  bingsatellites Mostly Ambient
PCBs for a Sequential Analogue Switch
Page 2 of 7 [170 Posts]
PostPosted: Wed Apr 15, 2009 6:33 am    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Matt,can u clock it at high very high speed ,and when u switch between audio signals is there an unwanted 'tik' or something audible?
i will try tonight.
fonitronik at
creatorlars
PostPosted: Wed Apr 15, 2009 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
Off topic (maybe), but can you tell me where you got those red momentary pushbuttons? They look great!
PostPosted: Wed Apr 15, 2009 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are not the first who asked Very Happy
i got them from Reichelt.de
this particular momentary is from SCHURTER, a swiss manufacturer operating worldwide.
fonitronik at
crashlander42
PostPosted: Wed Apr 15, 2009 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'd like 2.
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
mono-poly
PostPosted: Wed Apr 15, 2009 7:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
4 plz
Junk Rhythm
PostPosted: Wed Apr 15, 2009 9:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
You beat me to that question. Those pushbuttons look really nice.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
PostPosted: Thu Apr 16, 2009 1:30 am    Post subject: Reply with quote  Mark this post and the followings unread
i did a short test/try yesterday. i did not actually "hear" a "tik".
i fed the tri and the sin output of a VCO into I/O 1 & 2.
1st i clocked it by the square output of this VCO. made sound rich and nice.
2nd clocked it by the first devision of the VCOs square. sounded even more richer harmonically.
3rd i clocked it by another VCO (controlled by a LFO) and i got nice sweeps.
i will have to post same samples these days...
concerning the "tik". not that i have taken a look on the scope yet, but for me it seems obvious that there will have to be "glitches" when you switch between different signals in a not synchronized manner, isn't it natural? i think these artefacts will occur irregulary and more or less recognizable at different clocking times - or ratio signal freq/clock freq? just guessing here.
however the analog switch ICs are break-before-make.
fonitronik at
xpmtl
PostPosted: Thu Apr 16, 2009 2:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Still have all ur previous pcbs to build but yeah i'll take 2
http://www.xpmtl.net
LektroiD
PostPosted: Thu Apr 16, 2009 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Count me in for 1 (definitely), possibly 2 (depending on finances)
My tunes available here
(check out the new Electro-Funk LP)
PostPosted: Thu Apr 16, 2009 6:17 am    Post subject: Reply with quote  Mark this post and the followings unread
that is definetely an issue these days...
fonitronik at
PostPosted: Thu Apr 16, 2009 6:19 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW Farnell stocks the DG412 from Intersil for about 2.-EUR.
fonitronik at
numbertalk
PostPosted: Thu Apr 16, 2009 7:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Actually put me down for 2 boards.
TekniK
PostPosted: Thu Apr 16, 2009 10:37 am    Post subject: Reply with quote  Mark this post and the followings unread
ok,thanks for testing Matt.
To answer on your question ' isn't it natural',well its like the differences between high end desks when u use the mute button to bring in or cut the signal signal,with cheap desks u will have sometimes a 'tik' on high end u will not have a 'tik'
for experimentation using the module in 'audio mode' it will be (very) enoying
PostPosted: Fri Apr 17, 2009 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
BTW thank you all for interest. the PCB will get manufactured.
i decided to provide additional footprints for cliff 1384 sockets (.8in spacing, like doepfer).
for the power i did not implement a MOTM .156 header, but a conventional MTA100 3-pin connector and a ribbon connector (eurorack).
this way the PCB is still generic, but with a thing for euro Wink
hope you are all fine with that.
 Filesize:  54.71 KB
 Viewed:  117 Time(s)
fonitronik at
ach_gott
PostPosted: Fri Apr 17, 2009 8:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yay!
Blech! Wink
The Modcan solution of 3 pin header to 4 pin header cable would work in this case, correct?
TekniK
PostPosted: Fri Apr 17, 2009 9:30 am    Post subject: Reply with quote  Mark this post and the followings unread
damn,i did a search for those DG412,its almost impossible to get!
numbertalk
PostPosted: Fri Apr 17, 2009 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
563 in stock - http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMsn4IaorHFpMJ3iazHtss%2fg
numbertalk
PostPosted: Fri Apr 17, 2009 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
The schematic shows a 4017N, which seems tricky to find - would a CD4017B work as well here?
PostPosted: Fri Apr 17, 2009 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
DG412, MAX313:
Farnell Europe stocks them (from intersil, about 2.-EUR)
Futurlec in Australia stocks the MAX313 (about 6.-USD)
concerning 4017:
yep. the schematic shows the device from the eagle library. other will do well... take a look at the datasheets. the letters indicate different packages or performance criteria (i.e. temperature range).
fonitronik at
numbertalk
PostPosted: Fri Apr 17, 2009 10:23 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
concerning 4017:
Yep, just wasn't sure if any of that criteria mattered here. Thanks!
Norman Phay
PostPosted: Fri Apr 17, 2009 2:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you put me down for 2 of these please, Matthias? Many thanks.
wetterberg
PostPosted: Sat Apr 18, 2009 12:40 am    Post subject:   Reply with quote  Mark this post and the followings unread
Matthias, put me down for two as well - looks like a fun and easy build!
xpmtl
PostPosted: Sat Apr 18, 2009 4:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Would have prefered the standard MOTM header. If u don't have the space can u make the mat 100 a 4 pin one (2 grounds in the middle). That way it would be easier to make 156 to 100 cables.
A .156 header would be best tho Mr. Green
Anyway, thanks for that project matthias Very Happy
krisp14u
PostPosted: Sat Apr 18, 2009 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
I would like the 156 header but if its got to be 100 make it a 4 pin Rolling Eyes
Paul Darlow
www.krisp1.com
PostPosted: Sat Apr 18, 2009 6:51 am    Post subject: Reply with quote  Mark this post and the followings unread
good point. i will do that.
i am not offended, i just want to explain: we have MOTM, DOTCOM and EURO. if i implemented all three headers i would need half of the board to do just this (almost Wink ). there are so many flavours, even about front panel components. so i made a decision this time. i think that is still fine - there are a lot of DIY-boards out there without any standard headers... so "something is better that nothing"?!
fonitronik at
mps board
