shanemorris
Audio files: 83
Posted: Thu Apr 16, 2009 3:13 pm Post subject:
RADIO SCHEDULE |
A live updated version of this schedule with times translated into your local time can be found here
and the playlists, a live view is available here
Connect to the stream here and Join us in the chat room!
Recordings of previous stream sessions can be found here Last edited by shanemorris on Mon Jan 31, 2011 7:07 pm; edited 65 times in total |
EdisonRex
Joined: Mar 07, 2007 Posts: 4571 Location: London, UK
Audio files: 171
Posted: Thu Apr 16, 2009 3:25 pm Post subject:
Remember that GMT is a constant, and daylight savings times add 1 hour to it.
"GMT" is now one hour ahead masquerading as British Summer Time.
We keep GMT as the standard, but add one hour to it, and then calculate for your local time (in daylight or not).
This means that the United States, Eastern Time is five hours ahead of "GMT + 1", so if you want to listen, just add 5 hours. Central time, add 6 hours.
This means that 9pm in GMT is 10pm in British Summer Time (BST), and is 5pm in Eastern Daylight Time (EDT). Winter time is essentially the same 5 hour difference (+1 hour European difference).
Hope this helps. _________________ Garret: It's so retro.
Posted: Fri Apr 17, 2009 7:21 am Post subject:
Paul,
Good to know but probably would just add confusion. If Shane just keeps it all in standard GMT, the times will be correct as someone here in the states would just subtract the normal 4 hours. By the looks of things, you start at 5 PM and I will be listening !!!!
Look forward to it my friend .....
I just got hit with an upper respiratory infection BUT my show will go on next Tuesday !!!
Bill |
Joined: Apr 03, 2004 Posts: 22901 Location: The Netherlands, Enschede
Audio files: 239
G2 patch files: 319
Posted: Fri Apr 17, 2009 12:15 pm Post subject:
State Machine wrote: | If Shane just keeps it all in standard GMT, the times will be correct as someone here in the states would just subtract the normal 4 hours. |
As long as you keep in mind that GMT doesn't use daylight saving and so when they mess with your clocks again that interval would change  _________________ Jan
Posted: Fri Apr 17, 2009 12:31 pm Post subject:
Quote: | As long as you keep in mind that GMT doesn't use daylight saving and so when they mess with your clocks again that interval would change |
Yes, good point. In the fall here on the US east coast, we set the clocks back one hour thus we would then need to add GMT + 5 hours.
Thanks Jan
Bill |
cappy2112
Joined: Dec 24, 2004 Posts: 2436 Location: San Jose, California
Posted: Fri Apr 24, 2009 8:09 pm Post subject:
Re: NEW Electro-Music Radio Schedule |
shanemorris wrote: | electro-music.com now hosts regularly-scheduled streaming radio programming featuring live performances, recorded music, interviews, demos, and more. Please tune in and join us in the chatroom!
~ALL TIMES GMT~
FIRST and THIRD TUESDAY of EVERY MONTH:
23:00 - 00:00 The Soldering Musician with State Machine
AND WEEKLY:
THURSDAY:
23:00 - 00:00 Boiar - Live Streaming Performance
FRIDAY:
21:00 - 23:00 Edison's Ephemera with EdisonRex
23:00 - 24:00 The Chuck Show with Inventor
24:00 - 25:00 Space Station with Shane Morris
The stream is here, and we'll be in the chat room!
For a GMT / local time calculator click here
Some of the mp3 from the radio shows have bad links. _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Audio files: 239
G2 patch files: 319
Posted: Sat Apr 25, 2009 4:23 am Post subject:
cappy2112 wrote: | Some of the mp3 from the radio shows have bad links. |
Maybe you have an example of a non working link for me? I tested most of the 66 links to music here and they all worked for me, the way the page is generated should ensure the rest is working as well then ... but I could have made a mistake of course in the programming logic. _________________ Jan
cappy2112
Posted: Sat Apr 25, 2009 8:55 am Post subject:
Blue Hell wrote: | cappy2112 wrote: | Some of the mp3 from the radio shows have bad links. |
Maybe you have an example of a non working link for me? I tested most of the 66 links to music here and they all worked for me, the way the page is generated should ensure the rest is working as well then ... but I could have made a mistake of course in the programming logic. |
http://bluehell.electro-music.com/_streams/2009-03-01/track-12.mp3
Tracks11,13-15 are bad as well _________________ Free Tibet. Release the Panchen Lama from prison. Let the Dalai Lama return to his home. |
Audio files: 239
G2 patch files: 319
Posted: Sat Apr 25, 2009 10:04 am Post subject:
Try CTRL+F5 on the page maybe, that link indeed exists no more as I rearranged things a bit but the page that I have here works ok on all those tracks.
There will be more changes soon though, I'm currently transferring all recordings to the main server ... the archives might not be too responsive for the next couple of hours ... my outgoing link is like FULL. _________________ Jan
Audio files: 239
G2 patch files: 319
Posted: Sun Apr 26, 2009 1:58 pm Post subject:
The streaming archives are on the main server now :
http://electro-music.com/radio/archives/
I'll try to find all old links & update 'm ... _________________ Jan
Posted: Mon Apr 27, 2009 4:38 am Post subject:
Quote: | The streaming archives are on the main server now : |
Hey great ... looks fine !!! I see the "m3u" links to .... WMP friendly links !!!
Thanks Jan |
Audio files: 239
G2 patch files: 319
Posted: Mon Apr 27, 2009 4:41 am Post subject:
But we're having a problem ... when I listen to a pls or m3u the link keeps getting dropped ...
In winamp that is ... now testing WMP with an m3u link. _________________ Jan
djfoxyfox
Joined: Feb 05, 2003 Posts: 2230 Location: Nazareth, Pennsylvania, USA
Posted: Sun Mar 21, 2010 4:14 am Post subject:
Daylight Saving Time |
Now that it's Daylight Saving Time, the US east cost has changed from EST/UTC-5 to EDT/UTC-4. The schedule shows, for example: Quote: | MONDAY:
22:00 - 00:00 GMT
Edison's Electronic Review with EdisonRex | Before the time change, 2200 GMT was 1700 EST or 5 pm EST. After the time change, that is now 1800 EST or 6 pm EST.
Is everyone OK with the schedule effectively springing forward by an hour? I'm wondering if the schedule should be moved back an hour so that the shows remain at the same local time as before the time change. Chez Mosc was 6 pm for me and is now 7 pm. That means midnight in the UK (are they on Summer time yet?) and 1 am in western Europe. This is later than what I'd like. I'm interested in moving the schedule back an hour while we're on Daylight Saving Time. What do all of you think?
Cheers, _________________ Bill Fox------------------|\-------------
-----------()----soundscapes.us/bill Last edited by djfoxyfox on Tue Feb 01, 2011 12:45 pm; edited 1 time in total |
shanemorris
Audio files: 83
Posted: Sun Mar 21, 2010 4:33 am Post subject:
Re: Daylight Saving Time |
djfoxyfox wrote: | Now that it's Daylight Saving Time, the US east cost has changed from EST/UTC-5 to EDT/UTC-4. The schedule shows, for example: Quote: | MONDAY:
22:00 - 00:00 GMT
Is everyone OK with the schedule effectively springing forward by an hour? I'm wondering if the schedule should be moved back an hour so that the shows remain at the same local time as before the time change. Chez Mosc was 6 pm for me and is now 7 pm. That means midnight in the UK (are they on Summer time yet?) and 1 am in western Europe. This is later than what I'd like. I'm interested in moving the schedule back an hour while we're on Daylight Saving Time. What you all of you think?
Cheers, |
Hey Bill
If people want to move their schedules around that is always fine.
Please just post request and Ill change it on the radio schedule above.
Bill you want me to move Chez Mosc to 22:00 - 00:00? _________________ ElectroCasa |
djfoxyfox
Posted: Sun Mar 21, 2010 7:39 am Post subject:
shanemorris wrote: | Bill you want me to move Chez Mosc to 22:00 - 00:00? | I do but let's double check with Howard first before making any changes. After all, it is Chez Mosc.
-----------()----soundscapes.us/bill Last edited by djfoxyfox on Tue Feb 01, 2011 12:48 pm; edited 1 time in total |
Posted: Sun Mar 21, 2010 7:49 am Post subject:
Bill makes a good point but it was opposite for me. I like the summer schedule because my show, in winter, starts at 6PM. I get home from work at 5:45 so that gives me 15 minutes till start. In summer, it starts at 7PM ... much nicer
I think I will do my schedule move in winter next time.
BTW, end of this month is British Summer Time, GMT+1.
Bill |
Joined: Feb 04, 2005 Posts: 2664 Location: Nottingham, UK
Audio files: 266
Posted: Sun Mar 21, 2010 7:54 am Post subject:
With regard to GMT times for shows, I'd much rather keep AIS at 11pm and not move it an hour later once we get in to DST, it's just too late and it gets confusing with show times changing _________________ Jez
music | adventures in sound | gear for sale |
shanemorris
Audio files: 83
Posted: Sun Mar 21, 2010 8:45 am Post subject:
modulator_esp wrote: | With regard to GMT times for shows, I'd much rather keep AIS at 11pm and not move it an hour later once we get in to DST, it's just too late and it gets confusing with show times changing |
It doesnt matter to me one way or the other for my show. But since at least 1/2 or the majority of the listening audience is EU, I dont mind to play earlier either.
Ill adjust to whatever you and Rob decide on.  _________________ ElectroCasa |
EdisonRex
Audio files: 171
Posted: Sun Mar 21, 2010 11:09 am Post subject:
Likewise, once we move to Summer Time, I'll keep my shows at clock time (ie they will move back an hour GMT) so as to keep the clock time constant (except for those places which don't move their clocks). So after next week, I'll change my times on the schedule. _________________ Garret: It's so retro.
djfoxyfox
Posted: Sun Mar 21, 2010 1:14 pm Post subject:
EdisonRex wrote: | Likewise, once we move to Summer Time... | When does Summer Time start?
-----------()----soundscapes.us/bill |
Audio files: 239
G2 patch files: 319
Posted: Sun Mar 21, 2010 1:19 pm Post subject:
djfoxyfox wrote: | EdisonRex wrote: | Likewise, once we move to Summer Time... | When does Summer Time start? |
Last sunday of march, 28th this year. _________________ Jan
nobody
Posted: Sun Mar 21, 2010 2:43 pm Post subject:
At the risk of sounding ignorant, what's summer time? Is it "I love Cali in the summer time? Yeah, hey!"? |
EdisonRex
Audio files: 171
Posted: Sun Mar 21, 2010 5:19 pm Post subject:
audiodef wrote: | At the risk of sounding ignorant, what's summer time? Is it "I love Cali in the summer time? Yeah, hey!"? |
Look here _________________ Garret: It's so retro.
nobody
Posted: Sun Mar 21, 2010 6:41 pm Post subject:
Oh, it's just DST by another name.
Changing clocks to "save daylight": stupidest idea ever. |
djfoxyfox
Posted: Sun Mar 21, 2010 8:29 pm Post subject:
audiodef wrote: | Changing clocks to "save daylight": stupidest idea ever. | It is controversial. The only benefit that I can see of DST is that AFTER you get home from work, you have an extra hour of daylight that was stolen from the morning... which is hogwash. All you have to do is start work an hour earlier to achieve the same thing... or just leave work an hour earlier. DST is a mechanism of society that is just more complicated than just changing your work hours. But then not everyone would do it which is fine as far as I'm concerned. _________________ Bill Fox------------------|\-------------
