Posted: Wed Oct 27, 2004 5:09 pm Post subject:
Ultra Analog synth for WIN and OSX |
Ultra Analog VA-1 - Virtual Analog Synthesizer
The Finest in Analog Sounds
In a world filled with reproductions and ever increasing complexity, Ultra Analog imposes itself as a unique and powerful synth that is fast, easy and remarkably versatile. Ultra Analog offers 32 voices of polyphony and its highly adaptable signal path is driven by two super rich, alias free oscillators featuring standard waveforms, sub oscillators, hard sync, and integrated pitch envelopes. Two audacious multimode filters with distortion are then applied to shape its sonic character. Finally, carefully chosen modulation options are provided by two syncable comprehensive LFOs, four loopable velocity sensitive ADSR envelope generators and vibrato.
Make Music Happen
The superb preset library created by the best professional sound designers will be a sensational journey through all the colors of the analog spectrum whether you are a professional or hobbyist. The Ultra Analog is highly efficient. Find the sound you want fast and tweak it to perfection thanks to the integrated categorized browser and ergonomic interface. What's more, our practical browser enables complete freedom over the organization of your preset library; categorize by songs, styles, events, etc. Whether it's for day to day synth work or particular sound design tasks, Ultra Analog will deliver the entire analog sonic range with every control at your fingertips whenever your creative outbursts demand it.
Ultra Analog is packed with premium performance features, including keyboard modes, portamento and legato functions. Furthermore, in order to follow your groove, Ultra Analog is equipped with a complete set of MIDI features; easy to use "MIDI Learn" function for user defined MIDI maps, min/max parameter range settings, MIDI program change and automation. And for even more action, Ultra Analog provides a user programmable pattern arpeggiator and high quality master effects featuring chorus, delay and reverb.
Ultra Analog Highlights
32 voice polyphonic virtual analog synthesizer
Entirely based on physical modeling for outstanding sound quality
Top quality preset library
Real time calculation of sound - no samples
32bit floating point internal processing
Audio bit-depth and sample rates up to 24bit/192kHz
Integrated audio recorder to capture performance on the fly
Integrated browser and locate function for easy navigation and organization of presets
Import/Export functions for easy sharing of presets
Unlimited undo/redo capability
Standalone operation - no host application required
Standard plugin formats support
Full audio and MIDI hardware support
Simultaneous operation of multiple MIDI ports
MIDI automation and program change support
User defined MIDI maps with MIDI Learn
Module initialization and bypass
High quality integrated master effects: chorus, delay and reverb
MIDI Clock, tap and host tempo synchronization
Dynamic voice allocation and CPU overhead protection
Pricing & Availability
Ultra Analog's MSRP is US$199 and will be available by the end of October 2004.
System Requirements
Windows 98SE, ME, 2000, XP - Pentium III 800MHz - 128MB RAM - ASIO, MME - VST, DXi
Mac OS 10.2 and higher - G4 733MHz - 256MB RAM - CoreAudio - VST, AU, RTAS
_________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
