 Forum index » Instruments and Equipment » Sequencers
one note from the computer to trig one step of a machine
Page 1 of 1 [5 Posts]
sitarane
PostPosted: Tue Apr 21, 2009 1:15 pm    Post subject: one note from the computer to trig one step of a machine Reply with quote  Mark this post and the followings unread
hello,
I'd like to make my computer (with cubase or ableton or any software on it)
to trig a hardware drum machine or groove synthetiser.
For each note the computer play the hardware's sequencer play one step
of his own pattern
Then the hardware will play with the groove of the note sequence in the computer.
because my music is african traditional stuf that 's can't be program in the binary or ternary of the hardware sequencer.
example of hardware : korg SX1, MFB synth II, future retro revolution
computer is connected by midi .
thank you
it's important.
Tien bo larg pa !
Audio files: 215
G2 patch files: 92
PostPosted: Tue Apr 21, 2009 1:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are you planning on getting something new, or do you want to know whether you can use any of the hardware you mention? The DSI Evolver can do what you want with its 16 step sequencers.
I have an Electribe SX-1, and I'm not aware of any stepping by note on functionality. Maybe someone else knows about the MFB and Future Retro.
/Stefan
sitarane
PostPosted: Tue Apr 21, 2009 9:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for this information , yes I would like to know wich other instrument like the evolver can be step by a sound or midi note.
BUT, the real thing is,
is it possible to tweak cubase or ableton to do that with any other midi hardware sequencer?
or do i need something between the computer and the hardware
like a flame echometer ?
Tien bo larg pa !
Audio files: 150
PostPosted: Wed Apr 22, 2009 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if it is possible to do exactly what you want to do with MIDI, but a possible way to get the same effect would be to use your 'groove' patterns to build up a groove template in Cubase then record your sequences from your external gear into Cubase and quantise them to the groove, then use the external gear as sound modules played by Cubase.
Apart from the evolver, the only other hardware I can think of where patterns can be stepped by midi note messages would be the Nord modulars
music | adventures in sound
sitarane
PostPosted: Wed Apr 22, 2009 9:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes this is exactly what I use to do and i have made an album like this.
It's a long process and it's more research than direct composing, you see.
Tien bo larg pa !
