A fun experiment
Page 1 of 1 [17 Posts]
Muied Lumens
Audio files: 209
PostPosted: Sun May 10, 2009 6:57 am    Post subject: A fun experiment Reply with quote  Mark this post and the followings unread
I worked on this one a few years ago, but decided that I needed more data. This is what I did yesterday:
This site: http://resource.npl.co.uk/pressure/pressure.html, contains historical data from a barometer in Teddington, UK, just outside of London. You can define the time span that you want the data from so I took the last 8 years (April 2001 - May 2009)and got the raw data from it. I stripped the dates from the text in MS Excel and fed it into Adobe Audition, where I did a DC removal and amplified it by about 45 dB, then cut the subsonics.
My wav file is about 8 seconds long, roughly corresponding to 8 years of pressure changes, and you can hear the distinct changes over a single year. If you count the repetitions, you get eight of them.
There are some clicks in there which is probably my fault (Excel will only load about 16300 rows at a time, so I had to chop he data up and do it piece by piece), but the steady tones you can hear are a mystery to me...
The thought behind this is that barometric changes and sound are the same - pressure changes over time. One is just a little slower than the other. Smile
8years.wav
Wav file containing eight years of barometric pressure changes in Teddington, UK
 Filename:  8years.wav
 Filesize:  696.83 KB
 Downloaded:  270 Time(s)
Muied Lumens Base Star
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun May 10, 2009 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
the idea is startling, the results less so Shocked but...........it's only a start Wink
Politics is the entertainment division of the military industrial complex - Frank Zappa
Muied Lumens
Audio files: 209
PostPosted: Sun May 10, 2009 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, who would have thought that the weather sounds like wind in a mic? Razz
ark
G2 patch files: 31
PostPosted: Sun May 10, 2009 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Well, they're both fractal...
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 9:55 am    Post subject: Re: A fun experiment Reply with quote  Mark this post and the followings unread
Did you feed a text file to Audition or did you make it binary first?
I'm asking as I repeated the experiment and get a different outcome ;-)
baromhist.wav
 Filename:  baromhist.wav
 Filesize:  1.58 MB
 Downloaded:  426 Time(s)
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
As in that the days are audible as a tone of about 153 Hz.
Muied Lumens
Audio files: 209
PostPosted: Sun May 10, 2009 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course! That sounds plausible.
I stripped off the date and time data before I fed it straight into audition. Because of the way I did it, I'm not surprised you got a different result.
seraph
Editor
Editor
Audio files: 31
PostPosted: Sun May 10, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
yours sounds different because you are located in the Netherlands. I can hear the rain from here Exclamation
You don't need a Ph.D to understand something this simple Exclamation Wink
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I stripped the dates off as well and then I ran this code on it to make a binary file that I read into cool edit.
Code:
const
  in_file_name  = 'X:\Temp\baromhist.txt';
  out_file_name = 'X:\Temp\baromhist.bin';
var
  Data : array of Integer;
  AvgN : Int64;
  procedure ReadData( const aFileName: string);
  var
    aFile : TextFile;
    S     : string;
    i     : Integer;
    p     : Integer;
    N     : Integer;
    sum   : Int64;
  begin
    AssignFile( aFile, aFileName);
    Reset( aFile);
    AvgN := 0;
    sum  := 0;
    SetLength( Data, 1024);
    p := 0;
    try
      while not Eof( aFile)
      do begin
        ReadLn( aFile, S);
        N := StrToIntDef( S, -1);
        if N >= 0
        then begin
          sum  := sum + N;
          if p >= Length( Data)
          then SetLength( Data, Length( Data) + 1024);
          Data[ p] := N;
          Inc( p);
        end;
      end;
      SetLength( Data, p);
      AvGN := sum div p;
      for i := 0 to Length( Data) - 1
      do Data[ i] := ( Data[ i] - AvgN) ;
    finally
      CloseFile( aFile);
    end;
  end;
  procedure WriteData( const aFileName: string);
  var
    aFile : file of SmallInt;
    i     : Integer;
  begin
    Rewrite( aFile);
    try
      do Write( aFile, Data[ i]);
    finally
      CloseFile( aFile);
    end;
  end;
  procedure DoIt;
  begin
    ReadData( in_file_name);
    WriteData( out_file_name);
  end;
procedure TForm1.BitBtnDoItClick(Sender: TObject);
begin
  DoIt;
end;
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 12:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
hmm .. maybe you do ... Shocked
Muied Lumens
Audio files: 209
PostPosted: Sun May 10, 2009 12:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
Jan, I'm assuming that you normalised and DC corrected the data, but I'm not a programmer, so I can't tell much from looking at your code.
I did that in Excel, using a small collection by taking the average and converting the numbers to positive and negative values. I also checked the graphs from the NPL site to see that it corresponded with the wave in AA. As far as I could see, it correlated well enough for my unscientific purpose...
Yours sound better though. Smile
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 12:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
I subtracted the average value from each data sample to remove the DC component, but didn't normalize ... I meant to do it, but there was a reasonable amount of signal, so I just later normalized in Cool Edit to -3 dB.
The biggest difference is that I saved the file as binary data, where you saved it as text probably ... but then your wave would have looked very different from the graph on the site ... so I don't quite get that bit Wink
Anyway, I checked my wave against the plot on the site as well, and thought it to look similar.
Oh there is an interpretation detail .. I set it to read data as if it were 16 bit mono PCM, your file is shorter, so probably you imported it with other settings.
Edit : I took the dots out of the data, effectively multiplying by 100.
Muied Lumens
Audio files: 209
PostPosted: Sun May 10, 2009 3:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
I did import a text file indeed, and was a little unsure of how the commas would be interpreted by the software, 16 bit 44.1 kHz mono. The general trend is the same as the plot, but I guess yours is much more accurate in the detail. The reason mine is a smaller file is because I pitched it up to correspond with a second a year. I conveniently forgot to mention this earlier. Wink
You did it the proper way, so I trust your judgement. I've got to learn myself how to do some of that fancy code. Very Happy
Audio files: 116
G2 patch files: 317
PostPosted: Sun May 10, 2009 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Muied Lumens wrote:
I've got to learn myself how to do some of that fancy code. :D
Copy it ;-) (using Free Pascal and Lazarus)
Rykhaard
PostPosted: Sun May 10, 2009 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Copy it Wink (using Free Pascal and Lazarus)
The code minorly stumped me in formatting here and there but then, I'm just used to various forms of Basic (with a bare smattering of C and C++ and a few glances at 8 bit Assembler) over the years. Surprised
And who's this Lazarus guy, anyways? Wink
Inventor
Audio files: 258
PostPosted: Fri May 15, 2009 7:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I vaguely remember reading that a telecom twisted pair cable buried underground in North America has an impedance variation which is roughly sinusoidal. I think it was due to winter/summer temperature variation.
Muied Lumens
Audio files: 209
PostPosted: Wed May 20, 2009 9:33 am    Post subject: Reply with quote  Mark this post and the followings unread
When looking for plugins for a friend, I came across this:
http://arvidtp.net/sw/maestro_frankenstein.php
Seems like somebody out there has similar ideas...
emSynth
