jenamu6
Posted: Wed May 20, 2009 11:51 pm Post subject:
Simple lunetta question |
Hi, I'm new on the board.......and very new on Lunettas
I've been reading almost every post on this site, and came up with an idea to make a rhythm machine.
Basically this is what I wanna build.
3 different square clock generators, all with different pots.
Then a couple of nand, and, or ports and dividers.
So I'll be getting different trigger rhythms at one tempo, to control my Serge and Digisound modular.
Questions:
-I simulated the idea, and it worked. Do you guys think it will also work in the real world........so would I be able to trigger my modular?
-I've read that all unused cmos ports should be conected to ground. But in this design I would like everything to be modular. So open banana connections to the AND, OR etc.
That would mean when not patched, they would be unused..........but not grounded. Would that work?
Thanks,
Jean |
Posted: Thu May 21, 2009 3:19 am Post subject:
Just put a 100K resistor between the inputs and ground. It will still work when connected, but will be held down when not. |
jenamu6
Posted: Thu May 21, 2009 4:42 am Post subject:
OK, thanks.
So if I understand it right....for instance an and port will have 2 connections to ground via a 100K resistor?
I'm about to order my lunetta stuf.
I really think it would make an excellent trigger machine for my modular, and when the speed of the clocks will go up, it'll still be a nice Lunetta noise machine.
Anybody tried the semi-random trigger machine idea? |
Rykhaard
Posted: Thu May 21, 2009 4:46 am Post subject:
jenamu6 wrote: | OK, thanks.
As a standard for all of my CMOS inputs in my noise machine I have a 100k resistor to Ground, along with a diode from the jack to the pin / resistor connection. This way, my chips are protected from any -V that could possibly come their way.
With the 100k resistors to Ground for every logical input, you should be ok. (There are some control inputs that require their function to go LOW. When they're to be held HIGH normally, a 100k resistor to +V will do.) |
jenamu6
Posted: Thu May 21, 2009 6:28 am Post subject:
OK, just ordered a whole bunch of:
CMos chips, Leds, 100K resistors, diodes, breadboard, banana sockets and some more.
With these I could build at least 2 lunetta noisemachines and 1 supertrigger machine.
I'll keep you guys posted. |
RF
Audio files: 28
Posted: Thu May 21, 2009 6:32 am Post subject:
Allright jenamu6! We'll look forward to seeing what you come up with - it's nice to have another one building these!
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Rykhaard
Posted: Thu May 21, 2009 8:34 am Post subject:
RF wrote: | Allright jenamu6! We'll look forward to seeing what you come up with - it's nice to have another one building these!
bruce |
Agreed! Not so much as "the more the merrier" but "the more the noisier"! |
RKHobbs
Posted: Thu May 21, 2009 1:37 pm Post subject:
If you build a Nandsynth with big (10uF+ capacitors) it will give you trigger clicks that can be dialed in to produce all kinds of odd polyrhythm. |
Rykhaard
Posted: Thu May 21, 2009 1:55 pm Post subject:
RKHobbs wrote: | If you build a Nandsynth with big (10uF+ capacitors) it will give you trigger clicks that can be dialed in to produce all kinds of odd polyrhythm. |
Now that's a very cool idea! I may have to try that as well with my NAND Synth / 40106 Saw VCO cross. With larger caps, I could come to unpredictable rhythms, which could be quite useful. |
jenamu6
Posted: Thu May 21, 2009 10:36 pm Post subject:
Does it have to be a NAND gate synth?
I did order NAND gates, but I planned 40106 oscillators......will they have a strong enough signal to trigger for examples my slope generators on the Serge?
I can't wait for the breadbord and parts to arrive.............but first we'll go on a camping trip with the kids this weekend (first time) |
RKHobbs
Posted: Fri May 22, 2009 9:47 am Post subject:
You can use the 40106es for pseudo-random like Ken Stone does in the Psycho (and SuperPsycho) LFO.
If you cascade one output into the next gate, the nand gates switch each other on and off.
I don't know what the Serge needs, but the 40106 and 4093 put out a pretty hefty click. |
Rykhaard
Posted: Fri May 22, 2009 10:57 am Post subject:
RKHobbs wrote: | You can use the 40106es for pseudo-random like Ken Stone does in the Psycho (and SuperPsycho) LFO.
The outputs from the CMOS inverters will be the level that you power them with. You could check to see what voltage level the Serge panel requires and make sure that you're powering your CMOS from the same voltage level. (Minimum). You should be ok there as long as you don't feed the Serge too high or an incorrect voltage. (In case the related one does not accept negative voltages.) |
jenamu6
Posted: Sun May 24, 2009 7:07 am Post subject:
Thanks guys.
This week I'll get the parts, I'll keep you posted. |
jenamu6
Posted: Thu May 28, 2009 1:04 pm Post subject:
Parts came in today.
Made my first oscillator from a 40106, connected a LED........and the LED flashed.
So I took the breadboard to my modular.............and YES the pulses from the 40106 trigger my modular.
So off the breadboard an onto perf board..........can't wait to try the XOR and AND ports. |
RF
Audio files: 28
Posted: Thu May 28, 2009 3:47 pm Post subject:
Yay! Success
Now get back to building....
