 Forum index » Instruments and Equipment » Sequencers
Schrittmacher
Page 1 of 1 [2 Posts]
Subotnik
PostPosted: Thu Apr 09, 2009 10:29 am    Post subject: Schrittmacher Reply with quote  Mark this post and the followings unread
Is it possible to play two presets at once? For what use are the four different sequence areas?
I made a preset by the Virus(MIDI Ch.A1), and one by Vermona DRM(MIDI Ch.B1). Is it possible to create one preset, with two different Midi-Tone generators?
Kind greeting from Teufen at Rhein
droolmaster0
PostPosted: Fri Apr 17, 2009 7:00 pm    Post subject: Re: Schrittmacher Reply with quote  Mark this post and the followings unread
Since no one else has answered, I'll jump in here. It's been awhile since I've used a Schrittmacher, though, and I'm not entirely sure that I understand your question.
As I recall, when you save, you're saving the state of the machine. There are 2 midi ports on the Schrittmacher as I recall, so any of these saved states can send stuff to one or both ports.
The 4 sequencer areas are like 4 self contained sequences. You can have individual lines interact with each other, but only within one of these 4 areas.
Not sure if that's helpful.
