 Forum index » Clavia Nord Modular » G2 Patches - Completed » Drum
Machine DRUM II
Page 1 of 1 [10 Posts]
mother misty
G2 patch files: 130
PostPosted: Tue Oct 25, 2005 12:12 am    Post subject: Machine DRUM II Reply with quote  Mark this post and the followings unread
not really an elektron machinedrum-clone (sorry to dissapoint you if you were expecting this Smile )
but a reworked version of richard devine's "machine DRUM 2" patch
I've added some new features like a mod env for the filters, a new fx section (3 bands distortion-unit with compressor),
a re-trigger function, a new mixer, knobs assignments new presets and 4 morph groups
morph group 1 (modwheel) : re-trigger function, move modhweel for re-triggering, adjust interval with the clockdivider and rnd-trigger
morph group 2 (page E:1) : morph effect, various parameters are assigned to this, move it to hear the effect
morph group 3 (page E:1) : morph effect, various parameters are assigned to this, move it to hear the effect
morph group 7 (pitchstick) : morph effect, this is a copy of morph group 2 or 3, but bi-polar instead of unipolar
you can do some crazy stuff with these morphs, certainly when you combine them, check audio example for a little demonstration.
This is a just a loop of 16 steps long (with no modulations) but if you tweak the morphs (and I've *only* tweaked the morphs during
that recording, nothing else) it gives this kind of result (check mp3 for example, the first 10 seconds is the loop without morph tweaks)
enjoy!
MD2MMAE_ROOM121.MP3
audio example Machine DRUM II with various morph tweaks
 Filename:  MD2MMAE_ROOM121.MP3
 Filesize:  2.04 MB
 Downloaded:  1760 Time(s)
MACHINE_DRUM_2MM.PCH2
reworked version of richard devine's machine DRUM II.
Tweak morphs for effects
 Filename:  MACHINE_DRUM_2MM.PCH2
 Filesize:  8.05 KB
 Downloaded:  2584 Time(s)
Afro88
Audio files: 12
G2 patch files: 79
PostPosted: Tue Oct 25, 2005 1:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow, this is fantastic! I'm having great fun cranking the retrig right up, then morphing it into something new and throwing the retrig back to 0.
Thanks for this patch! Very Happy
eposk
PostPosted: Tue Oct 25, 2005 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
man! i thought richards patch had lots of potential, but you totally put a twist on it. The retrig wheel action is very WARP material. great design!
Laszlo
PostPosted: Fri Jun 08, 2007 2:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow! looks useful!!! thanks!
W.T.
G2 patch files: 11
PostPosted: Fri Jun 08, 2007 3:26 am    Post subject: Re: Machine DRUM II Reply with quote  Mark this post and the followings unread
doesn't matter because i have a MD Smile
de mp3 sounds wicked, can't wait to load this patch in my g2 Wink
thanks
mother misty
G2 patch files: 130
PostPosted: Fri Jun 08, 2007 5:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad you like it.
welcome by the way
(I'm listing to "Ayime" at the moment, sounds like a sweet release man!)
Laszlo
PostPosted: Fri Jun 08, 2007 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
mother misty wrote:
welcome by the way
Thanks a lot Embarassed Hope you like it Surprised
dido
PostPosted: Sat May 16, 2009 9:40 am    Post subject: Reply with quote  Mark this post and the followings unread
hi Mother Misty i want know if there is a patch of drums that are not sequenced, i want play this patch like a drumkit by my sequencer live 7 or the keys of g2.
i m at first arms with g2 and his editors.
bye Dido
mother misty
G2 patch files: 130
PostPosted: Mon May 18, 2009 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
bye Dido
Hi dido!
sorry for the late reply. I've changed the patch a little bit, now you can sequence it from a DAW. (keymappings are kick=C0, perc=D0, SHPOSC=E0, SHPOSC 2=F0)
(Basicly, you just have to replace the trigger outputs from the sequencer with a note receive module in order to make this patch work with a DAW)
misty.
EDIT: you still need to change the value of the midi-note receive modules (top left) in the other variations, only works correctly in the 1st variation of the patch now.
MD2-NOSEQ.pch2
Machinedrum II patch (without internal sequencer)
 Filename:  MD2-NOSEQ.pch2
 Filesize:  7.51 KB
 Downloaded:  1372 Time(s)
http://www.myspace.com/mariodemeyer
dido
PostPosted: Mon May 18, 2009 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx Mother misty.
Ciao Dido
