droffset
Joined: Feb 02, 2009 Posts: 480 Location: new zealand
Posted: Mon May 18, 2009 3:20 pm Post subject:
Does this kind of counter exist? |
Here's what the 4040 does, the ripple carry counter:
See how each output stage is basded on the last, and the pulse length extends?
But that's not what i really want at the moment.
I'd like each output stage to still be based on the clock, but keeping the same pulse length, so:
Q1: up/down on each clock downward change
Q2: up/down on every second downward stage
Q3: up/down on every third downward stage
So the rippled pulses stay the same size as the clock pulses but are more spaced out.
See what I mean? If you know of an IC that does this please let me know.
Thanks |
Joined: Apr 03, 2004 Posts: 19570 Location: The Netherlands, Enschede
Audio files: 116
G2 patch files: 317
Posted: Mon May 18, 2009 3:49 pm Post subject:
Re: Does this kind of counter exist? |
| droffset wrote: | | So the rippled pulses stay the same size as the clock pulses but are more spaced out. |
Sounds like what a rate multiplier does, note that a rate multiplier in fact is a divider. Only thing is that it doesn't double the spacing on each stage, as it has only one stage .. that stage however is binary programmable through a couple (like four) binary rate inputs.
Look at CD4089 for instance. _________________ Jan |
droffset
Posted: Tue May 19, 2009 1:39 am Post subject:
Thanks Blue Hell, I'll look into rate multipliers.
Just to be clear this is the desired behavior.
I was thinking about setting up a 4017 to do the divisions i needed but i love the way that 4040 gives me several outputs ready to go.
Another thing to explore is flip/flops, I understand that's what ripple counters are based on.
The end goal is a monster clock module, that does both ripple carry counting on one column and this sort of Offset Counting on the other column.
All based on a pwm timer. |
Inventor
Joined: Oct 13, 2007 Posts: 5947 Location: San Antonio, Tx, USA
Audio files: 256
Posted: Tue May 19, 2009 4:09 am Post subject:
droffset,
Q0 and Q2 could be obtained by ANDing of the available signals from the 4040. Q0 is the AND of the 4040's Q0 output with the clock, and Q2 is the AND of the 4040's Q2 with that derived Q0. Q1 requires a divide-by-three counter and Q3 looks like you'd need a divide-by-five counter (plus logic off of the output bits as described.
I'd consider changing the requirement so that the non-binary cascading bit thingie is a binary cascading bit thingie, that way you could derive everything from ANDing of the 4040's output bits. See what I mean?
slacker
Posted: Tue May 19, 2009 5:17 am Post subject:
| I think one of Ken Stone's designs uses a counter and some NAND or XOR gates to do this. Can't remember which one it is at the minute though, sorry. |
slacker
Posted: Tue May 19, 2009 10:55 am Post subject:
I was thinking of the master divider and unfortunately it doesn't do what I thought it did.
I tried what Les suggested and that gives you the 2,4,8,16... divisions but each one only stays high for 1 clock pulse. They're in sync with other though not offset.
What you could do is run the outputs through individual one shot generators then you could have whatever pulse length you wanted. |
Inventor
Audio files: 256
Posted: Tue May 19, 2009 11:17 am Post subject:
Thanks for checking out what I said, slacker: teamwork in action!
I suppose to get really fancy, we'd need to look at it like this: Those pulses are 2, 3, 4, and 5 cycles long. 2 is a trivial case since 4 is 2x2, so that means we have 3x4x5 = 60 clock cycles before the pattern repeats. So we'd need a counter that counts to 60, then we could derive the desired clocks off of that using logic.
But anyways, I like the one-shot idea if you really really need those cascaded clocks. _________________ "Let's make noise for peace." - Kijjaz |
slacker
Posted: Tue May 19, 2009 12:00 pm Post subject:
| Inventor wrote: | Thanks for checking out what I said, slacker: teamwork in action!
No problem, just a case of patching up the Lunetta, only took a couple of minutes. |
droffset
Posted: Tue May 19, 2009 12:36 pm Post subject:
Thanks guys, lots of ideas to try!
I'm not that fussed about a lot of the requirements, as long as something interesting comes out.  |
amplex
Joined: May 26, 2008 Posts: 64 Location: sacramento, ca
Audio files: 6
RF
Joined: Mar 23, 2007 Posts: 1481 Location: Northern Minnesota, USA
Audio files: 28
droffset
Posted: Wed May 20, 2009 4:21 am Post subject:
amplex, I have a different divide by N counter, i think it's the 4018, might do something similar, will have to play with it.
Bruce, Thanks for that, i had something similar in mind with 4017, glad i won't have to reinvent the wheel.  |
