to build this but i am a bit scared of your schematic Wink
seriously though this is a super project
thanks
synthmonger
PostPosted: Wed Apr 08, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
sounds cool
thanks
Using yet another 4007 as a switch to swap out the 1nF caps. The left out chip is just one of the 3 that replace the vactrols.
slacker
PostPosted: Wed Apr 08, 2009 1:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, I'll give that a try, I know the VCO you mean.
I don't suppose you've done a VCA have you? I'm looking for something for my CMOS synth idea.
synthmonger
PostPosted: Wed Apr 08, 2009 1:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm working on a single chip VCA using the 4007 and a tripple using a 4007 and 4069. It's 4th on my list right now though.
Of the 4007 VCA's I found on the net; I tried Osamu's, Rene's and one I found in an ETI article. The eti one worked the best but not as good as I'd hope.
PostPosted: Wed Apr 08, 2009 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Other thread alert (re CMOS vocoder)!!!;
http://www.electro-music.com/forum/topic-27272.html
Introducing Mr Stephen Giles! Cool
ACHTUNG!
synthmonger
PostPosted: Wed Apr 08, 2009 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
After tweaking the resonance again I'm 100% satisfied with it's sound. It can now make synths breath! Wink
Here's a long droney demo of chords coming out of my mt-240 thats running through the filter. The cut off on each filter is being modulated by a triangle LFO. The resonance is only tweaked by my hands and occasionally each of the cut off frequencies.
P.S. If you have a sub woofer hooked up to your computer speakers, I'd suggest keeping it low and gradually cranking it to a suitable level. The bass in the demo gets pretty aggressive! Very Happy
cmos_VCF_reso_fixed.mp3
 Filename:  cmos_VCF_reso_fixed.mp3
 Filesize:  4.19 MB
 Downloaded:  289 Time(s)
richardc64
Audio files: 25
PostPosted: Thu Apr 09, 2009 3:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Against my better judgment, here's a hex vca found I-know-not-where.
Frankly, I think you guys are getting carried away and need to go back and re-read Mosc's introductory post for this forum http://electro-music.com/forum/topic-23850.html and take note of the word "simple."
 Filesize:  8.16 KB
 Viewed:  3661 Time(s)
"It's quite OK to make music with tea spoons and rubber bands!" -- Blue Hell
loss1234
PostPosted: Thu Apr 09, 2009 5:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Well slacker mentioned he was trying to make a NON lunetta CMOS synth....
besides...why knock a gift horse in the mouth!!
synthmonger
PostPosted: Thu Apr 09, 2009 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
True these aren't as simple as one would expect in a Lunetta design. Though it is possible to remove a lot of the components to make them Lunetta. I'll post a more Lunetta version when it's finished.
synthmonger
PostPosted: Thu Apr 09, 2009 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
How does that Hex VCA even work? Seems like it wouldn't due to the pins.
Rykhaard
PostPosted: Thu Apr 09, 2009 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Aye. The Vdd and Vss are connected together to the input of the output opamp??
I don't see where each of the 6 'outputs' are summed to the input of the opamp either ...... scratch
slacker
PostPosted: Thu Apr 09, 2009 8:57 am    Post subject: Reply with quote  Mark this post and the followings unread
I think that VCA is using the gates as voltage controlled resistors, similar to what you're doing with 4007s. If you look at a data sheet that has a schematic of the individual inverters it sort of makes sense.
Rykhaard
PostPosted: Thu Apr 09, 2009 9:09 am    Post subject: Reply with quote  Mark this post and the followings unread
On that posted schematic though, the VCA's outputs aren't going anywhere ...... ? I could bread board one of them of course and see what happens. Very Happy
slacker
PostPosted: Thu Apr 09, 2009 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
I think it makes sense if you look at it as being made up of individual PMOS and NMOS transistors rather than, them being inverter gates.
I think it's basically similar to the VCA from this http://www.uni-bonn.de/~uzs159/vcf4007_s.gif. Pins 1 and 8 on the Hex VCA are the same as pin 7 on Rene's. The outputs are pin 8 and the inputs are pin 6.
synthmonger
PostPosted: Thu Apr 09, 2009 9:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Ahh that makes sense now. Pretty clever.
slacker
PostPosted: Thu Apr 09, 2009 9:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I think you're right, this stuff is definitely stretching the definition of a Lunetta. Nothing wrong with a bit of crossover though in my opinion, after all some people have integrated bits of Lunetta stuff into their modulars.
If I post my filter ideas I'll do it in the general DIY section, hopefully they'll be gentle with me Smile
Thanks for posting that VCA though, I'll try it out.
synthmonger
PostPosted: Thu Apr 09, 2009 10:16 am    Post subject: Reply with quote  Mark this post and the followings unread
I should follow your route slacker and if I can post a Lunetta version here.
loss1234
PostPosted: Thu Apr 09, 2009 10:27 am    Post subject: Reply with quote  Mark this post and the followings unread
synthmonger....the more i look at the schematic..the more i get a bit confused...
i feel like an idiot so sorry if i keep bothering you about this
Ok for the Stage that gets repeated three times....each stage has A and B to control its resistance right? SO my question is...DO i need to make a completely NEW A and B fake vactrol for each stage? (which would mean stage 2 would have C and D, stage three E and F,etc)so a total of 6 4007 based vactrols? Or can i just stick the same out point from A and B to the new stage?
what i am trying to do is redraw it out so i can follow it.
also...in between each stage..do i put a 100k resistor or a cap?
thanks
synthmonger
PostPosted: Thu Apr 09, 2009 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks
My schematic is a big bag off mess, I can totally understand your confusion.
Yeah you need to replace each vactrol with a new 4007. You only one 4007 per stage and only one master resonance CV (this doesn't get repeated). So you have three 4007s for cut off control and only one 4007 for Master Resonance CV.
Just a cap between each stage. They sum together at the input and their outputs go to seperate stages.
Check Fonik's resonators for help. I based mine off that, which is identical to the Korgs but much easier to read.
PostPosted: Thu Apr 09, 2009 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Who thinks this thread should be moved? Is it getting a bit big for its Lunetta boots? I rather like that this thread is within this section, as it is CMOS based, therefore it's pretty nuts, but then again, were getting a bit too confused between something simple and something complex- especially with all these vactrols now being mentioned.
Votes please Very Happy (although Mosc really should have the last word Smile )
ACHTUNG!
synthmonger
PostPosted: Thu Apr 09, 2009 5:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
The Vactrols are apart of the Korg Resonator schematic -not mine. I simply replaced them with PMOS transistors from a 4007.
Niio2
