  bingsatellites Mostly Ambient
LFO Sync problems
Page 1 of 1 [3 Posts]
Thalassa
PostPosted: Wed Apr 15, 2009 10:45 am    Post subject: LFO Sync problems
Subject description: Yusynth LFO v2
I know....I've posted this message yesterday in "LFO problems" , but I think that is better to start a new topic
Hello , I just finish to built the LFO version 2. Everything works fine after calibration Smile but I have a problem with the sync input.
When I connect gate / trigger signal to de sync input I get a pulse that instead a cycle restart. The length of the pulse is dppendent of the flo frequency.
I've made a few tests before post this, I've changed the BS170 for a BC547 , I've changed the BS170 for another BS170.
I've changed the C6 capacitor for new one.
All of this tries didn't solve the problem.
I've attached a picture with the output of the lfo where you can see the pulse when the sync signal is received.
Also I've attached an audio file where the LFO is modulating the filter frequency , and as you can see the (not normal Sad ) pulse length changes when LFO frequency changes.
 Filesize:  125.6 KB
 Viewed:  1329 Time(s)
lfo_sync_834.mp3
 Filename:  lfo_sync_834.mp3
 Filesize:  1.18 MB
 Downloaded:  152 Time(s)
http://www.corsynth.com
yusynth
PostPosted: Thu Apr 16, 2009 7:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Thalassa
I will check this, I think two things can be done, first reduce the value of C6 to 1n, then change the value of R39 (may be just bypass it !).
Yves
Thalassa
PostPosted: Thu Apr 16, 2009 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello Yves, I've done what you said, I've changed C6 for 1,2 n ceramic capacitor ( I don't have here 1n capacitor and this one was the most similar one ) and bypassed R39 and the problem still there Sad
